Weeee, am I havin' fun!
Discussion in 'The Hokey Ass Message Board' started by dickster27, Oct 30, 2008.
  1. 29 sedanman
    29 sedanman
    from Indy
    Come on Dick! Tell us for sure what we are looking at.
    It looks killer, great job!
  2. You're getting out of hand over there Dickster. :D
  3. J&JHotrods
    J&JHotrods
    Windshield wipers for a goats ass? I'm not helping, am I. No disrespect meant-whatever carbs they are, it's different and cool lookin.
    Jay
  4. bobwop
    bobwop
    from Arley, AL
    I know, but Linda bribed me with some awesome oatmeal cake not to tell. Dickster, you are one lucky (and talented) dude
  5. bstie
    bstie
    Its the Flux Capacitor from back to the future!
  6. MichaelDorman
    MichaelDorman
    SBC dual quad intake w/ 2brl adapters and Carter YS side drafts?
  7. tommy
    tommy
    I can only think of 3 rear draft carbs, Mercury, Olds and Stude. None of them match what I can see.
  8. sir
    sir
    ...yup that's sweet....but does it work?
  9. dickster27
    dickster27
    from Texas
    Is a frog's butt watertight? Sure they work. I will give all of you a hint, cause you ALMOST(but not perfect) got the intake right and that's about all. I used 2 of these carbies in a different configuration a couple years ago that is now on a HAMBER's A burning up the roads. I'm going to let you guess a while longer and as long as Bob and Denise don't give my secret away I am going to make it a little more interesting. One more hint, this is NOT the unit that is going to SEMA next week on a A pickup. I will give one of my "spiral ribbed" fuel filter kits to the person who can identify this induction system correctly. Now, have some fun, cause I sure am.
  10. yblock marine or corvair turbo carbs
  11. Looks like a headache to me...........But probably some old "fish " carbs with a 3bolt
    base adapted.
  12. dickster27
    dickster27
    from Texas
    Man, your insight is overwhelming.
  13. Dickster 27,Thats what happens to you after 75 years.....Been there,seen that,but still going strong...now where is my cigar? where in Texas you coming to?
  14. The light finally came On. They are Heavy equipment Holly carbs. Same base as Strombergs.
    The Wizzard
  15. dickster27
    dickster27
    from Texas
    Man, you are getting warmer but not there yet. You're going to win that fuel filter kit yet! Keep goin'.
  16. thunderbirdesq
    thunderbirdesq
  17. im thinking they are your "lasers" for your "deathstar"
  18. They are called a Concentric Carb for heavy equipment and some stationary power plants. Used from 1946-1955. Does that work?
    The Wizzard
  19. They look like a hybrid of the Mercury 885 3 bolt base and the top half out of a Mack truck. Because if look at the link I posted the top part of the carburetor in the lower left hand corner matches; the Mercury carbs don't match.
    Either way, they're Holley Concentric carburetors and you named them first!
  20. Doc.
    Doc.
    My next carb/intake purchase?
    Doc.
  21. 40Standard
    40Standard
    from Indy
    it looks too costly whatever it is
  22. dickster27
    dickster27
    from Texas
    Not unless you put the 2x2 back on the Lander and let me get it running.
  23. dickster27
    dickster27
    from Texas
    Well wizzard, I gotta tell you. Your close enough to get the brass ring. These are indeed Holley Concentric carbies. These particular onces were made for the Canadian military to provide some more torque for their deuce and a half's and bigger. The first time I built a unit with this particular model, I had no idea what to expect but found out after being used they run great. They are very unique in the fact that the valve body is exactly as any 94 but the bowl is actually a cast iron cover that is chambered around the action fuel bowl. They have a 4 bolt square side draft air horn so I took a VW custom air cleaner and altered the base to make it clear and mount to the horn. I used my special risers compliments of my buddy Matt at Gear Drive to give the carbies a little more height and little more run to atomize fuel a bit better. Obviously the rest of the stuff is my craziness. So, my intellectual friend, PM me your mailing addy and I'll send you your prize. Oh, I'm starting one now that will be 4 carbies, 2 94's and 2 97's on the same intake with 2 front to back and 2 side to side. That will be a fun challenge for progressive linkage. It is amazing how much you can do with dual quad intakes without having to resort to 2 ho-hum 4 barrels. Damn, ain't hot rodding a blast?
  24. TRIUMPH TERROR
    TRIUMPH TERROR
    Damn Dick I was gonna see if you would give me a fuel filter just to keep quite since I had inside info..........HAHAHAHA
    This looks even better and wilder in person boys.:cool: its Kooooool with a K....
    Shoe
  25. Yee Haa!! First thing I've won in years. I actually remember working on an Old Road Grader probably 40 years ago with one on it. I was driving my 50 Merc at the time and noticed the simularitys. I looked through my many Motors Manuals for an actual Model number but no luck.
    You do some Fine work my friend and that fuel filter will look right home next to your Oil fill tube on my small block Tri Power when it goes back on said 50 Merc.
    Shipping info coming via P.M.
    The Wizzard
  26. racer756
    racer756
    I think its awesome, but can it make whiskey:)
  27. Doc.
    Doc.
    Okey dokey.
    Doc.
  28. sxdxmike
    sxdxmike
    wow that thing is very cool. Any build up pics or tech you might want to share?
