Projects Water Pump Problem
Discussion in 'The Hokey Ass Message Board' started by F-ONE, Jul 31, 2008.
  1. F-ONE
    F-ONE
    from Alabama
    I'm having a problem with putting the flathead back in my F-1. The engine is the original R code truck block but it was ran in my 50 Coupe. The problem I have now is since the engine was in the car, it has the narrow pulleys. All the F-1 water pumps use the wide pulleys. The engine is set up for a car so the Generator, crank, fan and water pumps all use the narrow belt.
    The simple solution would be an early or F-1 water pump with the mounting ears and narrow pulley. Apparently there is no such animal. The local shop told me it is nearly imposible to simply change out pulleys without breaking them.
    Any suggestions?
    Thanks
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    You could have the pumps rebuilt to high pressure and have the pump pulleys changed out then. You could also change the crank pulley and generator pulley to the wide style. A tractor parts supply will have a wide pulley for your generator.
  3. Flat Ernie
    Flat Ernie
    Tech Editor
    Don't the late Merc pumps have ears & narrow pullies? IIRC, the mounting ears are higher up on the pump body, but they're there...
  4. JohnEvans
    JohnEvans
    from Phoenix AZ
    Try 50-51 Merc pumps for ears and narrow belt. May need a spacer on the mount to get the correct height.
  5. F-ONE
    F-ONE
    from Alabama
    Eureka!!!
    The Mercury pump and some shims are the solution.
    Thanks
