Technical Weber Flywheel?
Discussion in 'The Hokey Ass Message Board' started by Malcolm Elvy, Jan 29, 2023.
  1. Malcolm Elvy
    Malcolm Elvy
    Can anyone tell me the application for this Weber Aluminum Flywheel? I don't see any part numbers....the timing marks are on the outer edge of the part...Thanks for any help.... DSCF3220.JPG DSCF3221.JPG DSCF3222.JPG DSCF3223.JPG
  2. squirrel
    measure the diameter of the inner hole, as well as the ring gear.
    Chevy 2.5" id, 3.58" bolt circle, 12.75" (153 teeth) or 14" (168 teeth) od
    If it's not for a Chevy, then post the dimensions.
  3. Malcolm Elvy
    Malcolm Elvy
    Would a Chevy have the timing marks on the outer rim?
  4. gnichols
    gnichols
    from Tampa, FL
    An Italian car?
  5. squirrel
    If the flywheel was used in a race car without a damper, perhaps someone added the timing marks?
