Water pump risers need help locating zips etc
Discussion in 'Off Topic Hot Rods & Customs' started by Haileyp10142, Jul 14, 2025.
  1. Haileyp10142
    Haileyp10142
    IMG_2105.png IMG_2102.png Hello looks like zips and vintage air water pump risers are no longer available is there anyone else that makes a similar set up for sbc? Thanks
  2. 19Eddy30
    19Eddy30
    from VA
    I wonder If the reason so many parts are going away is of All Brands have moved to Ls ,Coyotes ,Mopar new gen engines
    John Drakulic Was Zipp's
    I talked to John maybe 10 years ago , I believe then in late 70s 80ish
    John was still active @ that time in pouring / casting & will to make
    Custom parts @ Johns location .
    412 Area code Pa ?
    I have a few Zipp's Even on a Vortec sbc
    Its been some time , Back in 80s I seen
    Cast iron ones on Tall deck 366/427 bbc
    & sbc , I believe they had Gm part #s
    Cast iron ones ?
    Haileyp10142 likes this.
  3. HOTRODPRIMER
    HOTRODPRIMER
  4. A Boner
    A Boner
    $355.00 I guess!
  5. scrap metal 48
    scrap metal 48
    I know I'll get some ****, but if you raise the engine where it should be, you won't need the riser....
    Just Gary likes this.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That’s fine if you want your transmission beside you.
    Haileyp10142 and 19Eddy30 like this.
  7. Haileyp10142
    Haileyp10142
    Bought that last two from Pete and Jake’s thanks everyone for your help
  8. scrap metal 48
    scrap metal 48
    bare metal 29 005.JPG new motor in coupe 002.JPG MR 800 for sale 012.JPG Hey Johnny Gee; Both your 56 and 57 Chevys had v8s with the fan centered in the radiator and no need for a Zipp's water pump riser.. Why people are mounting the engines so low just makes me wonder.. no disrespect to anyone that does, it just makes me wonder.. In all my model A builds on super thin sidewall model A frames, I had no problem using a regular water pump and a small hump in the floor..**clic pic
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Are Tri Fives built like early Fords from the factory?
    19Eddy30 likes this.
  10. scrap metal 48
    scrap metal 48
    Whatever.. just trying to say Zipps are usually not necessary in engine is installed correctly.....
  11. 19Eddy30
    19Eddy30
    from VA
    For me With 14 double D in A & 32 I need all the feet room I can get .
    @Just Gary when seen one of my car's for first time asked where was my Loud Pedal was, Did not see , I told Gary its in there its high & I pick up my foot this is why.
    In my Blown Alt Ch***is Hand brake even with
    Wrestling shoes & Funny car boots was tight , there was times I just Fire Socks
    & boots
  12. Just Gary
    Just Gary
    Yeah- big feet & big trans tunnels due to high mounted engines takes measuring & planning.
    Glad you were able to find a riser.
  13. ALLDONE
    ALLDONE
    come on man,,,,
    in this pic... even with the little fan out of your wifes hair dryer... it only pulls from the very botttom of the rad... try that in 120 degree vegas heat...
    jimmy six and 19Eddy30 like this.
  14. ALLDONE
    ALLDONE
    I just ordered one from there... they didn't say they were sold out????
  15. 19Eddy30
    19Eddy30
    from VA
    Notice that few days ago , Small Fan & low .
    Thats why I posted Big Feet .
    I think the reason some get away with because where there temp gauge is ,
    Close to Stock engine & it's in a cooler spot Just like what @Wanderlust
    Posted on another thread , had that book around 1986 ish in my teens .
    Other spots temps can be 300 plus ,
    Now what I do not Quite understand when temps get that hot , was Smokey
    Experimenting with like 30 or so psi cap & antifreeze ? Witch raises boiling point,
    Water starts to boil @ 215 deg .
    Maybe @ALLDONE can answer,
    I am just pulling some memories without actually refreshing exact numbers / theory .
    The Riser , Seem to be no longer made
    Since the thread started I was going to get another one just to have , when I purchased the last one I think it was less than $200,, Just in last week I was asked if I had one 4 sale , The persons said could not find instock , my self I have not talked direct , just looking on line seeing out of stock .
    Like @s**** metal 48 , I Also I can say I had one of those cheap ( mine was)
    Aluminum $130 rads with No heating issues , with Zip ,
    I prefer no electric fan, my 2 engine's different cid
    both in 650 plus range ,
    One Close to 12.1
    Other 10.3
  16. ALLDONE
    ALLDONE
    but wait.... there's more... no engine to pump by p*** hose...thats good for a few degrees,,,
  17. 19Eddy30
    19Eddy30
    from VA
    Also Just wondering and thinking
    On Book cover of Engine has heads taped
    But has Rad hose @ intake
    If cooling on race engine better /needed
    @ heads end .
    I wonder if there is a divider in thermostat pocket .
  18. ALLDONE
    ALLDONE
  19. scrap metal 48
    scrap metal 48
    ALLDONE, in your Thread above in your 2nd paragraph you stated what I've been saying; ENGINE IS SET TO LOW... All I've been trying to say is that!! If more thought was put into engine mounting maybe a zip's riser wouldn't be necessary.. I also read at all the modification that needed to be done to get the riser to work... It's all hot rodding..
  20. scrap metal 48
    scrap metal 48
    3 more, no riser...**clic pic** July sedan 012.JPG engine 002.JPG for sale pics II 007.JPG
  21. 19Eddy30
    19Eddy30
    from VA
    pic of tunnel on inside ,
    Coupe , roadster ,truck or sedan,
    Engine are higher then most,
    Stock engine by carbs ,
    No issues with Zip installation only on a Vortec block 1/16 to 1/8 to clear timing cover @ top @ angle
    There are many that are running hotter then they know because most install temp up near thermostat cooler then temps in near back
  22. scrap metal 48
    scrap metal 48
    **clic pic** for sale pics II 003.JPG bare metal 29 005.JPG July sedan 010.JPG
  23. 19Eddy30
    19Eddy30
    from VA
    @s**** metal 48 ,
    I don not Know why by pics why there seem not to be that much of hump in floor ,I have not done a 28-29
    only
    30-32, the As should be same @ tunnel.
    My Feet are big close to 6 inch wide with out shoe,
    Also thinking I have not ran a stockish
    SBC , all mine have been siamese cylinders ,& I pull / get temps between
    6-8 & 5-7 witch is hotter Area by 20-30 deg then @ thermostat , cid 406 -434 sb
    witch most are not using in A's 32.
    I know there is different for hotter temps, & @ thermostat cooler than rear of engine .
    So stockish engines might not need the Zip until up near 400 hp plus ,
    Unless carb to lean , wrong timing ,
    Wrong pulley ratio, to small of Rad , Fan
    Ext .
    Maybe more information then Most
    Rodders need / know ,
    Cooling on GM first Gen sb , Bb has been issue from beginning,
    Unbalance cooling across cylinders,
    The SB2 Solve these issues ,
    scrap metal 48 and jimmy six like this.
  24. scrap metal 48
    scrap metal 48
    Motors are well used, low horsepower, even 2 barrel carbs...
  25. ALLDONE
    ALLDONE
  26. ALLDONE
    ALLDONE
    some one went blabbing on the web about how good they work... now they are all sold...
  27. ALLDONE
    ALLDONE
    you probley don't even need a water pump
    Weather history for Dayton, Ohio
    Temperature
    Rain
    Snow
    July
    84 / 64
    °F
    C
    Average temperature
    Record temps
    Avg rainfall
    Snow
    103° / 51° F
    4.39 in
    0 days
    20406080
    JanFebMarAprMayJunJulAugSepOctNovDec
  28. ALLDONE
    ALLDONE
    What's the Hottest Month in Dayton?
    In Dayton, Ohio, the warmest month is July, with an average daily high temperature of 84.5 °F and an average low of 65.0 °F.
  29. ALLDONE
    ALLDONE
    we never used to use zips before they came out.. and then only on ones that needed...my woody has a 462 hp motor... liked to run hot setting at a light... but once it started getting hot it like to stay there... so needed more fan...in utah... it barely gets hot enough to open the stat..
