Hot Rods Weiand cheater heads?
Discussion in 'The Hokey Ass Message Board' started by BACKYARDKUSTOMZ, Apr 23, 2015.
  1. BACKYARDKUSTOMZ
    BACKYARDKUSTOMZ
    This guy is advertising these as weiand cheaters anyway to tell if they really are? ImageUploadedByH.A.M.B.1429845531.837118.jpg ImageUploadedByH.A.M.B.1429845585.778574.jpg ImageUploadedByH.A.M.B.1429845594.425748.jpg ImageUploadedByH.A.M.B.1429845662.501349.jpg
  2. Kevin Lee
    Kevin Lee
    Super Moderator
    They look like it – I can see the little pad beneath the water neck that says "Weiand". Not a stamp so much as cast into the head itself.
    From the size of the combustion chamber it looks like they may have been milled at least once? Also looks like they have been milled for valve clearance as well.
  3. BACKYARDKUSTOMZ
    BACKYARDKUSTOMZ
    Yeah the only thing I can clearly make out is that is says CANADA
  4. BACKYARDKUSTOMZ
    BACKYARDKUSTOMZ
    What would you guys pay for them? The seller says there are no stripped threads.
  5. AVater
    AVater
    1. Connecticut HAMB'ers
    Ford made aluminum heads in Canada with a Canada mark. Sorry I can't see Weiamd mark. You may want to check on the Ford barn.
  6. BACKYARDKUSTOMZ
    BACKYARDKUSTOMZ
    its on the back side of the water neck it says weiand
  7. BACKYARDKUSTOMZ
    BACKYARDKUSTOMZ
    Also says 375...not sure if these are for different compression ratio's.
  8. AVater
    AVater
    Yep. See it now. Thanks!
  9. BACKYARDKUSTOMZ
    BACKYARDKUSTOMZ
    What do you guys think? What are they worth to you? What does that 375 mean exactly?
  10. 24 Dodge
    24 Dodge
    Looks like one spark plug hole has been made bigger or am I seeing some thing that is not there.
  11. I was going to mention that they may just be Canadian heads. Which are prized heads by the real flathead guys. Two heads that would be high on my list if I was building a flatty are the Canadian aluminum heads and the American Rocky Mountain heads.
    OK just read though the thread, they actually say Weiand on them? Stamped or cast?
  12. AVater
    AVater
    I believe Offenhauser uses a numbering system 400, 425 etc with the lower number being higher compression. Not sure about Weiand?
  13. BACKYARDKUSTOMZ
    BACKYARDKUSTOMZ
    If you check out the second picture you can see it says weiland.
  14. hotrawd
    hotrawd
    from lima,ohio
    "375" (or any stamped number) is the maximum valve lift without machining for additional valve clearance.
  15. BACKYARDKUSTOMZ
    BACKYARDKUSTOMZ
    You are correct one hole is bigger he said for an oil fouler...I guess I should stay away from these heads eh?!
  16. Don't pay much for them and add a heli coil or steel insert in the big hole.
  17. dan c
    dan c
    the 375 is the clearance measured in the pocket above the valve. probably could get away with an isky max 1. but, don't the pockets in these heads look like they've been cut deeper?
  18. BACKYARDKUSTOMZ
    BACKYARDKUSTOMZ
    Thanks for the help guys!! I am staying away from these. I'm keeping my eyes open for vintage flathead parts for my 1946 block.
  19. alchemy
    alchemy
    Since you don't want them, tell us what he was asking for them.
  20. BACKYARDKUSTOMZ
    BACKYARDKUSTOMZ
  21. Makes my butt hurt just to think about it. They are used heads with no moving parts. :D
  22. alchemy
    alchemy
    Yeah, overpriced. Specially since they've been milled a couple times and have a buggered sparkplug hole.
  23. cretin
    cretin
    Kinda hard to see in these photos, but it does't look like it says Weiand to me. I can clearly make out the "and" but the first part doesn't really look like "Wei" to me.
