Technical Welded stroker crank
Discussion in 'Traditional Hot Rods' started by birdman1, Jul 8, 2020.
  1. birdman1
    birdman1
    I remember seeing welded stroker crank shafts in early hotrod magazines. Any of you guys have any experience with them?
    Deuces and dana barlow like this.
  2. Jmountainjr
    Jmountainjr
    Back then about the only way to get a stroker crank was to weld it up and have it machined. Today you can buy almost any crank combo you want, so like a lot of old things, you don't hear much about welded cranks.
  3. dana barlow
    dana barlow
    from Miami Fla.
    In the 40,50,early 60s there was not much,other ways to get big stroke. Welding up a steel crank worked ,but was a **** shoot in many ways, Welding added str*** an flaws,warped/bent crank=than had to be bent back to straight adding even more flaws. Some lasted amazingly well,knowing how many things can go wrong. We boxed rods too ,to try to made better. But welding on cranks or rods in the end is an was high risk,but lower $ then ****et.
    Now there are Co. that do bullet,cut from blocks for parts with as few flaws as can be,for making big HP.
  4. 1934coupe
    1934coupe
    Birdman it is done all the time especially on cranks for hard to get cranks like early Olds, Caddy, Buick etc. It also enables you to use a readily available rod like BB or SB Chevys.
    Pat
    rladams65 and Deuces like this.
  5. SS Pete
    SS Pete
    Storm Crankshaft Mount Vernon NY. they do welded strokers , this is also to repair rare crankshafts and camshafts. they ship global. Try them.
    Tman, dana barlow and 1934coupe like this.
  6. KJSR
    KJSR
    from Utah
    I used welded strokers in VW's all the time. Never had an issue but also dealt with quality companies.
  7. seb fontana
    seb fontana
    from ct
  8. 1934coupe
    1934coupe
    Everybody uses Storm Crankshaft here in the NE. They have been around forever.
    Pat
    Deuces, kidcampbell71 and dana barlow like this.
  9. MO54Frank
    MO54Frank
    Cool! Sub-Arc (submerged arc) welding. They used this process to weld steel tanks and pressure vessels at the place I worked back in the 90’s.
  10. bobss396
    bobss396
    I saw that in the Ladies Home "Journal"......
    ffr1222k, Deuces and kidcampbell71 like this.
  11. mgtstumpy
    mgtstumpy
    Crank Shaft Co. later became Hank the Crank
    Another old stroker business CT Automotive
    Deuces, Budget36, 1934coupe and 3 others like this.
  12. Dean Lowe
    Dean Lowe
    Left pieces of one all over the Bonneville salt flats in '67.
    Deuces, Tman, belair and 5 others like this.
  13. indyjps
    indyjps
    Similar topic, anyone had journals hard chromed?
    Tool maker I used to work with was telling me about his cl*** racing days, 413's then 426, won a lot of cash on and off the track. They were welding and offset grinding cranks, also hard chroming the journals to run very loose clearances. Said the hard chroming made a difference on the welded journals.
    This was in Indianapolis, could have been companies specializing in it, he was doing his own crank machining and had access to heat treat and normalizing equipment most of us dont.
    Interested if this was done back in the day on a regular basis.
  14. 73RR
    73RR
    Marine crankshaft in the Los Angeles area does welded cranks at reasonable prices...reasonable, as in, not like a custom Winberg piece. I have a left-over 426H Winberg crank, it is oh so nice, but $$$$$.
    I do recall some folks hard chroming cranks back in the 60's but, apparently, not real popular today.
  15. Jmountainjr
    Jmountainjr
    Yes, hard chrome was the in thing for a while and was used a lot on welded cranks. Today nitride hardening is used. The EPA put a lot of chrome applications into the very expensive or no longer allowed category.
    RodStRace and VANDENPLAS like this.
  16. gimpyshotrods
    gimpyshotrods
    My local crankshaft shop routinely welds them up, and pretty cheap too.
    As soon as we are allowed out, I will be dropping off two Hemi cranks, each to get a rod journal touched up.
  17. gimpyshotrods
    gimpyshotrods
    Well, actually, it was the chrome shops, irresponsibly disposing or waste that brought the hammer down on them.
    What made chroming cheap in the past was the exporting of the costs of it, to the environment.
    This is not political, it is psychological. Anyone who thinks poisoning the water supply, so they can get something cheaper, is a sociopath, or worse.
    RodStRace, slayer, Fordors and 6 others like this.
  18. 38Chevy454
    38Chevy454
    Not only the much stricter environmental control costs, but also chrome plating is done in a chromic acid bath. Chromic acid has hexavalent chromium which is carcinogenic.
    Back to op question, I would agree less common now with cheaper offshore forgings that provide common stroker sizes.
    Another way to get small stroke increase is offset grinding the rod journal down to smaller diameter. Usually good for around.
    .125 inches stroke increase.
    Sent from dumb operator on a smart phone
    gimpyshotrods likes this.
  19. Marty Strode
    Marty Strode
    I read up on C-T, Don Clark and Clem Tebow, one of their young employees who was great at welding cranks, was Kent Fuller. The flathead pictured was 352", via a Crankshaft Co. 1" stroker. Set the NHRA record in '62. Johnnie Hart D/D. 2012-07-28 110444.jpg
    alanp561, Deuces, Tman and 4 others like this.
  20. Jmountainjr
    Jmountainjr
    In no way was I suggesting that the EPA's actions were wrong, or not warranted. They addressed something that needed fixing. For me it was a short way of explaining the reason you don't see many chrome operations today, which was the OP's original question. Just like changes in leather tanning, oil disposal, trash management, etc.
  21. 19Fordy
    19Fordy
    Seb, Thanks for posting that video.
    Is that called submerged arc welding?
    Deuces likes this.
  22. dreracecar
    dreracecar
    from so-cal
    My Olds has a 1/2" stroker, welded and offset ground for smaller rod bearings
    Deuces and 1934coupe like this.
  23. gimpyshotrods
    gimpyshotrods
    Yup. That's what it is.
    Deuces likes this.
  24. alchemy
    alchemy
    A 1" stroke on a 2" journal means that half the journal is weld, right? How long would something like that last? And I'm ***uming they had to grind a huge notch in the bottom rails of the block, so it was probably filled.
  25. Marty Strode
    Marty Strode
    Here is part of the Hot Rod article from Oct. 62. I made a mistake, it was 354" !!!! IMG_5133.JPG IMG_5132.JPG IMG_5134.JPG IMG_5135.JPG
    Deuces, Fordors and Desoto291Hemi like this.
  26. Marty Strode
    Marty Strode
    Maybe I am missing something here, you only need 1/2" offset in the crank to achieve 1" of stroke.
    55willys, alanp561, ottoman and 3 others like this.
  27. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Right Marty,
    You move the center line of the rod journal out 1/2". You would need to have 1/2" of weld on the outer side to grind down to the proper rod journal diameter.
    I have seen this done two ways:
    Offset grind the journal down until it is round, then weld it back up to the new stroke. This keeps the final surface the same depth and material around the entire cir***ference.
    The other way is to just lay weld on the outer half of the journal and then grind it on the new stroke radius. This leaves a weld line (visible or not) on each side of the journal.
    My guess is that the first way is stronger, but what do I know?
    Desoto291Hemi and pitman like this.
  28. dreracecar
    dreracecar
    from so-cal
    Back in the day when it was popular, cars were not going as fast as they are now and didnt have traction that would put a load on the driveline either
  29. Pete1
    Pete1
    from Wa.
    The first way was the common way. I made 2 in the early 60's.
  30. johnny 5
    johnny 5
    from Missouri
    I've been looking into this for at least a year. I've only found 2 shops that will still do a welded stroker crank, and 1 of them was over $2500 for a 3/4" increase. The one I'll go with is just over a grand if my motor doesn't sell.
