Event Coverage Welcome to the 2017 Meltdown Drags
Discussion in 'The Hokey Ass Message Board' started by Okiedoker, Oct 6, 2016.
  1. Gammz
    Gammz
    from Lincoln Ne
    Flower pot for the house....... [emoji848]
    loudbang and saltflats like this.
  2. saltflats
    saltflats
    from Missouri
    I seen you have spent a lot of time on the Altered thread. ;)
    loudbang, Gammz and DubG like this.
  3. rawcjw19
    rawcjw19
    You don't want one of those big ugly things.All they do is attract cameras,ruin your rear tires,make people stare at you, whine, and make little engines big [emoji3]
    loudbang, 30dodgeboy, Gammz and 4 others like this.
  4. Toymaker
    Toymaker
    from Fresno,CA
    Back to Byron Meltdown to do list!
    * leak down engines
    * change head gaskets on RH engine
    * pin rocker studs RH engine
    * check cam gear RH engine
    * install coolant Puke Tank (been running dry for 1/8th mile but if I'm on a good p*** we're going for the 1/4 mile stripe.)
    * check clutch
    * check ring gears
    * mount new tires
    "Back to Byron" Evil Twin Shirts AVAILABLE!
  5. Rocky - just a heads-up that Byron requires water as coolant instead of (glycol) anti-freeze. Their rule applies to all modified cars, which is everything participating at the Meltdown Drags.
    Toymaker and loudbang like this.
  6. Toymaker
    Toymaker
    from Fresno,CA
    Working on trucks I've trained myself to say coolant[emoji23] Water it is[emoji108]
    30dodgeboy and loudbang like this.
  7. rawcjw19
    rawcjw19
    My 9 inch rear end seems to be puking gear oil out the vent. Is this normal? Or am I about to have a catastrophic failure of some sort? It is a limited slip if that makes a difference.
    48fordor, loudbang and DubG like this.
  8. Fordors
    Fordors
    Now there's a blast from the past.
    Keeping it Traditional to the extreme.
    loudbang and Toymaker like this.
  9. me, too :D
  10. overfilled?
    where is the vent located at?
  11. Finn Jensen
    Finn Jensen
    And the track informed me that it is straight water only. No additives.
    loudbang, Toymaker and 30dodgeboy like this.
  12. rawcjw19
    rawcjw19
    I fill it until it is level with the bottom of the fill hole? The vent comes directly out of thetop of the housing. I have the vent hose about a foot long tied to the body, but it is nearly the same height as the top of the rearend. I do run it kind of hard, and it turns 3200 on the highway
  13. saltflats
    saltflats
    from Missouri
    You may want to use one of those heat guns to see how hot it is after a road trip.
    If you use synthetic gear oil it my help.
  14. squirrel
    plug that vent hole, put a new one in an axle tube?
  15. good
    Sounds to me like the ring gear is throwing the lube at the vent hole and thermal expansion is pushing it out.
    Squirrel is right - put the vent on the tube closer to the spring perch
  16. rusty1
    rusty1
  17. ididntdoit1960
    ididntdoit1960
    from Western MA
    prayers sent......looked like a pretty serious car......given modern safety reqirements, i wonder how/why he was ejected from the car?
  18. The first fire up went smooth on gas. Later in the week after some street miles i will convert it over to nitro for some p***es at the grove. 20170625_185223.jpg The chrysler is ready for on track action this year.
  19. squirrel
  20. BigDrag
    BigDrag
    from Milwaukee
    I'm a little embarr***ed to show you my tiny little engine after seeing how huge Brian's is.
  21. saltflats
    saltflats
    from Missouri
    Thank you guys....I will just leave my **** at home now.
  22. DubG
    DubG
    from Nebraska
    woah woah woah.... I hear you're looking for a race salty?
    wyatt "the Gasman" Gammel
  23. saltflats
    saltflats
    from Missouri
    I got nothin.....
  24. Regardless what you have its going to be a great time for all. Everyone has been working hard to get their cars in top notch shape for the event. Its going to be weekend to remember.
  25. Gammz
    Gammz
    from Lincoln Ne
    Chief engine tuner for the GasMan instead? Only kidding James! You bring that Bel-Air man. That **** is cool. We gonna have fun!
  26. Gammz
    Gammz
    from Lincoln Ne
  27. saltflats
    saltflats
    from Missouri
    Its the truth man.
    I have fretted over the rear end all weekend long.
    For now I have a car that looks like a big wheelbarrow.
  28. Gammz
    Gammz
    from Lincoln Ne
    Your not alone with the fretting!
    loudbang, rocketsled59 and powrshftr like this.
  29. Deuced Up!
    Deuced Up!
    The "NEWnasty" debuted its new look at a local car show Saturday.
    It won first place and then promptly set a new precedence for leaving a car show!
    Check out the second gear AIR!....lol
  30. rocketsled59
    rocketsled59
    I'm sure my time could be put to better use but I'm waiting for parts. Sooo I made up some new headlight blanks. I know , it's trivial but it is cool!
