Technical Weber inlet manifold ID?
Discussion in 'Traditional Hot Rods' started by filospinato, Nov 13, 2023.
  1. filospinato
    filospinato
    I picked up a couple of Italian DCOE Weber carbs, and some side draft manifolds were thrown in. I keep to British cars, these aren't anything I recognize.
    There are 3 with no markings, runner lengths are all the same. There's also a single, shorter manifold with the same mounting flange, the casting says 'SISSELL' and 'SWM 45 LC'.
    Closest I can figure, they're for a Chevy 6 cyl motor.
    Look familiar to anyone?
  2. Black Panther
    Black Panther
    from SoCal
    filospinato likes this.
  3. filospinato
    filospinato
    Thanks, BP. I can't use them, they're headed for the auction block.
  4. jimmy six
    jimmy six
    Most out there are Clifford’s…… I’d rather have Sus***’s as a choice if wanted a set…
  5. Joel W
    Joel W
    Any chance they would work for a Pontiac sprint 6? Would like to have a setup like that on a Sprint! Have an Austin Healey 100-6 project that has a Sprint 6 retrofitted.
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I knew someone who modified a Pontiac Sprint four barrel intake manifold to use on his Chevy 250, so I imagine that you could go the other direction.
