Technical Water neck question
Discussion in 'Traditional Hot Rods' started by mhirscher, Feb 9, 2026.
  1. mhirscher
    mhirscher
    from WI
    I think my water neck was leaking a bit. Took it off and the o-ring is a bit rough looking. I have one of these aluminum rubber gaskets. Can I just pull out that o-ring and replace it with that gasket or is the seal compromised due to the neck's o-ring design? Thanks!
  2. 3blapcam
    3blapcam
    Lots of unknowns in this post. Sure, swap it for a regular gasket. Add some RTV, it'll seal up. Good luck!
    3blap.
  3. 19Eddy30
    19Eddy30
    from VA
    Two threads today same questions
    Yes that gasket should work
    Make sure straight with file
    Snug torque about 15 ft pds
  4. leon bee
    leon bee
    A little 3Bond wiped on there fix it.
  5. squirrel
    I'd replace it with a stock type neck that does not use an O ring.
    saltflats likes this.
  6. woodiewagon46
    woodiewagon46
    from New York
    There are two types of thermostat housings available, a die cast housing and an aluminum one. The die cast one lasted about a year on my car because of dis-similar metal corrosion. I changed to the all aluminum and it has lasted several years now. The zinc in the die cast housing was the problem. I now use a sacrificial anode radiator cap. Check your housing and make sure it's not being eaten away. I have also found the gasket as you show to be prone to leaking.
  7. 19Eddy30
    19Eddy30
    from VA
    We do not know witch O ring thermostat housing Op has , I have cheap,
    Good Quality
    Billet
    Oem that uses O ring
    & some thermostat that use O rings gasket on thermostat.
    I'm ***uming he's working on Gm but it could be what Mopar Ford ect
