Not exactly on topic but definitly part of the hobby . Was quiet at work today so took the time to practice my mig welding which is something I have minimal experiance in , so you could probably call this my first real attempts . Some are ok some are junk . My best attempt of the day , must of been a fluke couldnt repeat it . Just got to keep practising . I am wanting to get a Tig machine to learn that aswell . I know its not hotrod stuff but hey I thought I would post it anyway .
how is that not hotrod stuff . Good welds are essential to longevity and safety. Just keep practicing, looks good.
A good LOOKING weld is not necessarily a GOOD weld. Full penetration is the most important aspect of welding, not a pretty weld. Weld on some s**** pieces and cut them apart (perpendicular to the weld) and see if you got complete penetration. If not, change the machine's settings or your methods until you get a complete weld. After that you can work on having pretty welds. My 2¢
think "setup and root p***" go from there. lincoln has good wesite with info on mig welding. always have proper ventilation, respirator and eye protection. there was a thread on mig welding and how it's effects shorten your life.
More junk from today My attempt at tig with a scratch start pretty bad , those scratch starts are a bit of a pain , cant wait to eventually get the chance to use a pedal tig .
And when I say my junk im not actually calling it junk im just joking , its all learning and practice .
Hey there Mooseman, I arced a couple of brackets (4mm) for the A Coupe the other day, and I must say I ended up redoing them with oxy/ecetelyne at work as I was ashamed to say that I arced them. Kiwi Helrod
Mooseman, Yeah they came up a beaut as I'm a far better gas welder than arc. To be honest I've never even tried mig.... shameful isn't it. Kiwi Helrod
shamefull I dont think so , I cant say I had seriously tried mig either untill yesterday though I am only 21 , Most of my welding history has been gas and stick nothing special though just me messing around making little things out of s**** nothing serious .
tag man is 100 percent correct. penetration is key you should be able to watch both sides of the parent metal braek down when you are gooing along
