Technical weber cam specs for F/h
Discussion in 'Traditional Hot Rods' started by 48fordnut, Mar 21, 2018.
  1. 48fordnut
    48fordnut
    I have picked up a 59 a short block that has a weber cam . The cam number is weber 1B or could be 11 B, it is double stamped. Anyone have any specs for this cam. The eng is ported and relieved ,3 3/8 x 4 for the size.
    Thanks for any help.
    jim
  2. Are you sure it is not just the factory marking? I've seen plenty of factory cams with the number 11 right on the snout area. I used to run Weber cams back in the day, they were marked with things like F-1, F-6, F-7, etc.. I'm not aware of a '11B' grind . . .
  3. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    B&S Do you know of any info on a weber 5-T.I have searched their site but come up empty. I bought a 59 ab & it came with it extra. P O had no info for me.
  4. I've never heard of a Weber 5-T? Can you send me a clear picture of the front of the cam so I can see how it is marked?
  5. the Weber F-1 specs are--advertised duration-264 deg. in&ex
    112 deg. lobe separation angle
    net valve lift .300 in.-.299 ex.
    valve lash hot .012" in -.113" ex.
  6. banjorear
    banjorear
    5-T is a Ford stamping I believe.
  7. 48fordnut
    48fordnut
    Bob, this is what is showing with the timing gear on. Will pull the gear for a better pic.
    Duncan, thanks for the info.
    Thanks,
    jim
  8. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    3844610[/ATTACH] Hi Gary:
    Hope you can make these out. There is a 5T that is cast in the forging. Don't look like it has ever been used. weber 5-T cam.jpg
  9. BURN OUT BOB
    BURN OUT BOB
    from western AZ
  10. flatjack
    flatjack
    As noted 5T is a Ford designation for 59A cams.
  11. 48fordnut
    48fordnut
    will try to get what is behind the cam gear in about a hour.
  12. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    Ok so what are the specs?
  13. 48fordnut
    48fordnut
    That's what I want to know. I have a pic and it says weber at the top ,R1 B below that .pic coming
  14. 48fordnut
    48fordnut
  15. Weber did make an 'R' grind - but I have no clue as to if this is it. It is a very mild grind (which wouldn't seem to be the one in this engine). It only lifter .290 and had pretty low duration.
    BUT - I would think it strange for Weber to use two different stamp fonts on the same cam - so my guess is that the 'R' stuff is something else . . .
  16. Only problem - that is an early cam . . . way before the 59x series. I'll have to look at a few old early cores to see if they have the 5-T marking - can't remember.
    48fordnut likes this.
  17. 48fordnut
    48fordnut
    Thanks all for the answers.
