Way OT Build
Discussion in 'Off Topic Hot Rods & Customs' started by wetskier2000, Nov 26, 2025.
  1. wetskier2000
    wetskier2000
    from NH
    Seems a guy in Spain has copied my build design. lol. Although his looks more like the upscale side of the family... Very nice... I specifically didn't want to do anything '57 Chevy cuz it was too recognizable IMHO, but this guy sure has integrated it and made it flow very nicely...
    The black/turquoise one is C6 based. The one below is XLR based.
    chryslerfan55 and JohnLewis like this.
  2. wetskier2000
    wetskier2000
    from NH
    Fenders are home from media blasting... Only a couple minor surprises... "Gee, I didn't know it was porous there....".
    chryslerfan55 and Okie Pete like this.
  3. gene-koning
    gene-koning
    Probably would not had been much left of my 48 Plymouth coupe if it had made a trip to the media blaster. We still put 88,000 miles on it over 15 years (not many the last 3, have a new toy). The car is still road worthy, even though it started out as a pile of rust, and was not media blasted.
  4. wetskier2000
    wetskier2000
    from NH
    Finally back working on Boris... Ended up using a new external relay for the fog lights. I really wanted to use the relay already in the underhood panel, but it just became too convoluted and hacky... I just put a switch on the lower dash for on/off without the former regard to hi/low beams. The fogs can be on any time now. They do shut off with the car however.
    Next, I'm thinking about rewiring the low beams. Right now all 4 headlights are on for hi and low beams, but low beams are pretty dim while hi is pretty decent. I was thinking about using the hi beam filament in just the outer, upper headlights as a low beam, but I don't know the ramifications of essentially having that filament wired to both hi and low. Will I backfeed something I don't want to??
    chryslerfan55, leon bee and Okie Pete like this.
  5. wetskier2000
    wetskier2000
    from NH
    Raised the front of the nose 3/4". A little mudd to hide my mediocre welding skills. Some sanding next then make them red again. I think I'll just rattle can the underside black for now. Eventually, I need to think about inner fenders. Of course, it needs to be drivable for the summer. That might preclude the door work I have planned next.
    wicarnut, Okie Pete and chryslerfan55 like this.
  6. RodStRace
    RodStRace
    On the headlights, GM has done Daytime Running Lights (DRL) for decades now using the high beam filaments in series rather than parallel. Just another possibility. Between various aftermarket bulbs it is probably easier to find the brightness you want without diving into the wiring.
  7. wetskier2000
    wetskier2000
    from NH
    Hmmm.... I kinda thought I'd wired the 1959 turn signals as DRLs. They are on when the key is on as well as the yellow LEDs in the headlights. She liked that so I left it that way...
  8. wetskier2000
    wetskier2000
    from NH
    The genesis of this project.
  9. sweetdick2
    sweetdick2
    from new jersey
    WOW!!! I love that frankinstien !! You'll never have to worry about running into another one! Good for you brother!
  10. wetskier2000
    wetskier2000
    from NH
    Some sanding... will take another round... I so enjoy sanding....
    porkshop likes this.
  11. wetskier2000
    wetskier2000
    from NH
    Pretty sure these 6 yellow lights are wired to the DRL circuit... Car is just sitting there lights off and engine running.
  12. SS327
    SS327
    You gave up that sweet dodge front end for the Chrysler? I’m disappointed.
    HJmaniac likes this.
  13. wetskier2000
    wetskier2000
    from NH
    Yeah, that 1959 Coronet front end is so damn good looking, what was i thinking?!?
    SS327 likes this.
  14. wetskier2000
    wetskier2000
    from NH
    No love on the replacement grill...Sounded really good that it had been inside for the last 30-40 years, but while it was nice and straight and the pot metal was in good shape it had a considerable booger on the upper left of the pot metal surround..
    More sanding... I mudded my ****py door welds. We'll see you that sands out. My thought is that I can run it like that for the summer and see if I get any cracking. Better to find that out before paint.
  15. gene-koning
    gene-koning
    Always more fun to drive it through the summer that to have it parked while doing body work.
    RodStRace likes this.
  16. wetskier2000
    wetskier2000
    from NH
    Finally in red primer. There are still a few little flaws that I'll probably fix... But, no raw, cut edge is pretty nice...
    Boris_Fenders_Primed1.jpg Boris_Fenders_Primed2.jpg Boris_Fenders_Primed3.jpg Boris_Fenders_Primed4.jpg
  17. sweetdick2
    sweetdick2
    from new jersey
    I love the creativeness of stuff like this, BRAVO!!
  18. wetskier2000
    wetskier2000
    from NH
    I need to put a right angle flange on this piece where the blue tape is which will attach the forward area of the door sheet metal to the fibergl*** inner structure. Thought about using my tipping die but a test piece told me no way... I went and talked to my buddy that's probably forgotten more about building hot rods than I will ever know... First he told me the part I'm making is called a return... Second, he says "no problem", he walks over to the vise with a test piece and a hammer and VOILA!! Stupid simple... Now to see if I can do it too.
    SS327 likes this.
  19. gene-koning
    gene-koning
    Might be time to invest in a stretching/shrinking tool. Bend the "L", stretch or shrink the flange to get the curve you need.
    Faster, easier, and more consistent then bending it any other way.
    I spent years contemplating buying that tool, but never bought it, I know how to do it the hard way. Was a friends shop, he had one, i couldn't believe how long I deprived myself of having one, but by then, I was past the need for it.
  20. wicarnut
    wicarnut
    I like it, Very Kool IMO. Admire your skills, ambition and the concept And you Win the Unique award.
  21. wetskier2000
    wetskier2000
    from NH
    Funny you should say that because the same hot rod guy told me when I was building the COE and asked if he'd do some of the work "I'll show you how but it's your truck and you should be doing the work." The piece I was trying to make involved a shrinker/stretcher. So I hung my head and walked into HF for cheap s/s and learned to use them.
    On this piece, the right angle flange itself is curved like an S. The jaws would flatten that curve. You could shrink/stretch the flat, middle portion and get that curve, but it's blocked by the original flange. The original flange and curve needs to remain the same, it dictates the original 1959 door skin curve.
    First p*** with the hammer came out pretty good. Kinda had to learn how much to whack it and where.. I had trouble hitting the exact right spot so I ended up with the hammer on the line and hitting the hammer.
    TrailerTrashToo likes this.
  22. wetskier2000
    wetskier2000
    from NH
    Took advantage of a warm, dry day here in NH and got some primer on the doors to blend into the rear quarters a little as well as hide my mul***ude of sins.. Back to the returns later this week....
    Boris_Doors_and_fenders_Primed1.jpg Boris_Doors_and_fenders_Primed2.jpg Boris_Doors_and_fenders_Primed3.jpg
  23. wetskier2000
    wetskier2000
    from NH
    A recent JY trip for a replacement grill came up empty... I've been thinking about my current grill. It's in pretty decent shape except for one split where it was hit about halfway up the right vertical portion. I've thought about JB welding it then wrapping with chrome-like stuff as well as actually having it rechromed. I have concern$ about both solutions... I wonder how dumb one of those badges guys put on grills would look there... Obviously, it won't be on the grill, but on the surround. Maybe a nice Dodge Brothers badge?
    wicarnut likes this.
  24. wetskier2000
    wetskier2000
    from NH
    his is what happens when a guy doesn't notice that those holes will not be used. He gets to mudd, sand and prime AGAIN! In his defense, there were no holes in the other fender, the donor car must have had a fender replaced at some time in its life...
  25. b-body-bob
    b-body-bob
    Could be worse, at least it's still in primer. I've got one in paint with a similar but opposite problem - they left holes that I didn't want. (Cancer got in the way of keeping track of it, but I'm back now.) Part of me wants to gob them up with dum-dum on the inside and forget about it.
  26. wetskier2000
    wetskier2000
    from NH
    Cleverly placed piece of trim or emblem maybe??
