History We ALL Love a DARE! PIX of TRULY Extinct Makes?
Discussion in 'The Hokey Ass Message Board' started by jimi'shemi291, Sep 12, 2009.
  1. jimi'shemi291
    jimi'shemi291
    Thanks to ConceptCarz, here's a fabulous look at an actual 1928 Martin Aerodynamic Model 100 at a Glenmoor Gathering of Significant Automobiles. This was one of three "cars of the future" put forth by James V. Martin, famous for aircraft, from 1928 to 1950. The resemblance to Stout's Scarab seems unmistakable, suggesting Stout was impressed enough to given the visual concept an impressive Art Decco treatment a few years later.
    <LI itxtvisited="1">[​IMG]
    Anybody know what the four-banger with updraft carb is?
  2. Stefan T
    Stefan T
    from Sweden
    Her's pics of Roosevelt
    The Roosevelt was made by Marmon in 1929 to 1930
    /Stefan
  3. jimi'shemi291
    jimi'shemi291
    Note the text of Brisbane news item from late-December
    1932 posted by MrFire. The use of Duralumin, usually used
    for light, strong aircraft, underscores the company's plans
    for a light, monocoque-bodied wind-cheater, whose 80
    horsepower might, then, achieve the attention-getting
    speed of 100. A bit to hope (or boast) for!
    _______________________________________________
    Brisbane Courier, December, 1932
    REAR-ENGINED CAR.
    Streamlined Model.
    An interesting car, a rear-
    engined Bremac, is to make
    its appearance in America shortly.
    The car, which is not intended for
    quan***y production, will be fit-
    ted with a special streamlined
    body. An 80 h.p. eight-cylinder
    enginer is to be used, and it is
    estimated that the power-weight
    ratio will be 33lb. per horse-
    power, which, together with the
    streamlining, will provide a maxi-
    mum speed of over 100 m.p.h. The
    novel body will consist of a series
    of duralumin hooks framed with
    wood and covered with metal.
    __________________________________________________
    Introduced in 1909 "Duralumin" (now an obsolete term) was
    the original name for an aluminum alloy, stronger and lighter
    than aluminum alone. Besides aluminum the alloy includes
    some copper, manganese and magnesium. Relatively quickly,
    its use in rigid dirigibles (Hindenburg included) and airplane
    monocoque fuselages spread from Germany through the world.
  4. jimi'shemi291
    jimi'shemi291
    William Stout's Scarab, 1935
  5. jimi'shemi291
    jimi'shemi291
    Pic of the final evolution of Paul Lewis' 1937 Airomobile,
    thanks to SunRoofCord, who dug for it.
    Photo source: Thanks to FindRareCar.com
    (Hemmings AutoBlogs)
  6. jimi'shemi291
    jimi'shemi291
    <TABLE cellSpacing=1 width=400 bgColor=#ffffff itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD itxtvisited="1">[​IMG]</TD></TR></TBODY></TABLE>
    McQuay-Norris Streamliner, 1934.
    Photos THANKS to Diseno-Art.com!
  7. jimi'shemi291
    jimi'shemi291
    Buckminster Fuller's Dymaxion, 1933.
    Below is a patent drawing of the Dymaxion. Note the driveline.
  8. jimi'shemi291
    jimi'shemi291
    Yup, a REAL Dymaxion, in case anybody thought they all wound up in museums. Doug Gary said his grandfather's bottling company acquired it in Washington, D.C., for ad power. It was driven to Charlotte, NC, where it eventually burned up after its driver forgot and left the gas cap off after a fill-up. HAMBer Mazooma provided the link to most of these Dymaxion photos. THANKS!
  9. jimi'shemi291
    jimi'shemi291
    The Starliner was a one-off teardrop car created by Robert Gouge
    of Bay City, MI, in 1935. Amazingly, it survives, though new owner,
    Geoff Hacker of Tampa, FL, has work to do in bringing it back.
    The dorsal fin originally was taller
    and went further up, Geoff says.
    Geoff with his dream car
  10. jimi'shemi291
    jimi'shemi291
    Unnamed four-wheel vehicle, model only, 1934 by industrial designer Norman Bel Geddes.
    Norman Bel Geddes, 1893-1958, paved the design
    thought path for others whose names are better
    remembered today than his own.
  11. jimi'shemi291
    jimi'shemi291
    Bel Geddes flying car, 1945
    [SIZE=-1]Double-decker airliner, Bel Geddes with Otto Koller, 1929[/SIZE]​
  12. SUNROOFCORD
    SUNROOFCORD
    Vintage Dream Car Pictures
    1. 1951 Buick Lesabre
    2. 1954 Cadillac Park Avenue
    3. 1955 LaSalle Sports Coupe
    4. 1956 Buick Centurion
    5. 1956 Chevrolet Impala
  13. jimi'shemi291
    jimi'shemi291
    Sheesh, Jim, EVERY one of these shots is just amazing -- several of which I have NOT seen before! But for the obvious "show" windshield/roof, this '56 Impala is pretty darn amazing!
  14. SUNROOFCORD
    SUNROOFCORD
    Ford Fairmont Durango
    For the 1978 model year, General Motors introduced the downsized A-body platform, and with it, the downsized El Camino. Ford’s financial condition had been weakened, and its mid-sized platform held out through the 1979 LTD II. Ford had not prepared a proper Ranchero replacement. As a last attempt to capture some of the car-based truck market, Ford looked to Gardena, California-based National Coach Corporation for help. Primarily an airport-limo converter, National Coach took the Ford Fairmont Futura sporty coupe, removed the bodywork aft of the thick B-pillar, and crafted a fibergl*** cargo bed in its place. The body lines of the Futura, including the rear panel reconfigured into a tailgate, seemed pre-designed for conversion into a pickup. The whole package only added 50 pounds in the transformation. The new model was dubbed Durango.
    Built in 1980 and 1981, the Durango’s production numbers range from a low estimate of 80 to high estimates of 210 or 220. With prices in the $9,000 range, the Durango held a $2,500 premium over the standard Fairmont. The Fairmont ended production in 1983, and National Coach closed its doors around 1990.
    I don't think I've ever seen one before.
  15. jimi'shemi291
    jimi'shemi291
    Man, me either, SunRoof. It's fun when something I wasn't even aware of at the time just drops out of the sky! THANKS, buddy.
  16. jimi'shemi291
    jimi'shemi291
    Before we totally leave the mid-'20s to mid-'40s teardrop cars, I want to show Paul lewis' '37 Lewis Aeromobile, BEFORE the headlights got fared into the fenders! Never a beauty-contest winner the Aeromobile looked a hell of a lot better with a little cosmetic work, eh?
  17. jimi'shemi291
    jimi'shemi291
    Okay, so who doesn't like "swoopy" sports cars -- especially
    when they were ahead of their time??? Made ONLY in 1959,
    the Asardo was made, of all places, in North bergen, NJ. Asardo
    is an acronym standing for American Special Automotive Research
    & Design Corporation. The Asardo 1500 AR-S was powered by
    1485cc 135bhp Alfa Romwo Giulia 1300 engine. It featured
    gull-wing doors and also had Alfa Romeo transmission and rear
    suspension. This only prototype was later refitted with a 3528cc
    Buick V-8 engine. For these wonderful and exciting pix of this
    super-rare machine, my sincere thanks to findrarecar.com.
    Actual photography is credited to yclasicos.com and
    motorpasion.com.
  18. SUNROOFCORD
    SUNROOFCORD
    Courtesy of Daniel Strohl, Hemmings Cl***ic Car
    For all the streamliners and teardroppers sketched out, put into clay and prototyped, very few successfully became the car of the future that they claimed to be. But they sure made for excellent copy for the newspapers and mechanics magazines of the day, and David Greenlees recently came across a small treasure trove of streamliners in press photographs, few of which have been seen until now. Fortunately, he knew these were right up our alley and forwarded them on to us.
    First up, the Dan LaLee car The photos all date from February 10, 1938, and depict LaLee, along with Jack Knight of United Air Lines and model Betty Bryant, showing off the retractable in or around Dearborn, Michigan.
    A couple of the photo descriptions include the word “rebuilt” and those wheels appear to come from an earlier Ford, so we can presume LaLee used a ch***is from a wrecked car on which to base his retractable.
  19. SUNROOFCORD
    SUNROOFCORD
    Raymond Loewy streamliner rendering courtesy of Daniel Strohl. Raymond Loewy penned this , dated January 1938, and described it as &#8220;a model of the automobile of the future, with its engine in the rear.&#8221;
  20. SUNROOFCORD
    SUNROOFCORD
    Walter Teague streamliner rendering courtesy of Daniel Strohl.This one comes from Walter Dorwin Teague, and was used around March 1940 to promote Teague&#8217;s book, &#8220;Design This Way Day: The Technique of Order in the Machine Age.&#8221; This rendering is described as &#8220;the rear-engined, teardrop car of tomorrow&#8230; designed by Mr. Teague and Walter Dorwin Teague, Jr., features clear vision, extra seating capacity, built-in bumpers and airflow form.&#8221;
  21. SUNROOFCORD
    SUNROOFCORD
    Frank Spring streamliner, courtesy of Daniel Strohl. This tadpole-configured model, dated March 1944, is credited to Frank Spring, who intended to combine &#8220;maximum streamlining with practical considerations.&#8221; Of course, everybody but Spring had designed their streamliners to be as impractical as possible&#8230;
  22. swi66
    swi66
    Libby Body Riley Head car
  23. SUNROOFCORD
    SUNROOFCORD
    Alberto Gorgoni-designed rhomboid-type streamliner courtesy of Daniel Strohl.
  24. SUNROOFCORD
    SUNROOFCORD
    Unidentified streamliner, courtesy of Daniel Stohl
  25. SUNROOFCORD
    SUNROOFCORD
    In the history of streamlining and teardrop cars, you can’t overlook Emile Claveau, who, as Lord K recently wrote on Dieselpunks, helped bridge the gap between the early efforts to produce an aerodynamic car in the 1920s and later production efforts such as the Zephyr and Airflow. (Note: It appears much of LordK’s article comes from an earlier article on Claveau at the Tampa Bay Auto Museum’s site.)
  26. SUNROOFCORD
    SUNROOFCORD
    You wouldn't know it by looking at Saab's current automobiles, but once upon a time the Swedish marque was known for crafting almost impossibly rounded bodywork. Victor Muller, CEO of Spyker Cars, which just completed its acquisition of the Saab brand, plans to reintroduce such teardrop-shaped emotion back into the automaker's line with a new vehicle codenamed 92, or in more modern parlance, 9-2.
    Don't expect to see the small, premium 9-2 before 2013 or so, when it would theoretically go up against machines like the Mini and Audi A1. According to Autocar, Saab would likely borrow a suitable set of underpinnings from GM's Opel division, as is the case with the new 2011 Saab 9-5.
    If Saab is able to get this new entry-level model into production as planned, its inclusion would no doubt go a long way towards reaching Muller's stated goal of hitting 100,000 total sales per year for the newly acquired automaker. That's not too big a stretch considering that the brand sold 93,220 cars as recently as 2008. We wish him, along with the rest of those with a stake in Saab, lots of luck.
  27. SUNROOFCORD
    SUNROOFCORD
  28. jimi'shemi291
    jimi'shemi291
    Now for a REAL change of pace, we give you the Autoette. "Huh?" you say? Made in four different decades, the Autoette is hard to pigeonhole. Is it a car, a golf cart, an urban runabout, a wheelchair . . . a tow truck?
    Well, er, uh, yes and no. In fact, the Autoette's versatility helped make it a long-lived micro-car which still has a large following today! Obviously, it never pretended to be a Deusenberg, ya know? But in terms of a basic-transportation vehicle, it lived up to all its promoters promised.
    <TABLE cellSpacing=0 cellPadding=0 width=350 border=0><TBODY><TR vAlign=top align=left><TD></TD><TD width=1>[​IMG]</TD></TR><TR vAlign=top align=left><TD colSpan=2 height=209></TD><TD width=320>[​IMG]</TD></TR></TBODY></TABLE>
    1953 Autoette, thanks to photographer Larry Fisher
    on his Autoette blog.
    On the isle of Catalina, here's an Autoette tow vehicle. The little micro-cars are still the preferred mode of transport on the island! The Autoette was made, and evolved, from 1948 to the 1970s by Royce Seevers, owner of the Autoette Electric Car Company Inc. of Long Beach, CA.
    According to Wikipedia, the two-seat, three-wheeled micro-car was electric powered by specially made batteries propulsion by a converted 24-volt Dodge electric starter motor. This was later changed to a proprietary motor built for Autoette. Models included the "CruiseAbout", "Golfmobile" and "Electric Truck". Autoettes were available with a broad range of accessories, usually installed by the dealer as upgrades, including windscreens, doors, convertible tops, side curtains, etc.
  29. TubularGoose
    TubularGoose
    HEY! thats my car! lol (just kidin)
  30. jimi'shemi291
    jimi'shemi291
    Jim, sounds as though the four years of work by the three
    gentlemen (1938-42) produced a very roadworthy car in the
    Spirit of Tomorrow! Here it's shown in one of your links, in
    the Ozarks! That's a goodly distance from British Columbia, eh?
    And though we've all seen illustrations like the one in this 1939
    newspaper, below, I think it's fun to see, while we are still on the
    subject of the early "streamliner" experiments.
