wax recomendation
Discussion in 'The Hokey Ass Message Board' started by moter, Dec 3, 2009.
  1. Customs&Color
    Customs&Color
    "After 60 days, the vehicle may be waxed" I just read this in the House of Kolor tech manual.
  2. Terry O
    Terry O
  3. Chevy Gasser
    Chevy Gasser
    Wait 90 days. Glazes are not the same as waxes. My local paint shop lays paint so slick they don't usually buff it. If they do buff it they will glaze it as a final step. When it is glazed it will be as slick as it can get. After 3 months you can seal it with wax if you want. Nearly 20 years ago my base coat/clear coat finish looked waxed. I was embar***ed when a guy asked me what wax I used to keep my car so slick. The paint job was nearly 2 years old and I had never waxed it once, just wash, rinse, chamois.
    Basecoat/clearcoat will be too hard to polish by hand but it can be done. Use a machine glaze/swirl remover. 3M, Meguires, Mothers and other make their own version.
  4. moter
    moter
    Thanks guys! Lots of great info.
  5. pastlane
    pastlane
  6. tedley
    tedley
    from canada
    I like the 3m hand glaze to if you like buffing her yup alot. No build up. For wax i like ****een wax or lucas wax is great to.
  7. blinddaddykarno
    blinddaddykarno
    When I worked in the trade, we did a lot of things that are questionable; we drove just finished cars down to the drive thru car wash, (one with the rolling brushes, no less!). We waxed new paint jobs, etc, the point being, just because someone does it (even a pro), doesn't mean it's right!
    Brian
  8. Lowmerc50
    Lowmerc50
    I like race glaze myself
  9. Shifty Shifterton
    Shifty Shifterton
    Glaze is safe for new paints and has higher optical clarity than wax, so indoor show and megabuck paintjob guys tend to prefer it. It also washes off with water. Totally different product than wax even though it applies the same.
  10. 5window
    5window
    Not to be ignorant, just un-educated, but doesn't waxing a car also rub dirt and grime into your paint/finish? Since no wash job would ever fully remove all the surface contaminants, how often can you wax before you effect a deterioration of the fnish?
  11. zman
    zman
    from Garner, NC
    HOK recommends 60 days, we go ahead and say 90 days. Then maybe they'll at least wait 60 days. :D
  12. Shifty Shifterton
    Shifty Shifterton
    You have to sponge wash, not pressure wash. Waxing after pressure wash only will cause problems unless there's a rubdown step like a chamois before waxing.
    Yes the wax will seal in some contaminants, but it will also bond with existing contaminants and when the wax is removed, the contaminant leaves with it. And liquid wax itself is a great solvent, much like bug and tar remover.
