WATERPROOFING
Discussion in 'Off Topic Hot Rods & Customs' started by Bandit Billy, Jul 9, 2024.
  1. Bandit Billy
    Bandit Billy
    I am working on my daughter OT 4x4. These things are notorious for leaking up under the dash. The cowl vent is seam sealed on both sides but after 40 years, no longer holding water. The area is extremely hard to reach even with the access plugs out and wiper motor removed.
    So here's the query. She furnished a gallon of POR15 bed liner for me to spray in the bed. My Schutz gun has a 36" flex hose attachment for shooting inside frame rails. What if I hosed that POR15 bed liner inside the cowl area that is leaking water into the cab? Do you think it will seal it? I don't want to make a bigger mess in an area I cannot easily access. Yea or Nea!
    Jeff Bohmann likes this.
  2. miker98038
    miker98038
    We had a 1 ton van with a man lift bucket on top of it. The roof got badly corroded from acid on a site. After we got that cleaned we didn’t think paint was going to stick. Pinholes, especially around the gutters. We sprayed it with bed liner and it sealed up and lasted for years. But it was an exposed visible surface, we could see what we were doing. Hard to say in your case how big the gaps are.
    29A-V8 and Bandit Billy like this.
  3. Zax
    Zax
    I don't think that will seal it. Does it have a functional cowl vent drain?
    SS327 and Bandit Billy like this.
  4. Flatrod17
    Flatrod17
    If you hose that stuff in and then it don't work and you have to go in there and weld, wouldn't that be a bigger problem? That said, if it were me I would hose it in, and I mean hose it in!
    Landmule, Sharpone and Bandit Billy like this.
  5. Bandit Billy
    Bandit Billy
    I am going to run my scope in there and see what I am dealing with before plunging in. If it looks like hair line fractures this ought to work. If it is bigger, I'll need a better strategy.
    Sharpone likes this.
  6. Is this a Dodge truck by chance?
    Bandit Billy likes this.
  7. rockable
    rockable
    One problem is there is probably lots of surface rust and nothing you spray in there to try to seal it up will have anything to substantially adhere itself to.
  8. Zax
    Zax
    If it is a Jeep the cowl vent should have a drain. These can easily get clogged and cause the water to enter the cab and spill into the floors. I have to clean them out once or twice a year on the Jeeps I own. Some models don't have the best design for the cowl drain and need a little re-engineering.
  9. 6sally6
    6sally6
    According to POR-15......it ADHERES to rust. In fact they recommend you just lightly brush the flaky stuff off and apply their product to the rusty area.
    Billy.....on older Mustangs with a leaky cowl a lotta guys use a removable plastic cover over the cowl grill. When outside or rainy conditions (like PNW !) Remove it when traveling...install when ya park it !
    6sally6
  10. Bandit Billy
    Bandit Billy
    I have a buddy who's 64 1/2 rag top has a rusted out cowl. I'll mention the cowl condom to him, cheaper than chopping out the cowl, welding and paint work.
    No, since this is now in the OT forum it is a 81 SR5 short bed, short cab 4x4 PU. I have spoken to guys that are into these trucks and they say it is most common to have the seam sealer shrunk up inside the vent area and no longer sealing. They talk of making a s**** tool to reach in there and apply new sealer. I was just thinking my fix my be easier, cover better and faster.
    POR15 seems to like rust and humidity. I hope so because her truck bed is covered in surface rust. I plan to wire brush and apply this stuff per the instructions.
    Sharpone and rockable like this.
  11. rockable
    rockable
    Good luck! Let us know how it works out.
  12. rockable
    rockable
    The regular POR 15 does. Don't know about the bedliner. Worth a shot if you can't do better.
  13. Bandit Billy
    Bandit Billy
    The website says the POR15 bedliner is applicable over rusted surfaces once scales and loose bits are removed. I won't be able to clean down in that vent area tho.
  14. rockable
    rockable
    That's what I was afraid of. If the rust flakes off, the POR flakes off with it. If you could s****e the loose stuff off, it would probably adhere for a while.
  15. Roothawg
    Roothawg
    Funny you should mention this. My dad and I built my youngest sister a 66 Mustang, which are notorious for the cowls rusting out. We didn't know that until later. Dad chased leaks like that that forever.
    He went as far as building a Plexiglas cover with weather stripping and quick turn fasteners, for rainy days. It was sold and the cover was still in the trunk....problem never solved.
  16. Bandit Billy
    Bandit Billy
    The only correct fix on a stang is cutting wheel, welding, painting. I thought I had the same issue on the little PU but they thought to add drains and clean out holes in the firewall so you can get to the leaves and debris. My daughter lives on Mt Hood and this truck sees the elements with no indoor storage. I have to seal it up even if it means cutting and welding. I think the bed liner is worth a go first.
  17. Oneball
    Oneball
    You can get spray on leak sealer for house roofs and gutters no idea if it’ll work but might be a better option than bed coatings.
  18. Bandit Billy
    Bandit Billy
    And I have used Flex Seal before and it works great but what they don't seem to make is a spray can with a hose like Eastwood sells for undercoating inside frames. I can't get a can or a paint brush in there. If I bought liquid flex seal, I wonder if it would spray through my schutz gun and hose? Can it be thinned? Hmmm
  19. Oneball
    Oneball
    You can buy them off Amazon eBay etc.
    Just need to decide if youve a male or female connection on the spray can
  20. Dick Stevens
    Dick Stevens
    Rust needs oxygen to continue to grow and POR15 seals it so no oxygen gets to the metal, hence no more rusting, ***uming that you get it covered completely.
    Edit; Clarification on what POR15 does and doesn't do.........it does not neutralize rust, it encapsulates it to prevent any further rusting!
    Sharpone, SS327 and Bandit Billy like this.
  21. Bandit Billy
    Bandit Billy
    You would think by now I would have shoved my inspection camera in there and taken some pics but it like 100 degrees in my garages this week by the time I get home from work. I am not expecting rust though, I am expecting hard , dried up seam sealer that is no longer sealing anything.
    dogwalkin and Sharpone like this.
  22. Before you slather a sealant (think roofing tar, bed liner, etc.) around the trouble spot hoping to cure the problem, give a think to what your next step will be if that doesn't solve the problem. Removing the "solution" material and doing a "cut out and weld-in new" might become a bigger project than if you just take that approach from the get-go. It doesn't sound like your daughter is likely to give up her pride and joy just for a leak, so you can rest ***ured she'll be after to perform a second repair if bedliner (et al) doesn't work.
    Good luck!
  23. Jeff Bohmann
    Jeff Bohmann
    3$ f6
    $7'56'/y'8",,$68¤°8 Oder_"%% 4t=ft
  24. RodStRace
    RodStRace
    Jeff, your dog is posting again!
    I'd try to bottle brush, rag on a rope or something to at least knock down the dirt and leaves in there before spraying, but I don't know the details of access.
    If this is a family heirloom, I'd even consider pulling the HVAC to access, but I know Toys tend to be right in the middle and a lot of work.
    SS327, Sharpone and Bandit Billy like this.
  25. 6sally6
    6sally6
    There's no way to cut out an "inspection hole" in the firewall? Get in there and brush and re-seal and then weld up the said hole ? (go ahead....somebody comment about my said hole !!!!!)
    6sally6
  26. Bandit Billy
    Bandit Billy
    That is a feasible idea. If I can't reach it why not make a better access? I can bolt it in for that matter for the next guy.
    I thought he was swearing at me.
    ekimneirbo, SS327 and Sharpone like this.
  27. Sharpone
    Sharpone
    I think it’s code for good luck:rolleyes:
    ekimneirbo and Bandit Billy like this.
