Welding Heat Sink/Dam
Discussion in 'The Hokey Ass Message Board' started by Nick P, Jul 6, 2010.
  1. Nick P
    Nick P
    from Texas
  2. aaggie
    aaggie
    It may work but nothing beats trimming the panels to fit and doing short tacks until the seam is complete. Take your time and don't overheat the joint. Hammer and dolly as you go to control shrinkage.
    Patience Grasshopper.......
  3. HomemadeHardtop57
    HomemadeHardtop57
    the stuff works well
  4. John_Kelly
    John_Kelly
    You cannot avoid some warpage when welding since the weld always shrinks the metal. That stuff is next to useless as far as I'm concerned unless used to protect chrome or something near the weld. I wouldn't worry too much about over heating the weld either. There is no such thing unless you blow through or undercut. When mig welding, weld as hot as possible in short zaps. Gas or tig welding, weld a few inches at a time then hammer and dolly. This article might help:
    http://metalshapers.org/101/jkelly/index.html
    John www.ghiaspecialties.com
  5. Unkl Ian
    Unkl Ian
    Jim Bailie uses a spray, forget the name.
  6. zzford
    zzford
    Right Guard?
  7. A little trick I use is to tack everything together, then skip around and do small stitch welds. To prevent warpage I will keep a wet rag to quench as I go. Yes that does crystalize the weld, but on sheet metal it dosent make a difference. On anything thicker, air cooling is the only way to go. It just a different way comapred to the Eastwood stuff.
  8. wildearp
    wildearp
    from tucson, az
    Tons of tack welds. I have done lots of panels without any of that stuff you mention.
  9. Francisco Plumbero
    Francisco Plumbero
    from il.
    A lot of far tacks followed by closer and closer tacks and then to short seam joints, that stuff is unnecessary you may as well use the Right Guard, be patient, I wouldn't use the water, some guys like it.
