WANTED!! Caddy 331 engine
Discussion in 'The Hokey Ass Message Board' started by Badfella, Aug 24, 2004.
  1. Badfella
    Badfella
    Hello all. I'm looking for a Caddy 331 (49-56) engine, hopefully rebuilt longblock but am open to anything (Even blocks). Thanks!
  2. Mild Mitch
    Mild Mitch
    I have a '52 that was un-***embled years ago that I've never gotten to. All of it is there. Block and heads were checked. Each head had a very small repairable crack. Needs a rebuild. $500 plus shipping.
    Thanks,
    Mitch
  3. yorgatron
    yorgatron
    actually,you want a '49-'54.you do NOT need a '55 UNLESS you have the matching dual-range hydra-matic and are planning to use it,or you're going to get the Wilcap adaptor for TH400.the '56 is a 365,NOT 331,i think the exhaust ports are larger-george
  4. RocketDaemon
    RocketDaemon
    from Sweden
    why do you post the same post in both the main message board and in the cl***ified area? do you feel like your post is so much more important then the rest of us, get it ... the cl***ified is for cl***ifieds and the main board is NOT for cl***ified, use ONE only and if your posting cl***ifieds us the CL***IFIED area for that
