Technical WANTED- Additive to Kick the Smoking Habit
Discussion in 'The Hokey Ass Message Board' started by kencemo, Mar 21, 2018.
  1. kencemo
    kencemo
    from Sacramento
    Has anyone had success with an additive to spray or pour in the cylinder? I have identified #7 on a Ohv V8 as the weak cylinder allowing some oil past some sticky rings? Valve job was the last thing done. After that the car has sat off and on for the last 40 years. Also tried a pcv valve. It helped but more pressure than that could control. Smoke mostly noticeable from blowby vent (not exhaust).
  2. Hollywood-East
    Hollywood-East
    I heard car Lot's would tip Clorox cleanser(not bleach) down the carb running...said to ruff up cylinders, No I'm not recommending it, But it was something that was done many moons ago... Note:Car lot!
  3. Gman0046
    Gman0046
    They say Chantix works great.
    Irish Mike, bobss396 and 55styleliner like this.
  4. Try ATF and Acetone, half and half, in the bad hole, put it at bottom dead center and fill it up thru the spark plug hole, let it stand for a week or until it empties. It works to loosen up the rings. I f you can get a wood dowel thru the plug hole to the top of the piston tap it to jiggle the rings while it's full of the ATF and Acetone. Could be a stuck valve which means you'll have to pull the head, pour the juice on the stem and tap on it til it's free.
  5. blowby
    blowby
    from Nicasio Ca
    That's the Bon Ami tune-up. :) Supposedly recommended when the new SBC came out and rings weren't seating. Supposedly.
    There was a thread not too long ago on snake oils. Surprisingly a number of posters said the Lucas oil treatment worked wonders. I think this is it.
    https://www.jalopyjournal.com/forum/threads/snake-oils-or-not-snake-oils.1082062/
    Hollywood-East likes this.
  6. catdad49
    catdad49
    Nicorette?!
    wraymen likes this.
  7. Slopok
    Slopok
    Have you tried the patch yet?;)
  8. mike bowling
    mike bowling
    Tighter valves put more stress on loose rings , no?
  9. indyjps
    indyjps
    Id go with ATF / acetone soak to loosen the rings up, pull the plugs and get it all blown oit and running again. Then run it at 2500 rpm and trickle water down the carb, knocks a lot of carbon loose.
    Used the water "cleanse" a few times, also saw it frequently in army motor pool.
    If that doesnt clean it out, go for more aggressive action. Never heard of bleach.
    BJR likes this.
  10. Add Lukas oil addictive to your oil
    Only stuff I use and works well.
  11. Deuces
    Deuces
    That's what I need....:(:rolleyes:
  12. 302GMC
    302GMC
    from Idaho
    https://www.jalopyjournal.com/forum/threads/snake-oils-or-not-snake-oils.1082062/[/QUOTE]
    This dates back to at least 1941 when "the cure" appears in Buick or Chevrolet service news as a ring seating operation for slowly driven cars not broken in. It doesn't work on worn out stuff. Whoever did the heads without at least ringing it probably parked it soon ...
  13. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    Get yourself a bottle of RESTORE from WallyWorld
    JeffB2 likes this.
  14. BadgeZ28
    BadgeZ28
    from Oregon
    I had a beater with the same problem. I tried several motor honeys, etc. They helped a bit but the fact is the only solution is a rebuild.
  15. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    I have also tried RESTORE and it worked pretty well.Only problem is has to be used continuously,not just once.
    JeffB2 likes this.
  16. Truck64
    Truck64
    from Ioway
    What do the plugs look like right now. Oftentimes mistuned carburetors will tend to foul the cylinders and possibly "wash out" rings or contribute to cylinder glazing. Don't want that because it is basically irreversible. Make sure ignition is hot and carb is adjusted proper.
    Can use some of that marvelous mysterious oil in both the fuel and crankcase oil as per ratio directions on the can. The beauty of that stuff is if it's going to work, it should work pretty quickly, within a tank of gas easy. Get it good and warmed up to speed on the highway and vary the load and decelerate etc. Drive the piss out of it. Worth a try for sure.
  17. Mike VV
    Mike VV
    from SoCal
    Yes, while not a "pour-in", it's called new piston rings, valve guides and seals.
    You really think some snake oil additive is gonna "fix" things. A thick oil/STP may disguise things for a while, but thick oil doesn't flow very well, especially on cold days..!
    Mike
    Barrelnose pickup likes this.
  18. squirrel
    I had a couple old engines that had been sitting for a while, and needed to drive 5000 miles. The first one wouldn't start, the rings were stuck, not enough compression. I took it apart, and put rings and gaskets in it, fixed it right up. The second ran but smoked like crazy (less than 100 miles per qt oil), and I took it half way apart, replaced the rings and the cylinder jug that was seriously rusted, and it ran great and didn't smoke any more.
    So, my answer is "no". Fix the thing. You don't need to replace every part in the engine, just the rings and gaskets.
    Rex Stallion, bobss396 and Jiminy like this.
  19. kencemo
    kencemo
    from Sacramento
    Spark plug is more of a charcoal black rather than gray. I does not have any excessive carbon deposits. It is definitely firing as their is a slight change in rpm when disconnected (100 or 200 rpm). The other cylinders drop 400 to 500 rpm. I have a bottle of Rislone Piston Seal on the shelf. I will do a little experimenting with that and see if she will kick the habit! Thanks for the replies.
  20. pat59
    pat59
    Let us know how ya make out.
  21. Truck64
    Truck64
    from Ioway
    Nobody here is claiming an additive will repair worn out piston rings though, are they?
    When I read the original post he was asking about stuck or gummed up rings. Solvents will take care of that. Maybe something else is going on here, but that is what he asked about.
    blowby likes this.
  22. bobss396
    bobss396
    If it works, next step is a Krylon rebuild...
  23. MARKDTN
    MARKDTN
    Is that the same as an aerosol overhaul?
    Truck64 likes this.
  24. I don’t think he was looking for a permanent fix, nor was anyone saying rebuild in a can is that type of fix.
    I’ve limped along a lot of winter beaters with luckas and Barr’s stop leak etc to get 3-6 months of driving out of them.
    You want a correct rebuild after adding luckas and Barr’s to an engine you repaint it, get the cheap chrome dress up kit for it and some moroso and auto meter stickers and go racing !
  25. rmorris
    rmorris
    I only add Marvels Mystery Oil. Old school.
    Truck64 likes this.
