Technical Water neck question
Discussion in 'The Hokey Ass Message Board' started by mhirscher, Feb 9, 2026.
  1. mhirscher
    mhirscher
    from WI
    I think my water neck was leaking a bit. Took it off and the o-ring is a bit rough looking. I have one of these aluminum rubber gaskets. Can I just pull out that o-ring and replace it with that gasket or is the seal compromised due to the neck's o-ring design? Thanks!
  2. 19Eddy30
    19Eddy30
    from VA
    Should be able to,,
    Check straightness of the thermostat housing with a file to make sure it's close to being flat no more the
    Like .005
    You just snug tight bolts like 15ish ft pds
  3. RodStRace
    RodStRace
    SBC?
    O-ring is not OE style, is the neck designed for one?
    If you can't find a replacement o-ring for your neck, the one shown should still provide a seal.
    The sealing surface is a full 360 circle that is roughly 3/8" diameter. A small gap around this should still allow a seal inside and outside this groove for the o-ring.
    Hot rodders are always mixing and matching parts, but you gotta take into account what the differences are and how they stack up. Just look at where everything aligns.
    You can use a sealer to 'fill' that o-ring groove, too.
    Is your intake surface also different?
    mhirscher and chryslerfan55 like this.
  4. If it's one of the cheesy chrome thermostat housings, throw it away. I had one, filed it flat a few times, but the metal was so soft (I say metal, but mean whatever it was made of), merely snugging the bolts back up against the rubber o-ring was enough to introduce more warping.
  5. 19Eddy30
    19Eddy30
    from VA
    @anothercarguy
    Cheap chrome the reason is it bows
    Because cheap & O ring in center so when you tighten it bows ,, Better choice
    What Op shown , or use full gasket
    If you have a option get a Oem or
    Good Quality
  6. mhirscher
    mhirscher
    from WI
    Thanks for the help! It is a chrome neck. I too have read that they are cheap and prone to fail. Sounds like I should get an OEM one. I have an aluminum intake as well.
    lothiandon1940 likes this.
  7. 19Eddy30
    19Eddy30
    from VA
    Your Intake more likely good quality aluminum versus thermostat housing.
    Not all Chrome have issues
    But if it like $ 15 new its cheap one.
    Yes the do Decay / rot ..
    Leaking when New is because it bows when tightening or over tightening & the O rig it bows Cheap non Billet ones
    mad mikey likes this.
  8. The only thing those cheap chrome jobs are good for is keeping a bit of coolant in while you look for a cast iron housing.
    mhirscher and lothiandon1940 like this.
  9. RodStRace
    RodStRace
  10. woodiewagon46
    woodiewagon46
    from New York
    There are two types of thermostat housings I know of, one is die-cast and the other is aluminum. I have replaced two of the die-cast because they developed pin holes because of galvanic action. I now have the aluminum on both my cars and haven't had an issue since. I also had issues with the gasket you picture and took the thermostat housing off my car, cleaned it up and reinstalled it and had a leak a month later. I now use a stock type gasket and have had zero leaks on over a year.
    mhirscher likes this.
  11. deathrowdave
    deathrowdave
    from NKy
    GM sold gaskets with silicone raised face seal similar to oring at one time . All I would use in my GM tinkering days
  12. mhirscher
    mhirscher
    from WI
    O-ring + standard "paper"/Fel-pro gasket or O-ring only mated to manifold? Maybe less is more in this situation?
  13. Captain Chaos
    Captain Chaos
    from Missery
    main thing is not to over torque it , I dont use the Oring on cheap ones, I fill that groove with rtv or epoxy , cut it flat and use normal gasket with brush tac , not rtv for final ***embly
    mhirscher and Paul B like this.
