weird problem...
Discussion in 'The Hokey Ass Message Board' started by 54pathfinder, Jun 6, 2012.
  1. 54pathfinder
    54pathfinder
    from canada
    engine: 239 six pontiac flathead in a 1954 cheiftain
    symptoms:
    1) running rich, soot on plugs, soot on driveway.
    2) looses power at wide open throttle
    3) will often not stop running when key is turned off
    4) will not produce enough power to go up a hill when timing is set
    according to marks
    5) seems to miss subtly at idle
    6) high voltage shocks when distributor is turned while engine running
    its getting worse and worse. also i cant find a carb kit for the WCD Carter carb which is flooding itself. one problem or several??
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    My first thought is that something is wrong in the distributor and vacuum advance mechanism. I would take it out and visually go over every aspect of it, maybe replace all the components, especially the cap and condenser. If you can find a shop with a distributor machine that might help. Bushings can wear in them and give goofy performance.
    Don
  3. Nitroholic
    Nitroholic
    from SoCal
  4. you is gonna need some wires and plugs , but need to fix the flood out problem too
    if you get the carb fixed and do the ignition then you could get it scoped out
    and it is going to take a 70 MPH decarbonization after fixing some of the problems
    i am in the middle of this on a car sitting for 3 years and have to buy a spare carb tomorrow, got the ign fixed today
  5. Mr48chev
    1. Is the choke plate opening up all the way?
    2.. Check Ebay number 251078199674 for the carb kit. Not the least bit inexpensive but they do have it.
    Other than that all I can suggest is doing the normal things a person would do to see what shape the engine is in.
    Run a compression test
    Run a leak down test
    make sure that the timing gears or chain don't have a bunch of slack.
    Have the distributor checked out as suggested previously.
  6. Mike Miller
    Mike Miller
    Basic tune up and a carb kit, start with an engine condition check (compression test) and go from there.
  7. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    Dont know if this helps or not...
  8. junk yard kid
    junk yard kid
    wait, your hand gets shocked when you touch the distributor?
  9. 55Hydramatic
    55Hydramatic
    ^HA thats awsome
  10. Don's Hot Rods
    Don's Hot Rods
    from florida
    That was what made me lean toward something not being right in there. Cracked cap, bad wires, but voltage is going astray it sounds like to me.
    Don
  11. dragster dude
    dragster dude
    new dissy cap time also check that the timing marks are accurate
  12. bonez
    bonez
    from Slow lane
    Looks like at least 2 diffrent problems...
    The fact that it keeps runnin when you turn it off its most probably due to a vacuum leak, or way off timing, but if you say the timing is right.
    I had the dizzy shock me b4. Even only touchin the cables used to. It turned out one of the leads got melted for being to close to the heders and the wire was exposed.
    Good luck.
  13. When did needing a basic tune-up become a "Wierd problem"
    Yep there are several issues and those are addressed in a tune up.
    Above and beyond the tune-ups basics,
    Flooding carb is your biggest problem and that needs to be corrected first .
    You probably need to search a bit harder and deeper to find that carb kit.
  14. farmboyhotrodder
    farmboyhotrodder
    from PA
    No one mentioned that it may also be a cracked distributor cap. Hairline cracks cannot be seen.
    Do like the others said above. Check your vacuum advance. Check your timing. I adjust the timing on my Chevy truck by ear and drivability. Sometimes a timing light will tell you where it's supposed to be, but the engine may be worn some, so you have to advance it.
    Also, the ethanol fuel wreaks havoc with the accelerator pump plungers, not to mention the pot metal carburetor housing.
  15. 54pathfinder
    54pathfinder
    from canada
    thanks guys i'll let you know what i find
  16. When you turn the key off, the ignition should stop firing, period. If the engine keeps running, you likely have a lot of carbon buildup (from the rich condition?) which is causing hot spots.
    Totally agree that if you are getting shocked when touching the cap, changing the cap, rotor, and wires are in order. Check for carbon tracks on the dist housing as mentioned. Once that process starts it will keep happening..
  17. Well you answered one question on your own the carb is flooding itself.
    second question may have also been answered by the first. Throttle blades open too far to compensate for flooding will cause run on.
    Cracked cap or bad wires or a combination of thre two. Also may need a new set of points properly adjusted. This may also cure 2 and 4.
    get it properly tunned and either adjust the float or replace the needle and seat and adjust the float then get back to us that it has been cured.
  18. bigalturk1
    bigalturk1
    I agree, check compression first
  19. Or...you could ****** that boat anchor out of there and put in a nice389/421.....
  20. bonez
    bonez
    from Slow lane
    I had an intake leak once that caused the motor to keep fireing after the ignition was turned off, so it aint necessarely the cap.
    A severe leak from the intake should cause a whistle too btw, other than making the engine run like ****e
  21. bobss396
    bobss396
    It probablly has a few basic issues going on. Agree that a compression test is a good idea before any real $$$ is expended. A real bad cap can give you a shock if the crack travels down the coil tower. That one may be visible from the outside. The carb and choke should be gone through and course the standard tune up and settings for that and the carb.
    Nothin' pretty getting a 58 year old relic sorted out, one step at a time and be prepared to get filthy and frustrated.
    Bob
  22. overspray
    overspray
    My flathead ran like that, except I didn't get a shock from the dist. I had rebuilt the carb and found the float had a dent in it. I salvaged a real nice shiney perfect float from another carb. It flooded, ran ****ty,sooted up the plugs, and gas poured down the carb. It seems I picked a float with a tiny hole in it and as it filled up with gas it sank in the bowl and the problem got progressively worse. I finally took the carb apart and found the bad float and replaced it with the original dented one. A stuck or dirty needle valve will act the same.
    Something to check, anyway.
  23. sdluck
    sdluck
    Spray water from a spray bottle onto the cap and wires,to find the spark loss
  24. other fun ways include watching it run in the dark and grabbing wires until you jump or **** yourself! :D
  25. Atwater Mike
    Atwater Mike
    DISTRIBUTOR GROUNDS!
    Internal (from breaker plate to dist. case)
    External (Dist. case loose at mounting, you grab it while running and you're the ground!)
    Try it again...
  26. I dated this broad that wasn't real bright once, of course she was dating me, and when my hawg seemed like it wasn't getting fire I would pull the plugs and she would stick a finger in the magneto wire. I told her that if the put her pinky finger on the head it wouldn't hurt.
    I always knew if it was getting fire because I would hear owe then get slugged in the shoulder. :D
  27. 40FordGuy
    40FordGuy
    Run - on after ign shut off can be from a too fast idle speed. You didn't say how long it runs on....but if your alternator is incorrectly wired,..it'll keep running , with some configurations......
    4TTRUK
  28. jcmarz
    jcmarz
    from Chino, Ca
    Sounds like old age.
  29. Moose223
    Moose223
    Hey P&B you are a sick individual.....Good job
  30. That would have to be some pretty screwed up wiring!
