Projects Welded quick change rear
Discussion in 'Traditional Hot Rods' started by Kato Kings, Feb 4, 2014.
  1. Kato Kings
    Kato Kings
    from Minnesota
    Here are some pics of my version of a welded quickie. I used a 10 spline pinion and gear set along with a champ lower shaft and 10 spline gears. I have all the parts made, I haven't attempted to weld it up yet. I machined the rear cover out of a chunk of aluminum.
      269.5 KB
      98.8 KB
  2. Kevin Lee
    Kevin Lee
    Super Moderator
    Very nice.
    I have that on my "to do" list someday. I've always ***umed there would be some facing and retruing of a few surfaces once everything was welded up.
  3. deuce354
    deuce354
    Great job!!. That is how the first QCs were made. Good Luck
  4. Looks VERY nice.
  5. flatheadpete
    flatheadpete
    from Burton, MI
    Sweet. I want a quickie bad for my T. Just not in the funds though.
  6. DICK SPADARO
    DICK SPADARO
    Nothing like backyard ingenuity. My suggestion would be to add a case gusset brace to the front jackshaft sleeve as this point is a high load area and you do not need it to flex.
  7. Kato Kings
    Kato Kings
    from Minnesota
    Thanks ****. I plan on a gusset on top of the front tube back to the case.
  8. Kerry
    Kerry
  9. 383deuce
    383deuce
    Any chance you would make one for sale???? If so drop me a message.
  10. mink
    mink
    from CT
    Do you planing on using a custom lower shaft alignment bar. You will be boring after it's welded up? I like this project please share as you progress
  11. von Dyck
    von Dyck
    So, with the Champ lower shaft, you must be running the 3.25" shaft center-to-center spacing along with the larger change gears! Novel approach.
    Keep all of us informed.
  12. Jethro
    Jethro
    Nice work!...how about a few more details / pictures....really like the rear cover!
  13. Kato Kings
    Kato Kings
    from Minnesota
    Yes, I plan on a lower alignmnet bar when welding. And yes I am running the 3.25 center champ gears.
  14. oj
    oj
    I've started on a similar piece and planned to do the lower in a complete heavy tube and cut it out for gear clearance as opposed to 2 seperate pieces. Either way it'll still need machining for alignment. Judging by the cover I'll guess you have the shaft bearings in it? Did you make the cover or is it store bought?
  15. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Just want to clarify, the Champ gear sets are 3.5" on centers.
