Technical Water Dripping
Discussion in 'The Hokey Ass Message Board' started by steveleb, Jun 6, 2022.
  1. steveleb
    steveleb
    from in a house
    Why would water drip from one side of the exhaust pipe? Dual exhaust no crossover.
  2. WhyW8
    WhyW8
    from Sun City
    no white smoke? probably just Condensation.
  3. steveleb
    steveleb
    from in a house
    On only one side of the engine? Car has been sitting idle for a week.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Where was the car parked.
  5. Heat riser valve on one side, maybe?
    X-cpe and Johnny Gee like this.
  6. steveleb
    steveleb
    from in a house
    In the garage 85 degrees and no heat riser
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Dual plane or single plane intake.
  8. 19Fordy
    19Fordy
    Perhaps the "no drip" side has the water settling in the exhaust pipe or muffler due to an uneven surface.
    Almostdone and lippy like this.
  9. Stand back, it's about to have a baby in the very near future :D
    The exact same thing happened to my wife ;)
    SEAAIRE354, 427 sleeper, fauj and 9 others like this.
  10. Drive it 'till it's warmed up and see if it still does it. Only one side is a bit concerning but maybe one side drains and the other doesn't. I suppose you may have a bad head gasket or a cracked head (or worse), but it's too early to tell for sure and tough to know from here. :)
  11. jimmy six
    jimmy six
    If it has no smell and clear drill a 1/8” hole in the rear edge of the muffler at the lowest point… then the condensation will be under the car and you won’t see it:).
    427 sleeper, fauj, VANDENPLAS and 2 others like this.
  12. Maybe that side is burning so clean it's only emitting H2O, and no CO2
    427 sleeper and guthriesmith like this.
  13. trollst
    trollst
    It's magic
    '28phonebooth likes this.
  14. v8flat44
    v8flat44
    Got bubbles in the radiator? Probably condensation....
  15. tomcat11
    tomcat11
    Is your water/coolant level dropping? If not its most likely just condensation. The 1/8" drain holes are always a good idea and will extend the life of the exhaust components. Try parking in the garage 180 deg. out from how your parking now and see if it switches sides. Variations in air flow and temperature gradients can do weird things.
    jimmy six likes this.
