Technical Wanted info on Transdapt KD25 Caddy 55-64 to GM 4 speed
Discussion in 'Traditional Hot Rods' started by hotrod_grmi, Nov 5, 2013.
  1. hotrod_grmi
    hotrod_grmi
    Any HAMB member help me with any info, pictures, data, specs on a Transdapt #KD25 Bell Housing Adapter for a 55-64 Caddy (331-390) to GM 4 speed. If anyone has knowledge of this bell housing I would greatly appreciate hearing about it. I have an opportunity to buy one with a new pilot bushing and want as much info and pictures on it as I can get.
    Thanks, Mike
  2. F&J
    F&J
    No info except any original adapter is a rare find for that 2nd generation Cad OHV-8
    I expect you will get some PM's from potential buyers :)
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Pictures or not, hurry up and buy it...I've seen two of them in the past 35 years of swap meets.
  4. Mike, your next post should be that you bought it and here are the pics.
    Charlie
  5. oldsman41
    oldsman41
    I would jump on that. buddy of mine had one years ago I will ask him if he still has it and try to get a pic jf he does.
  6. hotrod_grmi
    hotrod_grmi
    Thanks Oldsman41 that would be great if you could get a few pictures of it.
    Mike
  7. oldsman41
    oldsman41
    yeah called jim last night and he said he sold the damn thing two years ago. sorry
  8. vtwhead
    vtwhead
    Here is what my book says about the KD25. Fits Cad 55-64's and you must use a 54-56 Olds flywheel and pressure plate with a 57-60 Cad starter #1107657 12 volt.
    Hope this helps. No pics.
    Super rare. I would buy it for sure.
  9. hotrod_grmi
    hotrod_grmi
    vtwhead, thank you for the great info on this trans adapter. Plans are to pick up this piece next week.
    Mike
  10. falconsprint63
    falconsprint63
    from Mayberry
    the ring gear is REALLY hard to find too.
  11. Torkwrench
    Torkwrench
    How many teeth would that flywheel have? 176?
  12. falconsprint63
    falconsprint63
    from Mayberry
    no--it's a 153 if memory serves. nobody's making them and the NOS/used pool is getting pretty slim. I found one about 10 years ago and ran it for a while on a schaffer flywhell via a cragger adapter, but ended up changing out the whole setup after I went through 3 6-v caddy starters in short order.
  13. F&J
    F&J
    the 54-56 olds flywheel is 176. The older 303 Olds stick flywheel from 50-53 is the smaller one.
    The 54-56 is harder to find if you want original Olds pieces, but Ross racing has new ones.
    i think i have a NOS 176 ring gear here somewhere
  14. GOATROPER02
    GOATROPER02
    from OHIO
    We have approx 500 176 tooth ring gears in stock for the Olds .... And I always keep a fair amount of 145 tooth as well....
    And as FJ says we make new flywheels as well.....
  15. falconsprint63
    falconsprint63
    from Mayberry
    happily I stand corrected. it's been a while since I went looking for this stuff :)
