Hot Rods We never learn!
Discussion in 'The Hokey Ass Message Board' started by 325w, Nov 1, 2016.
  1. 325w
    325w
    image.png My first 54. Year was 1963
  2. ol-nobull
    ol-nobull
    If you go to car shows there are so many small blocks in the old Chevies they are just HO HUM & boring. They are trying to be different "just like all the others" & they are just all alike.
    The 235 works quite well for me in my 46 Coupe and gets much more looks & conversations from the spectators than the V8's do.
    Jimmie
  3. 325w
    325w
    Gas tank out today. Has a gallon are so of gas in it. Had to be good gas at one time cause it don't stink to bad.
  4. 325w
    325w
    Forgot how much trouble the master cylinder was to remove. Got that out and turned to motor over with a pry bar. Turned smooth. Plugs are not tight and it has marvel in the cylinders. It'll come out and one of you six guys in the DFW area needs to come get it.
    hotcoupe likes this.
  5. 325w
    325w
    Got Waltons swinging pedal for the 54. Nice piece. A couple of bits of adjusting and it'll work. Ordered other items and one the trans crossmember didn't come. The had notified before they shipped the pedal. The invoice had a hand written note telling this again. I'm liking doing business with them.
  6. HUSSEY
    HUSSEY
    Great looking car. That Walton's has some really nice stuff for 49-54 Chevy's.
  7. henryj1951
    henryj1951
    from USA
    heres mine----- ya right j/k---
    Durbinspeedshop likes this.
  8. Dan Hay
    Dan Hay
  9. 325w
    325w
    Made the attempt to remove the trans mount crossmember today. Installing the Walton crossmember. The rivets are some kinda stout. Ground heads off. Got out the air chisel. Got tired came in showered and watch tv. Try again tomorrow.
  10. WZ JUNK
    WZ JUNK
    from Neosho, MO
    You might try drilling the rivets. I remember that it was a tough job when I did mine but I do not remember how I got them out. I am using the stock cross member that I modified for the 200r transmission mount. I do plan to take it out again soon and modify it to make the center section removable instead of the whole unit. My car has the power brake unit under the floor and this complicates removing the whole cross member to remove the transmission.
    This week I am finishing up the panels I made for the dash. I made my gauge cluster out of fibergl***. The center panel where the speaker grille and ash tray are located and the glove box door are also one off fibergl*** pieces. I like a smooth dash.
    John
  11. 283john
    283john
    Makes it a 180, doesn't it?
    brEad likes this.
  12. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    In my opinion, there is absolutely nothing wrong with SBC's, they are a hell of an engine. However, again, IMO, there are places they don't belong, namely old Mopars.
    Damn nice '54 there 325w.
    afaulk likes this.
  13. afaulk
    afaulk
    I totally agree. Everything has it's place and time.
  14. 325w
    325w
    Got the four hour job of installing the Walton crossmember today. Only took me three days.
    Walton piece fit like a glove. Next step installing the 55 rear housing. Then off to get the 1/4's and the tail pan replaced.
  15. RustyDogg
    RustyDogg
    Outstanding! Made my day
    Sent from my QTAQZ3 using The H.A.M.B. mobile app
  16. 325w
    325w
    Free 55 Chevy rear end ***embly is in place. Car is rewired. Used a Chevy pu ignition switch. NOS car switches cost a bunch more. Modified the headlight switch retainer to work with a later model headlight switch. Waiting on my turn to get the rust repair done. Another week are so. EMS panel are here waiting. Time to run the brake lines.
  17. ct1932ford
    ct1932ford
    Go Man Go! Looks Good.
  18. 325w
    325w
    Done lots of side gl*** in tri 5 Chevys. First time doing a 54 quarter gl***. My goodness what a job. Have no idea how I got the left side out. Hope I learn doing the right side. Deep channel in there to catch water. Regulator mounts on the inside of the panel not inside the quarter. Good thing is all parts are reuseable.
    Dan Hay likes this.
  19. 325w
    325w
    Tackled the king pins before doing the brakes. Right side needs an upright changed that's next. Little at a time.
    little red 50 likes this.
  20. RMONTY
    RMONTY
    I really enjoyed seeing your project last week when I picked up the steering box from you. When you get ready to tackle that spindle support let me know and I will come give you a hand if you need it. I just rebuilt the front end for my 52 so it's all still pretty fresh in my mind. Keep up the impressive good work!
  21. 325w
    325w
    307 headed in the hole
    brEad, Jet96, 36brothers and 2 others like this.
  22. 325w
    325w
    Thank you Monty. I got the right upright replaced. Had to order parts.
  23. 325w
    325w
    IMG_0630.JPG More done
    cactus1 likes this.
  24. 325w
    325w
    Tuesday is the day. Going to get the rust removed and the EMS parts installed. Fingers crossed pockets emptied. Yes Larry (rip) I'll post pics on Tuesday so it happened!!
    brEad and Jet96 like this.
  25. missysdad1
    missysdad1
    Keep up the good work, ****. Lookin' good!
  26. 325w
    325w
    IMG_0695.JPG Set for surgery
    cpd682, little red 50 and pat59 like this.
  27. 325w
    325w
  28. 325w
    325w
  29. little red 50
    little red 50
    Your car reminds me of mine when I got it, rust in the same places way better than a lot of them I've seen. Nice car! Looks like we almost had the same game plan. Small block chevy etc....
    quick85 and brEad like this.
  30. 325w
    325w
    IMG_0740.JPG IMG_0743.JPG IMG_0742.JPG A bit more done
    quick85, brEad and Chavezk21 like this.
