weld thru primer price made me
Discussion in 'The Hokey Ass Message Board' started by camcb, Oct 24, 2013.
  1. camcb
    camcb
    Damn near fell down on the floor at car quest. $32.00 plus tax for a rattle can..... got to be a better buy out there:confused:
  2. 2racer
    2racer
    Seymour 20-1675 Professional Self Etching/Weld Through Primer, Gray
    by Seymour Paint
    4 customer reviews
    <HR><TABLE cl***=a-lineitem><TBODY><TR><TD cl***="a-color-secondary a-size-base a-text-right a-nowrap">List Price:</TD><TD cl***="a-span12 a-color-secondary a-size-base a-text-strike">$12.54</TD></TR><TR><TD cl***="a-color-secondary a-size-base a-text-right a-nowrap">Price:</TD><TD cl***=a-span12>$12.27 & FREE Shipping on orders over $35. Details </TD></TR></TBODY></TABLE>
    http://www.amazon.com/Seymour-20-16...d=1382661763&sr=8-1&keywords=weld+thru+primer
  3. okiewelder
    okiewelder
    from central Ok
    I got a can of it at my local Ace for 6 or 7 bucks a few weeks ago. I cannt remimber what brand it was. Seems to work well.
  4. Russ B
    Russ B
    11.99 for 16 oz aerosol can at Eastwood
  5. mattrod68
    mattrod68
    i looked all over my town for some when i needed it right away, i finally found it at a paint and body supply place--3m for 30 bucks. it hurts but how much do you really use at a time? its gonna go a long way
    still shocked me a bit though
    matt
  6. Autodave
    Autodave
    from Menifee,Ca
  7. GEEZZER
    GEEZZER
    3M always twice as much, but, twice as good.....tape,abrasives,adhesives,sealers, weld thru primer etc.
  8. mattrod68
    mattrod68
    I have found this to be the case. 3m stuff is always pricey but worth the extra
  9. MP&C
    MP&C
    Just use your epoxy primer on both surfaces and clean out the paint from the plug weld hole:
    This is the same size drill bit I used for plug weld holes that has been flattened and backfaced with a roloc sanding disc to resemble an end mill cutter.
    This shows how it works, cleans the paint from the metal surface, but having a flat face on the cutter, it doesn't affect the metal as a regular drill bit would. Notice most of the "chips" are paint....
    And welded......
  10. camcb
    camcb
