Hot Rods Water temp pickup
Discussion in 'The Hokey Ass Message Board' started by hounddogjake, Aug 11, 2018.
  1. hounddogjake
    hounddogjake
    I’ve got a Buick 350ci and looking for a way to hook up a thermostat fan switch. I’ve got one opening on the intake and I’m using it for a temp gauge. Any ideas ?
  2. squirrel
    you could buy a thingy that fits in the upper hose. Or a thingy that pokes into the radiator fins.
    hrm2k likes this.
  3. bobss396
    bobss396
    Not an expert on the Buick 350 head, the cylinder head may be a better place if there is a capped off hole to use.
  4. chevy57dude
    chevy57dude
    Used a thermostat housing with a NPT tapped hole for my temperature gauge sender. Possibly a similar one is available for the Buick.
    I did use one of the push it through the fins thingies for my fans. It works well. Still put an override switch on 'em in case it fails.
  5. goldmountain
    goldmountain
    Solder a 1/2" npt fitting into the bottom rad tank.
    Sent from my SM-T350 using The H.A.M.B. mobile app
    egads and olscrounger like this.
