Art & Inspiration Welder carts
Discussion in 'The Hokey Ass Message Board' started by VonMoldy, Oct 11, 2015.
  1. VonMoldy
    VonMoldy
    from UTARRGH!
    I am looking to build a cart for my new TIG welder and want to do something fun and cool looking with it.
    Show me the coolest welder carts you have built or seen plain but functional to wild.
    ace5043 and Larry W like this.
  2. Paul
    Paul
    Editor
    my mig is on a simple cart made from a surplus shopping cart, the tig is stationary and parked under the bench.
  3. X38
    X38
    Ditto. But once I modified everything there wasn't much left of it other than the base frame and castors!
  4. oj
    oj
    Welder cart for TIG? Here'ys go the Daddy of them all:
    The Miller 330A/BP sitting on industrial 30gal watertank/cart with a 220v water pump. It's a tussle to get that big rig movin but once in motion it handles easily. I probably have about a 30' supply cable and the outlet is near the middle of the shop.
    Just Gary and Larry W like this.
  5. Just Gary
    Just Gary
    And at the opposite end of the spectrum is the fly-weight cart I made when learning to MIG. It uses lawnmower wheels & handle. The "lightening holes" lower ETs and improve gas milage. ;):rolleyes:
  6. iwanaflattie
    iwanaflattie
    Weird I also used Castors (us)..just gotta keep them away from the poles.
    gimpyshotrods and falcongeorge like this.
  7. Mr48chev
    The one that you (Vonmoldy) showed is nifty looking but personally I don't want a bench grinder anywhere close to my welder and it's magnetic field. I can see the bench grinder with a tig where you need to sharpen the Tungsten on a regular basis though.
    Mine is built on the frame of one of Those little convertible hand truck/cart things that I picked up at a yard sale years ago. It isn't fancy enough to show a photo of but it holds the welder, tank and my angle grinders. I still need to rig a drawer for the expendables and small tools that go with it.
    38 mopar_fan likes this.
  8. V8 Bob
    V8 Bob
    I built this mig/stick/gas cart back when garage space was premium many years ago. The piggy back oxy cart "steers", but can be removed with one bolt, and a 50' cable allows stick welding outside the shop.
    36 ROKIT, Perk74 and VonMoldy like this.
  9. blue 49
    blue 49
    from Iowa
  10. VonMoldy
    VonMoldy
    from UTARRGH!
  11. VonMoldy
    VonMoldy
    from UTARRGH!
    Hey check this out! Really cool.
  12. Mr48chev
    Someone good with a tube bender put that one together.
  13. VonMoldy
    VonMoldy
    from UTARRGH!
    I got a tube bender and never used it yet. This might be a good project for it.
  14. nmpontiac
    nmpontiac
    from Taos, NM
    I made mine from a little cart / table I got at a yard sale................ DSCN1443.JPG
  15. aaggie
    aaggie
    I have the factory accessory cart that was included when I bought my Lincoln MIG and my Lincoln Precision TIG 225 has casters on it from the factory. If you go to WWW.WELDINGTIPSANDTRICKS.COM, Jody Collier did a multi part video on building a slick cart and the video is in the archive.
    VonMoldy likes this.
  16. shopdawg
    shopdawg
    from alberta
  17. MP&C
    MP&C
    In my shop floor space is such a premium that I need a real good reason for any machinery that is taking up space.. So when it came time to make a welder cart, it was made vertical to save that floor space. Tig, Mig, dent puller, and spot welder with timer..
    Build thread....
    http://www.garagejournal.com/forum/showthread.php?t=268777
  18. 36 ROKIT
    36 ROKIT
    Yeah, I'd say that cart has a Vertical theme going....!
  19. VonMoldy
    VonMoldy
    from UTARRGH!
    Cool I will check this out I love that guy.
  20. VonMoldy
    VonMoldy
    from UTARRGH!
    Holy crap. aWesome.
  21. rooman
    rooman
    I am about to build one that I can take to the nostalgia drags. At the big events I have been borrowing to one owned and built by Steve and Ernie McClain when I have been asked to do repairs but I want to put something together for the NDRL series and other races that run in the midwest. I am going to follow their example and put a nice thick top on the cart to clamp to and it will also have a vise. 10" o.d. pneumatic tires on one end and casters on the other along with handles on the castor end to get it over rough spots in the pits. I have an AHP inverter welder that will run on both 220 and 110 so I should be able to plug it into just about anyone's power source. The McClain's unit has a Miller Dynasty which is great but it needs 220 volts and at times I have had to borrow their generator as well. I have most of the pieces and will post photos once I get it together.
    Roo
  22. 340HilbornDuster
    340HilbornDuster
    The wire wheel was a later addition - I copied someone here at HAMB...works awesome!
  23. 56sedandelivery
    56sedandelivery
    No photos, but , my cart is a repurposed audio/visual department cart tossed out by a hospital I used to work at, so it was free. It has three shelves, all slanted towards the front, with a lip all around the shelves so things can't just slide off. It holds my 220 buzz box Craftsman arc welder, 220 mig, 110 mig, and since my oxy/acet is just a small setup, that fits too with the bottles lying flat. There's still room for electrodes/rods, wire, cables, helmet, and a box of tools. Only downside is it's kinda too big, but is on casters. A sheet covers everything up to keep dust off. I am Butch/56sedandelivery.
  24. RidgeRunner
    RidgeRunner
    from Western MA
    Storing the bottles flat is very bad practice. The acetylene bottle should only be used vertical after being vertical for considerable time for the acetone to settle and remain in the bottom.
    Yes, I've transported, stored, and used 'em horizontal and gotten away with it but that was when I was still young enough to think I knew everything.... May be a cynical old fart now but I realize just how lucky I was to make it this far.
    Transport, store, and use 'em vertical!
    Ed
  25. Beanscoot
    Beanscoot
    Large wheels or casters so that it's easier when rolling it outside over lawn or rough pavement.
  26. 56sedandelivery
    56sedandelivery
  27. Stumbled on this
    Down and dirty.
    Bandit Billy and VonMoldy like this.
  28. VonMoldy
    VonMoldy
    from UTARRGH!
  29. VonMoldy
    VonMoldy
    from UTARRGH!
    Awesome! The wheel is a great idea for keeping cables tidy. Also bonus points for the cat.
  30. iwanaflattie
    iwanaflattie
    I know i know old thread.
    Just made this.
    hrm2k, 37 Millrat, saltflats and 6 others like this.
