welding a pitman arm
Discussion in 'The Hokey Ass Message Board' started by brekteffect, Jul 5, 2009.
  1. brekteffect
    brekteffect
    I'm using a '56 f-1 box in my '27 roadster and I have to cut and reweld the pitman arm to get everything were it needs to be. Anyone have experience with this? Just curious what your opinion on welding pitman arms is. Had any problems? Any pointers? I'm having someone whos been a welder there whole life do it for me so there wont be any problems with weld quality. Thanks
  2. Sando
    Sando
    from Burbank CA
    Post a picture so we can see what the problem is...cutting and re-welding shoud be the last resort. Alot of times you can solve the problem with heating and bending.
  3. Send me a pm and we can talk. Ill give you my #, its not hard but not for the person who cant weld or has no real torch. I have done it sevral times but theres a sience to it so it dont break and kill any one.
    Brian.
  4. Brickster
    Brickster
    He should know better than to weld a steering arm. There has to be another solution.
  5. TagMan
    TagMan
    I needed to extend the pitman arm on my '46 Chevy 1/2T 1-1/4". I obtained two arms and cut them so they would form the total length I wanted plus about another 1" or 1-1/4" (I forget exactly how much) and z'd em so there'd be overlap for maximum weld area. I also ground a generous chamfer on the edges to be welded for maximum penetration, tacked it in position and took it to a professional weldor for the final welding. I have a welder and and do pretty respectable work with it, but a pitman arm is critical. I'll have my wife riding with me and p***ing thousands of people with wives & kids in their own cars. I wanted to make certain it was welded perfectly.
    The extral length (or decreased length) with change your steering ration and effort, so take that into account, too.
  6. brokenspoke
    brokenspoke
    Rat Rod in the works
  7. mj40's
    mj40's
    If he is a friend, he won't do it. Period!
  8. RAY With
    RAY With
    I Have cut and welded many pitman arms on race cars in the 50's 60's and into 70's to change ratio. It's not a big deal if you know how to weld. I usualy put a piece of 1/8 round stock around the outer area and form & weld it as an additional safety measure. Never ever seen one break or bend. It's no different that building a racing ch***is or installing a roll cage. Done right you dont have any problems.
  9. fab32
    fab32
    If you think that this can't be done safely you need to get out more. A certified weldor and the right technique will make a pitman arm that is as safe as an origional forging.
    There are probably thousands of steering arms that have been shortened or lenghtened for race cars in the past 100 years by having them welded. Like anything else there is a right way and a wrong way to achieve a good result.
    Frank
  10. 325w
    325w
    Shortened one on a 29 A and used the F 1 steering and it is still working good 24 years later. The weld was tigged.
  11. jim_ss409
    jim_ss409
    I've also done it. I can't comment on the particular pitman arm that brekteffect is talking about but in many cases you can weld and re-enforce a pitman arm in a way that makes it stronger than new.
  12. chaddilac
    chaddilac
    I cut my 57 pitman arm and rewelded it! no big deal... it's forged so welding is fine!
  13. 69fury
    69fury
    from Topeka
    i needed to add material for a second hole on the p***enger side steering arm to receive the drag link (converting side steer to cross steer)
    My machinist said he'd done many steering arms/pitman arms and back in the day they used arc welders with "super missile rod'. I found out that this rod is now known as "super 600" and is the real deal. $50/lb, instead of $12 for 5lbs, but the stuff works fantaaaastic.
    so, yeah if you do it right, you can weld anything.
  14. Hackerbilt
    Hackerbilt
    You can buy a tierod end for the right side with a tapered hole in the side of the shaft. The tierod from the pitman arm goes into it instead of using the usual extra hole on the right spindle arm...no welding involved.
  15. Brickster
    Brickster
    I'm not saying it can't be done but building a car for the street is different than building a race car. In a world where everybody is looking to cash in on something I'd be a little shy of welding steering components.
  16. 69fury
    69fury
    from Topeka
    please tell us where you received your Metallurgy degree. I really want to commend them on teaching you that that forgings cannot be welded.
  17. teddisnoke
    teddisnoke
    from So Cal
    I certainly understand concerns about welding steering linkages. Welding on a "forged" piece is a dream to work with. If correctly done, as in grinding down and performing a fillet weld, it really should be as good as original, if not slightly stronger as the the filler metal, wether its arc welded ,mig welded , or tig'ed, is of a higher, usually more stringent quality. I've personally re-welded sectioned straight axles, pitman arms, and most of my altered wheelbase projects have pieces salvaged fromt the original suspensions cut, ground, and re-attached, and all have seen years of dragstrip, open road, and deep pothole use.
    Castings, on the other hand, might be suspect. I"ve never taken on a customers "cast" piece to weld on. Who knows what they used... Pot metal?? Of this stuff I'd be suspect. And for sure use caution... But, getting back to older, forged pieces. I love working on these, as they really are a joy to weld!! The metal's great!!
    http://public.fotki.com/bowtie0069/shop-projects-1/funnycarfarmproject1/img3013.html
    Everyone's advise here is definately good!! But, if you have found someone who is an adept, confident welder, maybe even has a few certifications under his belt, you really should have no problems. Good luck!!
  18. chopt31
    chopt31
    pre heat it first, weld it, then submerge it in floor dry, pour floor dry in a pail then bury arm in it, let it cool slowly
  19. Hackerbilt
    Hackerbilt
    Which ones are cast? All the ones I'm familiar with are forged steel.
    I fully agree that its best to avoid it if possible...but sometimes it isn't.
    It's certainly not a job for a guy in his backyard with a 110 MIG...but its not a big deal for a licenced Weldor/Fabricator. Why do you think those guys go thru certification etc?
    Our lives are constantly dependant on the abilities of Weldors due to their work on buildings...elevators...staircases...cranes...you name it.
    They are craftsmen and I really don't think a pitman arm is beyond their capability.
    Bottom line: Don't judge others based on your personal limitations...
  20. 100PercentKulture
    100PercentKulture
    The Pitman Arm I made for My 29 is half F100 and half Mavrick 49,000 miles rock solid.
    You can see the Pitman arm over the 49,000 miles and 16,000 other pictures at 100percentkulture.com
  21. wheelbilly
    wheelbilly
    Builder friend of mine has welded many a pitman arm on rock crawlers. Those see quite a bit more force then an arm on a hot rod. I've welded on forged inner C's on an axle, as mentioned it welds like a dream.
  22. 69fury
    69fury
    from Topeka
    no one's saying to grab the battery cables and a silver dollar: we're just stating that if he takes it to a certified welder, he's not going to automatically come crashing through your family room at 60 mph.
  23. brekteffect
    brekteffect
    Thanks for the input, I know its been done alot and I figured no one ever had any issues, If done properly. If its done right it should be just as strong as the original forge. I may be able to just bend it if its not too far off. So welding will be plan B. Just wanted to hear it from the people who have done it I guess. And Im pretty sure that a '56 gear with a steering arm modified for proper steering geometry doesnt make it a "RAT ROD"
  24. lippy
    lippy
    from Ks
    What are you asking? Can I weld my pittman arm? Yes you can. Can I weld my pittman arm and it won't break? Maybe. Will I be responsible if it breaks after telling you that you can weld it?............nope. ;)
  25. brekteffect
    brekteffect
    So I should buy parts from someone I dont know that have been produced from god knows what and welded buy the chineese when I can have a certified welder with 30 years under his belt weld original parts?
  26. lippy
    lippy
    from Ks
    Sounds like your mind is made up already. Have the welder guy weld another one and do some destructive testing on it. You know, put it in a big vise and beat the **** out of it with a 50 lb sledge. If it p***es, then have him weld the one your gonna use. Lippy
  27. lippy
    lippy
    from Ks
    Hi James, yeah, sometimes us old ****ers have some weird ideas. Ah, usually works out though. :p In other words, bring that ****er over to my house, I'll tell ya if it's worth a **** or not. :D
  28. KUZTOM
    KUZTOM
    Here in NZ ,we are just not allowed to,even heating and bending is frowned upon,or you wont get certification !
  29. lippy
    lippy
    from Ks
    I didn't know you guys had torches in NZ. Just kidding, just kidding.:p I hope your a good sport.:D Check out my board name.:D Ok, I'll save you the time, yes we still have cowboys and Indians in Kansas.;)
  30. KUZTOM
    KUZTOM
    HAHA:D, my miss's nick name is 'Lippy' ,so im use to it:p
    America has everything, its just always 'bigger' !:D
