Event Coverage Welcome to the 2017 Meltdown Drags
Discussion in 'The Hokey Ass Message Board' started by Okiedoker, Oct 6, 2016.
  1. DubG
    DubG
    from Nebraska
    well i figured one of you out there are getting a little anxious to hear the white lighting so here ya go,
  2. saltflats
    saltflats
    from Missouri
    Sure sounds better than it did just settin in my basement.
    Good job guys!!!
    loudbang, powrshftr, DubG and 2 others like this.
  3. Gammz
    Gammz
    from Lincoln Ne
    I'm calling the cops [emoji61]
  4. saltflats
    saltflats
    from Missouri
    Are your header collectors 3 inch or 2.5 inch?
  5. DubG
    DubG
    from Nebraska
    they are 3", but sometime soon when we get some welding gas i'm gonna make some turn outs so we don't fry the tranny.
    wyatt "the Gasman" Gammel
  6. Tickety Boo
    Tickety Boo
    from Wisconsin
    Not much hair left on my head from scratching it trying to figure this one out but.
    Any one ever have a one wire alternator go bad, sending enough juice through its housing to cause run on ?
    This thing.runs hot to the touch in short time then ( with the wire disconnected ) the engine runs on for about 5
    seconds after turning the kill switch off?
    Doing this same test ( with the belt off ) the switch kills the engine immediately.
    Its got to be sending enough juice to keep the msd box lit and confused.
    Ric
    These electrical problems is cutting test and tuning time short, going to remove the screens and try the shear plates.
  7. saltflats
    saltflats
    from Missouri
    That's strange Norb.
    You are saying with no wires hooked up to the alternator it will run on?
  8. Tickety Boo
    Tickety Boo
    from Wisconsin
    Yes
    Tried it several times, then took the belt off ( no more run on )
    Tried this after replacing the one wire from the alt. back to the battery. ( thought it was grounding )
  9. saltflats
    saltflats
    from Missouri
    I would take a colt 45 and shot that sucker.
    55belairx2, loudbang and Gammz like this.
  10. Tickety Boo
    Tickety Boo
    from Wisconsin
    We will see if I need the core. ;)
  11. saltflats
    saltflats
    from Missouri
    When it's runnin with the belt on and the wire off can you pick up voltage in the case or the 12 volt stud on the alternator?
  12. Saxxon
    Saxxon
    I stated last fall this would be a season where I make no major changes ... nothing was said about a boat load of small ones ... which is just as radical and maybe even more expensive.
    I changed manifolds to one more suited to the application. It's hoped we solved the pan-evac issue that plagued us last year but just in case - this new intake along with the steel lined supercharger gaskets should help keep the blower off the picnic table. This intake is taller so I needed a longer blower belt. I had my engine builder do the intake and he gave the long block a once over - it passed with flying colors - and I got him to install a more traditional cam drive for the fuel pump to replace the remote drive. This meant a re-work of the fuel lines and shut off. After a broken crank hub and pulley I added a crank support. I also repaired the bigger fuel tank and redid the tank mount so it now includes a safety legal front bash bar. I've been thrashing the last 4 weeks to get it all together ... The most obvious thing I DIDN'T do was fix the body from my little staging lane accident from last year.
    First fire is scheduled for this Thursday. This weekend will see the Scout our prefect and Larry's 23 T Altered at a static display in support of a Special Olympics Car wash fund raiser then it's shake down passes July 1
    loudbang, 30dodgeboy, Gammz and 5 others like this.
  13. saltflats
    saltflats
    from Missouri
    Good luck....I broke mine for the test and tune....but I really like working on this car so I'am happier than a punk in boys town.
    Hope to have enough used parts to hold up for some fun......can't wait!!!
  14. Tickety Boo
    Tickety Boo
    from Wisconsin
    Yes, when wire is hooked up gauge shows it is putting out voltage but in a short it time gets hot ( no bearing noise )
    so I think it is grounding out internally.
    At the track the Volt gauge showed it stopped putting out, ( it got really hot ) at high rpm.
    I think it was messing up the msd box, it snuffed out during the burn out ( like you shut off the key ) took a while to get fired up ( like a msd relay had to reset ) then the motor missed under load all the way down the 1/4.
  15. saltflats
    saltflats
    from Missouri
    See there's your problem.....you got all that fancy stuff.....points and a good coil will work good last long time.
    loudbang, 30dodgeboy, Gammz and 4 others like this.
  16. DubG
    DubG
    from Nebraska
    that is if your running it in a chevy and not a ford.... but you didn't hear that from me.
    loudbang, saltflats and Tickety Boo like this.
  17. squirrel
    It's them damn condensers you gotta watch out for
  18. saltflats
    saltflats
    from Missouri
    I have been work with my stash from the late 70s.
  19. saltflats
    saltflats
    from Missouri
    Hey Jackson..... that jig sure was a fun project to get loose ;)
    loudbang and Deuced Up! like this.
  20. wrenchbender
    wrenchbender
    I'm sure it was james last time I used it was uhhhhh let's just say years ago lol but nothing a big hammer five cans of pb blaster probly a torch and lots of swear words wouldnt fix lol I did build that off of a 59 housing though and a 9" so god only knows what mods you will have to do lol
  21. saltflats
    saltflats
    from Missouri
    And a case of beer.
    DubG and loudbang like this.
  22. loudbang
    Music to my ears ;)
    powrshftr, Gammz and DubG like this.
  23. wrenchbender
    wrenchbender
    Just one case lol
    Chrome don't get ya home
    powrshftr, DubG and loudbang like this.
  24. saltflats
    saltflats
    from Missouri
  25. Okiedoker
    Okiedoker
    from Wisconsin
    Hey guys...I know some of you aren't on Facebook, but I thought I would share a few cool things...
    1) The Goodie Bag has set a new bar. Remember, goodie bags go to the first 350 cars that aren't Mustangs.
    2) We have more great giveaways for the racers this year. We have 25 copies of Isky's book that will be part of the giveaway tent for racers...and they will even be signed by none other than the Camfather. We draw car numbers and you win stuff. Like good stuff.
    3) We are going to have some new Meltdown items for sale at the tent. Make sure to get to the tent on Thursday or Friday as stuff goes fast.
    4) I heard that Scott is going to be signing autographs when he puts a whoopin on me....get in line early.
    Have a good one fellas.
    Bugsy48, powrshftr, loudbang and 5 others like this.
  26. grantrobert
    grantrobert
    This will be my first trip to the meltdowns. Does the camping area fill up quick???? If I roll in Friday evening will I still be able to find a spot??? Thanks
    Sent from my SAMSUNG-SM-G930A using The H.A.M.B. mobile app
  27. Gammz
    Gammz
    from Lincoln Ne
    And this email of utter importance....???
  28. Okiedoker
    Okiedoker
    from Wisconsin
    It's coming Gammz.... after I label the beer tonight.
    Settle down before we lose your number... ha-ha
  29. Gammz
    Gammz
    from Lincoln Ne
    I got your number fella......
    powrshftr, loudbang and DubG like this.
  30. wrenchbender
    wrenchbender
    Well Jeff I will be there just after noon on Thursday so no worries about a goodie bag for me cause I don't have a mustang but I do have lots of horsepower in the dragster lol and I'm sure no one will be waiting in any line for #4 lmfao
    loudbang, saltflats and Gammz like this.
