Hot Rods WC245 intake question
Discussion in 'The Hokey Ass Message Board' started by babblewon, Jan 8, 2022.
  1. babblewon
    babblewon
    from cali
    Hey guys. Can someone share a photo of a 4x2 inline with direct linkage?
    I have a wc245 with 4 97’s in line with straight linkage. My question is how are you guys hooking up a throttle cable and throttle stop to this setup? I’ve seen the cable plate stromberg sells for a throttle/kick down cable... I’m running a 4 speed so I don’t need the kick down cable deal. Ideally like to run my cable directly from the pedal to the carb somehow like the standard 4 barrel setup. That possible?
    Thanks!
  2. 73RR
    73RR
    If you are using 'straight' linkage to all 4 carbs then all you need is the cable to some point along the linkage.
    If you need to change the leverage of the cable then a bell-crank would be mounted on the manifold and cable attached there.
    Deuces likes this.
  3. babblewon
    babblewon
    from cali
    Thanks for the info.
    I’m thinking get a center carb longer arm and attach a cable to that. Then just make a throttle plate like strombergs that fits my setup better...
