water in carbs
Discussion in 'The Hokey Ass Message Board' started by 1929rats, Aug 3, 2008.
  1. 1929rats
    1929rats
    Im sure someone wrote this before, I did a search, but I didnt see anything dead on.
    Came home today from a meet in NH, and parked my hot rod outside in front of my garage....went in real quick to watch the weather and fell asleep. I am the only one around, and I awoke to a down pour!
    Got water in my carbs (rochester 2gc's). .....still cant believe I did this....:confused:
    drained the bowls of each carb and put in dry gas in the tank, blew out the line.....changed the distributor from points to petronix a while back,
    so that wasnt a big worry, but its running like sh*t now.....
    am I missing something?
  2. jimmyv
    jimmyv
    Did you check inside the dist cap to see if it's wet?
  3. rustyford40
    rustyford40
    from Mass Bay
    Check the oil if you see water droplets on the dip stick chang the oil and filter. If no water shows start it up an let it run. The heat from running will dry it out.
  4. 1929rats
    1929rats
    yup I did, I even dropped the oil, but, ya know what.....
    Shes outside running mint now.....maybe I was too anxious.....
