weld in steering joint ?
Discussion in 'The Hokey Ass Message Board' started by BILLS CUSTOM EXHAUST, Apr 18, 2011.
  1. hey guys i just bought some sweet weld in steering joints i was wondering if you guys tack them in place then dissasemble the joint and finish weld the nuckle to the shaft then re***emble or do you just weld them and pray the grease stays in thanks bill
  2. gimpyshotrods
    gimpyshotrods
    FULLY dis***emble.
  3. I weld about a 1/4" at a time, letting it cool in between welds. Never had a problem.
  4. mrconcdid
    mrconcdid
    from Florida
    I have found pulling the colume out about 2 to 3 inches. start at the rack or box and ***emble to the firewall then slide the colume back into the last joint. I agree with the 1/4 weld/cool technique.
  5. rustyford40
    rustyford40
    from Mass Bay
    Make sure the ground is on the side you are welding. Don't let 100+ amps go through the joint
  6. Bearing Burner
    Bearing Burner
    from W. MA
    I cross drilled and pinned mine. 1/4" grade 8 bolt with vibration proof nut.
  7. I like the cross drill also. Plus I trust a bolt over my weld any day, lol. Just dont tell my customers. Also I have seen the joints wrapped in a wet rag, and left to cool on there own. Thats my $.02
  8. iammarvin
    iammarvin
    from Tulare, Ca
    You wrote this?????And you are in business???Please stop!
  9. bill wallace
    bill wallace
    I imerse the joint in water & leave the portion to be welded above the water. This requires some set-up but protects the bearings in the joint.
  10. roundvalley
    roundvalley
    Thanks Bill. Not pretty but it worked well. Joint stayed cold.
  11. tb33anda3rd
    tb33anda3rd
    i have always used double d and splined joints. what is the benefit of weld in joints?
  12. roundvalley
    roundvalley
    U joint was mated to the end of a '41 column 3/4" round tube. No splines or DD on that end.
  13. gasser300
    gasser300
    from Ft Worth
    I had a good welder do mine then I drilled them and drove a roll pin throught the shaft n joint
  14. Verminator
    Verminator
    If you have a 3/4 SOLID ( not tube ) round column, mill or simply grind down the opposing sides to make it a double D
  15. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    I seriously pity your customers.
    ALWAYS Dis***emble!
  16. mj40's
    mj40's
    Damn! roundvalley, your shop is way to clean. I have a couple friends with mills and they DD them for me.
  17. seb fontana
    seb fontana
    from ct
    Ford column shafts are heavy walled enough to be double d'd..Putting a bolt through may seem like safety but its really a lot weaker than ANY other method..
  18. or you can get someone on the hamb to machine you a solid steering shaft with a double D or splines, the horn wire isn't going to go through the u joint anyhow.
  19. I do the water method.
  20. ParkinsonSpeed
    ParkinsonSpeed
    I soak old cut blue jean rags in water just so if they start steaming you get the idea to chill. I was tought that by an old timer that rebuilt tractors.
  21. Weasel
    Weasel
    Do Not weld steering joints - this from Borgeson's website:
  22. Da Tinman
    Da Tinman
    knew that was coming.
    I weldem, use water, and notch the end to be welded so the weld itself is curved around the shaft. Doesnt take much and its hard to see.
