Welding for the first time
Discussion in 'The Hokey Ass Message Board' started by 53kemper, Jul 9, 2010.
  1. 48thames
    48thames
    from so cal
    Not trying to high jack this thread, but It was mentioned in this thread that if the weld doesn't look right,they would grind it back down and reweld it. I asked about this before in different forums and was given a couple different answers. Some say big no no because you weaken the metal around it, and I have also heard that you can grind and reweld more then once on mild steel with no problems.
    With all the great welders on this thread,thought I would throw this question out there.
  2. TagMan
    TagMan
  3. 53kemper
    53kemper
    Put .35 wire on and practiced yesterday. I was able to slow down and get really nice bead with good penetration. I adjusted my gas a little and it seemed to help alot. Once I was able to fine tune the machine I was laying some very nice welds. Feeling alot better now. Thanks for all the help guys. I plan on practicing everyday.
  4. flatheadfreakv8
    flatheadfreakv8
    i would switch to .30 or .35 wire. Remember practice makes perfect.
  5. crminal
    crminal
    Totally agree with exwestracer. When you practice, make sure you can watch what the "puddle" is doing. You will learn to see if it undercuts, builds, the pattern of your "weave" by looking at what is happening with the puddle.
    Go slow when practicing, do "the miles" and you will be on your game.
    Good on you for sharing what you have done and for be willing to continue learning. My 2 cents.
    Bryan
  6. Francisco Plumbero
    Francisco Plumbero
    from il.
    Welds 1 and 2 look OK, welds 3 and 4 look like you did not have good heat, you did not have good penetration, clean them and do a hot s***ch p*** over that first bead, slow down and get a good puddle going. If you can run a p*** on the reverse side of those parts please do. Thanks.
