I have one for a '54 but I am not sure if it is the same as '55. Maybe someone can check that out as I don't have the parts book. Alan
Look on eBay. I've found lots of parts for my '59 and some hard to find stuff as well. I've seen '57 to '59 pedals before.
Will slightly later years work? Not mine. https://scranton.craigslist.org/pts/d/berwick-ford-car-clutch-brake-pedals/7473954963.html
This search took me less than a minute and filters can be applied to narrow down the results. I just used 1955 Ford pedals. https://www.ebay.com/itm/115257147119?hash=item1ad5dc7eef:g:rM0AAOSwISliEAvd https://www.ebay.com/itm/263994453837?hash=item3d774baf4d:g:esUAAOSwVxdblByQ
Dm me. I just took off the pedals of my '55 customline I have the manual pedals. I don't have the mounting bracket though because one i got with the auto pedal I bought didn't fit a sedan. Thinking it was a truck bracket or something. Anyway I was able to swap the auto pedal and pivot bolt to the manual bracket and it worked just fine. Anyway I still have the pedals, pivot bolt, springs, clutch linkage pivot point from the engine bay, linkage from clutch to clutch pivot. Where are you located?
Thanks everyone. I found a mount bracket and pedal out of Minnesota! my next question is, what push rod / plunger can I use ? Or I guess, what length? Who sells aftermarket ones. I will be using a 60’s f100 booster with a 60’s master cylinder. And again, thanks for all the help and guidance from all of you!
You should get this one so you can adjust it for your parts swap. https://www.ebay.com/itm/2635256867...LUflS+FRQM9xNq87fY2TAzfLWg==|tkp:BFBMnsWAmJNg
