"wasted",my new ford 31 coupe
Discussion in 'The Hokey Ass Message Board' started by vonstripers, Dec 12, 2009.
  1. 19Fordy
    19Fordy
    Holey Flexing Wishbones! I still would feel better if the internal circumference of the oblong cuts was "boxed". There would still be an opening but the "hollow" edges would be welded. Hard to explain.
  2. He said he's gonna box them.
  3. JAWS
    JAWS
    The issue is not with the front axle as it is forged and over engineered anyway.
    The bones are just hollow thin walled tube, not too thin being almost 3/16", designed for the engineered purpose. Removing small amounts and reinforcing the area around the removed portions is necessary. Removing large amounts as the oblong slots in this case, then the reinforcing boxing plate material must be much thicker to take the extra strain, not to mention the care needed in building and reconstructing/adapting these to the tubes.
    All of this I am sure was previously thought out.
    Just throwing in my BAAAAAAAAA..
  4. vonstripers
    vonstripers
    from france
    today update ,
    i made my new front crossmember ,let's see the pix
  5. vonstripers
    vonstripers
    from france
    here's my small block chevy
    i will post picts of the chassis next week
    enjoy...!
  6. UnsettledParadox
    UnsettledParadox
    the 1st pic you posted is the exact situation where the inner hot rodder woul d have his balls in a vice against the purist. i dont think i have what it takes to hot rod something so complete!!
    am i going to hot rodders hell?!
  7. vonstripers
    vonstripers
    from france
    upgrade pix, the dashboard
    here's my latest shot of the car (a mock up)
  8. vonstripers
    vonstripers
    from france
    the dashboard
    mock up
  9. vonstripers
    vonstripers
    from france
  10. lockwoodkustoms
    lockwoodkustoms
    I am curious about your cross member?. Does the spring have any movement in a relaxed state? When you jack the car up does the spring bottom out on the cross member? If so I would think this will create a world of shit when driving it.
  11. Von Rigg Fink
    Von Rigg Fink
    from Garage
    sweet , keep on keeping on
  12. Kerrynzl
    Kerrynzl
    I had a good look at your axle and bones, from an engineering perspective they are OK as is.
    The slots in the axle do not affect bending [beaming] strength much, if the axle wants to bend, the bottom edge wants to stretch and the top edge wants to compress [ or kink ]
    If you slotted between where the bones mount and the kingpins ,this would be dangerous [never do that] because the axle tries to parallelogram itself under load.
    The bones are also OK because they have an oval section and you only slotted the sides [ the top and bottom still have their structural integrity for tension and compression ]
    You will have some bending loads under "brake torque" which will try to compress the bottom edge.
    Do not mount the spring shackles on the bones suicide style [especially behind the first slot ] the first major bump and the bones will try and bend like a parallelogram.
    I hope this helps clear up a few doubts. [ I will be comfortable doing the same mods on an anglia front end for a vintage styled racer ]
  13. vonstripers
    vonstripers
    from france
    i will try to post more pix this week ........!
    more details from the front end.
  14. El KaMiNo KiD
    El KaMiNo KiD
    i'm scratching my head on that crossmember...that dash is pretty kool...different...that engine cleaned up nicely..
  15. Automotive Stud
    Automotive Stud
    I think you've got a mismatch of styles going on. Wire wheels and wide whites don't seem to match the broken low stance and dual quad chevy in my book.
  16. vonstripers
    vonstripers
    from france
    no wire wheels ,i put a 16" steelies set on it, watch my last pix of the mock up...!
    the car will be higher from the ground and will have a little rake, no more than 1".
  17. drflex
    drflex
  18. vonstripers
    vonstripers
    from france
  19. El KaMiNo KiD
    El KaMiNo KiD
    still scratching...i know the guys at pinkees are pros, but does it limit suspension travel?..and what do you gain by having the spring over the crossmember?..
  20. DirtyWoody28
    DirtyWoody28
    yeah, engineering basics arches, and circles are good for structure but slots definatly are not. You might get by with the wishbones being slotted as long as they have been filled, but the axle is definetly toast.
  21. shinysideup
    shinysideup
    from ruskin, fl
    You certainly have "wasted" your parts. After seeing your axle/wishbone/crossmember I gotta wonder if you are hittin on all cylinders?
  22. lockwoodkustoms
    lockwoodkustoms
    That cross member and spring have to hit when the car comes back up on it's travel. I just looked at the Pinkees web site and I and baffled as to how this thing can function correctly with out causing damage to the spring.
  23. Crease
    Crease
    Dash and 15s maybe, Kelseys and a stock dash yes, dash and Kelseys dont really go together IMHO.
    Just saw the mock up, that works for me :)...
  24. drflex
    drflex
    don't know how it performs but heres another version built by salt flat speed shop
    http://www.saltflatsspeedshop.com/sf32.html
  25. El KaMiNo KiD
    El KaMiNo KiD
    the crossmembers look a bit different..pinkees and vonstripers spring is sitting directly on top of the crossmember...the salt flats ss. project has some room for the spring to travel...i mean its gotta work right if pinkees sells it?..
  26. the vonstripers
    the vonstripers
    from france
    some news:
    the exhaust
    and the alternator braket
    the bomber seats and brakets
    and the aluminum doors panels and the shifter
    next steps the chopped 28 grill shell
  27. 29hammeredcoupe
    29hammeredcoupe
    from minnesota
    Looks like a coupe from the "Rufus Ranch".
  28. mart3406
    mart3406
    from Canada
    Re the slots cut in the axle compared to
    round holes - it's not merely a matter of
    "taste" and personal preference. it's a
    matter of safety and common sense and
    of basic engineering, metaliurgy and the
    laws of physics!! Compared to just drilling
    some round lightening holes in the axle.
    those slots have severely weakened it and
    it will almost certainly break. It's your car
    and your neck and your "taste", but I hope
    you don't take out anybody else who's
    unfortunate enough to be on the same road
    as you *when* your "cool" front axle lets go
    on you.
    Mart3406
  29. BOWTIE BROWN
    BOWTIE BROWN
    you are to far away to come over & punch me , but , that dash really sucks man .
    keep us posted.
  30. madgrinder
    madgrinder
    huh... while you guys are busy arguing about all his parts, he's getting closer and closer to driving.
