Event Coverage Welcome to the 2017 Meltdown Drags
Discussion in 'The Hokey Ass Message Board' started by Okiedoker, Oct 6, 2016.
  1. Okiedoker
    Okiedoker
    from Wisconsin
    Wow, that is impressive. My little old iron lunged sbc didn't even get close to those numbers...
  2. enloe
    enloe
    from east , tn.
    Man you guys are HARSH! :)
  3. DubG
    DubG
    from Nebraska
    i'm not old enough to buy ya a beer but maybe we can work something out!
    wyatt "the Gasman" Gammel
    loudbang, 55belairx2 and saltflats like this.
  4. Your gonna need a tow ball in the driver seat for your grommet to hold on to!
  5. Okiedoker
    Okiedoker
    from Wisconsin
    Come on Wyatt...your Dad is old enough...make him pay for it. Tell him he owes Ric a twelve pack and then I can have some too!
  6. Okiedoker
    Okiedoker
    from Wisconsin
    I just spit my water out....
  7. BLACK STUDE
    BLACK STUDE
    Mine was supposed to be iron lunged too, but I couldn't p*** up the deal on those stg 2 heads. Now I've got to detune it so I don't destroy it. Just have a halo girdle on the mains. Gonna try and bring it down about 80 hp, I need this thing to live a while. It made 626 with a 750 cfm carb on it, thinking of going that route. I just want to get it together and come have some fun with you guys. This build was fun but these damn buicks are expensive. Gathered parts for 11 years....
  8. Tickety Boo
    Tickety Boo
    from Wisconsin
    Good Luck Scott
    Hope it all comes together for you testing and tuning, Don't break it untill I get a chance to race you.;)
    Norb
  9. squirrel
    I guess I might head up to Tucson tonight and see how my car is running...it was kind of slow when I ran it there last month, hope nothing is wrong with it.
    My wife got us a hotel room for the Meltdown, so we'll be there...
  10. wrenchbender
    wrenchbender
    Says the guy who tore the rear end outta his car the previous year lmao
  11. You want it sent out now, or bring it to the Meltdown?
  12. Mission accomplished! :D
    55belairx2, loudbang and powrshftr like this.
  13. Gammz
    Gammz
    from Lincoln Ne
    Stopped for a couple of gas station sandwiches and then off to see if this pile of **** will run worth a ****....
  14. rusty1
    rusty1
    Squirrel,...are ya bringin your Chevy II?
  15. squirrel
    That's the plan. II.
    loudbang, saltflats and Gammz like this.
  16. powrshftr
    powrshftr
    The only thing that's gonna fail catastrophically is your dignity Jeffro.
    You better be bringin' a whole bunch more than 119mph to back up all the tongue waggin' you're doin'...;)
    Scott
  17. powrshftr
    powrshftr
    saltflats likes this.
  18. wrenchbender
    wrenchbender
    Seems like I seen that before Scott lol
  19. saltflats
    saltflats
    from Missouri
    Just thinkin out load....but have you drove this car before?...Scott?
    55belairx2 and loudbang like this.
  20. powrshftr
    powrshftr
    You got the VIP preview Jackson...[emoji16]
  21. wrenchbender
    wrenchbender
    I must be in the kool group I've gotten lots of previews lately but no posts yet lol
  22. Okiedoker
    Okiedoker
    from Wisconsin
    That is why I can call it a "pro tip"...
  23. powrshftr
    powrshftr
    If I need any help with "Un-locking" a line-lock,I'll give you a call Jeff.[emoji23]
  24. Gammz
    Gammz
    from Lincoln Ne
    After a few gremlins that decided to come out when I rolled into the tech tent. I got to make two p***es last night. Way better than a couple weeks ago. There is a lot more in it. Having some electrical issues still. It may be time to ditch the CHEAP *** HEI distributor. Looking into that. Going to try and recurve it. It acts like it's advancing to soon.
    One question this morning, with the key off should the car have power to the i terminal on the starter relay? I don't think it should. Only when cranking right?
    Anyways got home at about 2am. Time to go unload and spend some time with the ol lady.
    Stupid race cars........
    powrshftr and loudbang like this.
  25. squirrel
    The I terminal should only be powered when the engine is cranking. The ballast resistor byp*** circuit.
    Good to hear things are going better! you still have a month.
    get an old Dual Point distributor in there, and then play with the advance curve till it works right. That's what I have...
  26. Gammz
    Gammz
    from Lincoln Ne
    Thanks Squirrel! So perhaps the new starter relay is bad? And sending power across while the key is off. I'll slide over to the parts house and get a new one.
  27. saltflats
    saltflats
    from Missouri
    No it is back feeding from somewhere else.
    Unplug the wire from the starter relay and see if you still have voltage at the wire.
  28. squirrel
    If you don't have a ballast resistor, you should not have that I terminal connected to anything...right? been a while since I worked on a Ford, though
    Gammz likes this.
  29. saltflats
    saltflats
    from Missouri
    The I terminal would go from the starter relay to the + side of the coil and only have voltage when cranking.
    It get the voltage from the relay when it is closed.
    loudbang, Gammz and squirrel like this.
  30. squirrel
    Anyways...yeah, I ran an eleven last night, which is a bit slow. started another p***, noticed that it was not making boost, so I let off and decided I need to fix something. My wife mentioned something about throttle opening all the way, of course I didn't look at that at the time, just packed up and went home. Looked at the throttle linkage this morning, sure enough, it was opening the carbs about half way. doh. Playing around with it, I think there's a loose clamp bolt on the lever that attaches to the pedal, where it goes through the firewall. The problem with blown big blocks in compact cars is that you can't actually see or reach that bolt when the engine is in the car.
    I'll get it figured out.
    saltflats, Tickety Boo and Gammz like this.
