Weld penetration question...
Discussion in 'The Hokey Ass Message Board' started by Stevie Nash, Apr 14, 2011.
  1. tig master
    tig master
    from up north
    This fellow will get it done
    Tig
  2. Stick welding is still used to this day at Nuclear Powerplants, we have all just become too acustomed to the new, fast, and easy methods for welding. If you get a cheap AC/DC stick machine, now you almost have it all about covered.
  3. No worries, the rear wheel is chocked.
  4. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I personally only use an arc welder 220 .I had a friend that welded his brothers rear pads in ,Lasted awhile and we were driving in front of him and then he spun full 360 rear mount ripped right off and that was a 130 mig,with gas ..............Forklift mechanic by trade ,He went through gm school also ,Hes not a hack......So Id arc,,,,,,,,,,,,
  5. kkustomz
    kkustomz
    from Texas
    Here we go again a few good replies and the rest are the blind leading the blind to weld
  6. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
  7. 28pontiac
    28pontiac
    If you can't weld good, weld allot!?!?!
  8. Kind of fits well with that thread a while back "like to weld with out a hood"
    Oh boy
  9. chopolds
    chopolds
    from howell, nj
    Biggest factor in making it work, probably is the duty cycle. Having the welder cranked up high enough to weld it, you'll have to do the work in small increments, to keep the welder from going over it's duty cycle. But the machine will work in the hands of a skilled welder.
  10. johnny bondo
    johnny bondo
    from illinois
    you can get a 220 stick welder at your local swap meet for less then a case of beer im sure. make yourself up a chord for the dryer plug if you dont have a 220 line in the garage. then you dont even have to worry about it.
  11. buzz4041
    buzz4041
    from Texas
    Welding is kind of like golf. The best golf clubs still won't make you good a golfer. A great welding machine ain't going to make you a welder either but if you practice practice practice you will get better. A good welder can lay that bead for them brackets with a 110v welder with no problem and it be completely safe. The question is do you have the skill to do it ? If not get someone that does.
  12. Rex_A_Lott
    Rex_A_Lott
    Just FYI, Afco ( and Others) makes a split leaf spring pad that clamps around the tube, allowing you to move the rearend side to side, in or out, set the pinion angle etc....and then you weld it all the way around, giving you more surface area than the saddle mounts most people use. If you get a good weld, the problem is not the weld, but the tube itself, it will rip out around the weld. The 360 deg mount makes this less likely.
    Please listen to the guys that say take it to a pro. Good Luck with your project.
  13. davidbistolas
    davidbistolas
    Nice. It's ridiculous that you had to define ludicrous.
  14. I thought ludicrous was a rapper/actor ?
  15. Conniptor
    Conniptor
    from New Jersey
    They're all ludicrous
  16. Stevie Nash
    Stevie Nash
    That's Ludi Chris and his brother Rick Diculous...:cool:
  17. Blue One
    Blue One
    from Alberta
    Yes, it's better than the comedy network isn't it :)
  18. Oh **** I can't stop laughing!
  19. Reminds me of learning to spell with Darnell.
    Hi my name Darnell Williams and dis be learning to spell with darnell.
    Todays word is dictate it spelled like dis D I C K -- T A T E
    now les us it in a sentance . . .
    Oh damn I can't tell the rest of that on the HAMB. :rolleyes:
  20. Von Rigg Fink
    Von Rigg Fink
    from Garage
    That kind of music is like candy..only good with the wrapper gone
    "Rick Diculous"...Hhahahhaha
  21. jdustu
    jdustu
    from Detroit
    "can" and "will" seem to be used interchangeably in these welding threads...
    Personally, I've had welds I've done fail by using a 110 Lincoln MIG on 1/4" . Chances are they would have held under normal cir***stances, but some vicious(and consistent) wheel hop cracked them. The welds may look fine, but you just don't get the same push into the steel as with a bigger machine. Even with multiple p***es, the dig isn't the same. If you go that route, fcaw digs deeper, as has been pointed out.
    Not saying you can't do it, because you can. Just something to consider.
  22. Deuce Daddy Don
    Deuce Daddy Don
    Welding since 1951------About that 110----Don't even try it!!!
