Event Coverage Welcome to the 2017 Meltdown Drags
Discussion in 'The Hokey Ass Message Board' started by Okiedoker, Oct 6, 2016.
  1. saltflats
    saltflats
    from Missouri
    Someone my have to take my hand and show me.......If it is the exhaust setting on the shelf I hope you have some extensions on the collectors.
    I had some 3 or 4 foot pipes on the headers on my 383 Charger and the car would run 102 mph consistently.....I had read of the trick of painting a the pipe and cutting it off at the point the paint stopped burning off.
    Well The way the cross member was on the car the pipe would have to have a dog leg bend in it and just happen to have some pipes 9 inches long that I could just bolt up.
    So I installed the short collector pipes and the car picked up to 105 mph.
    That was the only thing that I changed.
    They say around 16 to 18 inches is the sweet spot.
    loudbang and Gammz like this.
  2. saltflats
    saltflats
    from Missouri
    Better check all the bolts.
  3. Gammz
    Gammz
    from Lincoln Ne
    It's nothing to do with the exhaust on the shelf. However we were hoping to have some kind of extensions on the headers before Saturday. Hasn't happened yet. He's been busy with the lettering on the junk.
    A old timer at work was telling me about the paint trick the other day. We might give it a try. The headers on this thing are kinda let's say jankey. The collectors point toward the center of the car. Not straight. We will have to get some pie cuts on or pick up some pre bent tubes and make it work. I can't speak for him but I'd feel better with some longer pipes on it
  4. Gammz
    Gammz
    from Lincoln Ne
    He did that today
    loudbang and saltflats like this.
  5. saltflats
    saltflats
    from Missouri
    Sounds like you want to put a governor on it.
    Should I delete my post before Wyatt see it?
  6. Gammz
    Gammz
    from Lincoln Ne
    [emoji23]
    loudbang, powrshftr and saltflats like this.
  7. loudbang
    Gammz and DubG like this.
  8. Okiedoker
    Okiedoker
    from Wisconsin
    I hope that everyone has a great weekend...we are only 7 weekends from the Meltdown Drags.
    How about a little caption contest for this picture...
    Swamp Rat 4, loudbang, DubG and 3 others like this.
  9. saltflats
    saltflats
    from Missouri
    All the kings horses and all the kings men couldn't put the shaker back together again.
  10. Finn Jensen
    Finn Jensen
    Jeff, you are brutal :)
    loudbang, powrshftr and DubG like this.
  11. I'd rather PUSH a Ford than drive a Chevy!
    :D:D:D
  12. wrenchbender
    wrenchbender
    Speaking of scot he was supposed to give us a video is this it? Lol
    Chrome don't get ya home
    saltflats and DubG like this.
  13. powrshftr
    powrshftr
    Still draws a crowd,even when it's broke....[emoji6]
    Scott
  14. 55belairx2
    55belairx2
    Lost Shim Shanker
  15. "I thought YOU tightened the U-bolts!?!"
  16. rawcjw19
    rawcjw19
    Any of you have plans or some pics of wheelie bars? I made some changes on my little model a and may want a set. I have some old leaf springs and we just got a new CNC plasma at work [emoji3]
  17. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    Quick hold him back or he will beat all of our Chevys!!!! :D:D:D
  18. powrshftr
    powrshftr
    Check out Quain Stott's build thread of his Willys.His are right up your alley.:)
    Scott
    rawcjw19 likes this.
  19. 55belairx2
    55belairx2
  20. rawcjw19
    rawcjw19
    I checked his out. But I have to come off the rearend, I don't have any frame really past the rearend. It may not even wheelie, but I would sure hate to find out and oil the track with my oil pan
    Gammz and loudbang like this.
  21. To make them look right you need to do your research first. When I am looking for reference material, I often refer to pictures taken from that era. Vintage pics could be found in many places, including '66 and earlier magazines, the awesome website of George Kl*** ( http://www.georgekl***.net/index.html )and of course reference the '66 NHRA rulebook. If you see them in a picture taken in 1966 or earlier, you know you are doing it right! ;)
    loudbang and powrshftr like this.
  22. strokedstang331
    strokedstang331
    from Beloit WI
    Go farther into his thread he built a different set later. Here are some pictures I have of his. My wheelie bars are just like them. The flat arched pieces are just 1/4" aluminum then the top bar is Chromoly. The only trick is the wheel and top bar location. Where the top bar attaches needs to be 1" ahead of the center of the wheel for them to work good. Pretty easy to make I built mine if u need any pointers let me know. 20141031_144217.jpg 20141031_144344.jpg
    Sent from my SM-G930R4 using The H.A.M.B. mobile app
    loudbang, powrshftr and rawcjw19 like this.
  23. powrshftr
    powrshftr
    So those new front coils that Alex got me turned out to be so tall/heavier rate,that they raised the front of the car about 5 inches.....It made for a really cool,mid-60's Superstock vibe with the front in the air a bit,but caused one major problem:The shocks were a couple inches too short to bolt up.[emoji53]
    Out comes the spring compressor again,time to nut-up and squish these death traps down so I can cut a cool off of em and get things right again.
    After a couple of hours,a couple of coffees,and a couple more near death experiences with my spring compressor,the coils are cut,the springs are back in the car,and it sits nice and level with about a 3" gap between top of tire and fender lip.
    Also finished up the install on the traction bars,and threw the new carbs on there.
    Check out the new and improved stance:
    55belairx2 likes this.
  24. powrshftr
    powrshftr
  25. powrshftr
    powrshftr
    This is from the bottom of my "to do list" taped to the windshield.
    I'm so glad the fastback is going to have parallel leafs and an Ford I-beam axle under the front....I never wanna see another coil spring as long as I live.[emoji15]
    Scott
    Deuced Up!, 55belairx2, DubG and 2 others like this.
  26. powrshftr
    powrshftr
    On the one yard line with our shifter issues,too....Turns out my Dad had installed a piece of tin under the carpet to fill a bit of where the floor was cut for the other shifter,and that,and a self-tapping screw that was securing it,were right in the way of 3rd gear.
    Problem solved.
    One step closer to testing.:)
    55belairx2, DubG and saltflats like this.
  27. powrshftr
    powrshftr
    Waiting for the parts store to open so I can grab some longer carb studs.
    Feeling pretty happy with all the **** I got crossed off the list tonight.:)
    Scott
    55belairx2, Finn Jensen and DubG like this.
  28. mediumriser
    mediumriser
    from Ohio
    Looking forward to seeing you and your dad again this year Scott.
    Tickety Boo, 30dodgeboy and powrshftr like this.
  29. powrshftr
    powrshftr
    Sorry it was such a sideshow last year Pat...Once things started going wrong (which was pretty much immediately..lol),all my "hangin out" time turned into "fixing broke-*** ****" time.
    This year we should have all the bugs out before we get to the event,and we should be able to spend a lot more time hanging out.
    Plus,I need a rematch with that bad*** Fairlane of yours!I think I had ya for the first 2-1/2 feet![emoji23]
    Scott
    mediumriser, 55belairx2 and DubG like this.
  30. powrshftr
    powrshftr
    Got some carb studs from my guy....but only half as many as I needed were in stock.
    Looks like I'm gonna be waiting a couple of days to make any test p***es with the car...Grrrr....
    mediumriser likes this.
