I just traded for a tunnel ram for a BBC, but I don't know what kind of carbs it's set up for. They are smaller than 4150's, but that's all that I know. The casting # on the bottom is CR 1935 (Might be 1985) and it's for a square port BBC. Any clues on adaptors for 4150's would be greatly appreciated. It's an older intake and it has "SAY WHY-AND" cast into it. Thanks in advance!
I was just playing with an adaptor plate that I had... The problem is mounting the Holley carbs sideways. Does anyone make an adaptor plate for this? Surely I can't be the first person to run into this!
I recently bought a tunnel ram at a swap meet. $120 for a SBF, I thought was pretty good. Well, after you buy two carbs and the special linkage to run the carbs side by side, and the small base distributor that's required for this setup....it wasn't so cheap anymore.
I got lucky, it came with a fogger system, 2 Holley 650's, plumbing and linkage. All this for $300... not too shabby in my book. Anyone have any idea about what year this thing is from? Thanks!
Why won't the 650's work if they came with the intake ? You need 4160's to run inline like these two 450's I have.
