Technical Welding a cracked block
Discussion in 'The Hokey Ass Message Board' started by ERguitar, Oct 31, 2020.
  1. junkman8888
    junkman8888
    When my brother and I were in grade school a friend of the family gave us a '60 Chevy hard top with a 283 and four-on-the-floor to play with. We'd been told the engine had frozen and busted finding a "T" shaped crack on both sides of the lifter galley when we removed the intake, a welder friend had us "V" the crack out with a cold chisel then when he was satisfied with our work he got busy with a pipeline special welder and some 6011 rod, he'd weld an inch or so and I'd peen the dog-slobber out of the weld with the pointed end of a slag hammer. After the welding was done we reinstalled the intake, changed the oil, filled the radiator with water and a can or two of stop-leak both us brothers using that poor innocent car to learn how to drive. Unfortunately, grandpa caught us engaging in "spirited driving" selling the car before we got hurt. Best of luck with your project.
    KiWinUS and kidcampbell71 like this.
  2. lippy
    lippy
    from Ks
    Peening the weld is the answer. It compresses the metal. capish? lippy
    kidcampbell71 likes this.
  3. deathrowdave
    deathrowdave
    from NKy
    Your repair is as good as if God sent it to that way
    saltracer219 and 2OLD2FAST like this.
  4. tubman
    tubman
    I personally like your repair. I hope it works well. As others have said, keep us in the loop; you may have discovered a new technique.
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    Or stumbled upon an old one !:D
    waxhead likes this.
  6. TCTND
    TCTND
    When it is brazed the the two metals blend into an alloy at the interface to form a contiguous part. Screws are still seperate pieces of metal.
    saltflats likes this.
  7. deathrowdave
    deathrowdave
    from NKy
    I was a Stationary Engineer by trade for 35 years . We will be long gone before any dissimilar metal issues arise . I saw and worked on 1000s of br*** fittings screwed into steel and cast iron . Seems to be a different outcome when the fittings are buried
    kidcampbell71 and saltflats like this.
  8. J'st Wandering
    J'st Wandering
    Looks like a good repair.
    The crack probably was a result from freezing. It is in a none stress area, except when it freezes ;). Anything filling the crack would probably work. Your fix looks as traditional as it gets. We have a tendency to overthink the problem.
  9. 1946caddy
    1946caddy
    from washington
    Peening expands the weld.
    lippy likes this.
  10. Boneyard51
    Boneyard51
    Looks like an excellent repair! I’m betting you will have no problem with it.
    There was a machinist , here in Muskogee, that used to repair stuff with that lock and s***ch method with great success. But his loc and s***ch set used 1/8 inch steel pipe thread plugs. That way the plugs “ wedged” in to the metal on both sides of the crack.
    Bones
    2OLD2FAST likes this.
  11. sunbeam
    sunbeam
    I have repaired many 8n Ford tractor blocks with freeze cracks drill the ends of the crack V the crack and braze it. If it seeps after go with water gl***. My neighbor has one that I fixed 30 years ago.
    kidcampbell71 and Boneyard51 like this.
  12. tubman
    tubman
    Back in the day, we wouldn't even wo rry about fixing that. Just buy another bottle od "Stop-Leak" every couple of months and fill the radiator up when needed.
    Boneyard51 likes this.
  13. BigChief
    BigChief
    Belzona epoxy systems.
    Makes JB Weld look like Silly Putty.
    Sent from my SM-G950U using The H.A.M.B. mobile app
  14. I have a br*** fitting screwed into a block and it doesn't leak....
