Hot Rods Water in my cast iron power glide fluid
Discussion in 'The Hokey Ass Message Board' started by drumyn29, Feb 3, 2024.
  1. drumyn29
    drumyn29
    I have flushed it a few times and it still struggles to get into gear, hit and miss. Is there any affordable way too resolve this issue?
    tractorguy likes this.
  2. 427 sleeper
    427 sleeper
    Is the cooler in the radiator or is it remote? If it's in the radiator, that might be the problem, it's cracked. When you pull the dipstick, does it look like a milkshake?
  3. drumyn29
    drumyn29
    Yep, it came from the radiator and it was milk shake.
    I disconnected the hoses from the radiator and ran new fluid twice but I think it gave up the ghost!
    SS327 likes this.
  4. 427 sleeper
    427 sleeper
    Pull it, clean it out, replace the rubber seal's, and stuff it back in. Everything else is futile. Milkshake's ****... unless they come from an ice cream shop!
    67drake likes this.
  5. X38
    X38
    Water has a negative effect on friction materials.
  6. gene-koning
    gene-koning
    The word I got (when I got water into my modern automatic transmission) was that the water breaks down the glue that holds the friction material to the steel plates and bands. The only fix is to replace all of the friction parts that were originally bonded to steel. If the bond has not failed yet, it will shortly. once the water made contact with the bonding agent, the process has started.
  7. X38
    X38
    Correct.
    61Cruiser and VANDENPLAS like this.
  8. drumyn29
    drumyn29
    Well, that's what I thought and you just confirmed it. Thanks guys.
  9. This! I’ve done dozens of trannies for this exact reason .
    Volkswagen was notorious for this in the 90’s with their “Autotragic” transmissions . Bottom of the trans looked like overcooked oatmeal when you pulled it apart .
  10. 1320 Fan
    1320 Fan
    X38 is correct. The lined plates will disintegrate. The rust is starting so get it apart as soon as possible if you plan to save it.
  11. jaracer
    jaracer
    Short answer: no. It has to come out and be rebuilt with all new seals and friction material. You need to make sure that your rebuilder has done a cast iron Powerglide. They are a beast mainly because all the part are so heavy and you have to align a bunch of things when you go back together.
    61Cruiser likes this.
  12. 61Cruiser
    61Cruiser
    Maybe a good time to update to an aluminium powerglide?
    bobss396 and Davesblue50 like this.
  13. bobss396
    bobss396
    My left nut still aches when I hear the term "cast iron PG"...
    427 sleeper, drumyn29 and SS327 like this.
  14. HEATHEN
    HEATHEN
    from SIDNEY, NY
    If it's a 235, that's not going to work. If it's a V8, and I was going to change to a different transmission, I'd go with something better than a Powerglide.
    427 sleeper likes this.
