Technical Water pump test
Discussion in 'The Hokey Ass Message Board' started by johnfin, Aug 15, 2025.
  1. johnfin
    johnfin
    from Florida
    Is there a way to test water pumps. When they go bad do they always leak out the weep hole?
  2. squirrel
    Normal failures are the bearing going bad, and the seal going bad. Noise and fan looseness and leaking out the weep hole are the usual symptoms.
    Occasionally other things happen, such as the impeller loose on the shaft, or rust holes causing leaks.
    winduptoy and Tim like this.
  3. studebakerjoe
    studebakerjoe
    I've seen blades on the impeller wear or break apart to the point they can't really pump anymore.
    winduptoy and squirrel like this.
  4. BJR
    BJR
    I had one where it had a plastic impeller that came loose from the shaft. It was on a Y block.
  5. winduptoy
    winduptoy
    on a cast impeller, it can rust and corrode/erode to the point that the pump looses its efficiency....
    I had a old 6 cylinder, 216 Chevrolet that would get hot...it had a cast impeller that was really rusted thin.
    Ordered a "new" replacement pump and the off shore maker had copied/patterned a compromised impeller for the new casting...it wasn't any better than the roached one that was already on the engine....I finally found a NOS one and the difference in the impellers was dramatic and this pump helped the cooling immensely....
    studebakerjoe and squirrel like this.
  6. distributorguy
    distributorguy
    from MN
    Besides all the info above, you can visually see in many cars (once the thermostat opens) if water is circulating rapidly though the radiator rather than just moving with convection. Its pretty obvious.
    FlowKooler sells a disc you could rivet to the back of an open water pump impeller to allow it to push more water. Its simple and easy to replicate, and they work quite well!
    3500-01 was the part number but it appears to have been eliminated when all the new CNC aluminum pump vanes came onto the market. You can still find the images on google.
    winduptoy likes this.
