Technical Water pump question
Discussion in 'The Hokey Ass Message Board' started by 5632, Mar 31, 2015.
  1. 5632
    5632
    I have had another FlowKooler water pump go bad and I am replacing it with a different brand. My question is does the plate that they pop rivet to the impeller really improve anything? Should I attach it to the new pump?
  2. I'm interested in the response too.........
  3. seb fontana
    seb fontana
    from ct
    Yes it does something, and if you have the ability to swap do so..Stock type impellers tend to cavitate some so the plate helps to direct water flow so it doesn't re circulate around the impeller blades, hair more efficient..Be sure you have clearence..
  4. Jalopy Joker
    Jalopy Joker
    those plates do help. they are sold separate from their pumps
  5. I would use it on the new water pump. HRP
  6. Gman0046
    Gman0046
    The plate is the only difference between a Flowcooler and the others. I'd put the plate on your new pump.
  7. tommy
    tommy
    Never used anything but the factory pump for the engine. No risers, no gimmicks, just factory water pumps. Never had an over heating problem!
  8. Lee Chamberlain
    Lee Chamberlain
    Its billet aluminum.
