Hot Rods Welding Helmet Vision
Discussion in 'The Hokey Ass Message Board' started by flatford39, Aug 28, 2019.
  1. 41rodderz
    41rodderz
    from Oregon
    I have decades of welding with a large front face shield. A subtle nod and away I go. Do wear those skull caps though. :D
    alanp561 likes this.
  2. Man that's funny. I'm laughing too, but not at you, with you. I've done a lot worse. Thanks for sharing.
  3. guthriesmith
    guthriesmith
    Thanks for posting. I have recently been trying to figure out what to do about a helmet. It has been several years since I welded much but recently had the need to get back at it and I even bought a new mig. The main thing I have noticed is that I can’t see anything anymore through my helmet. Part of it is overspray on my lense...but I think my biggest problem is older eyes. Between not being able to see up close anymore and lack of light making that nearly impossible, I have learned a lot from the responses here.
  4. Thanks for sharing your story, it was my morning laugh (with you). Wait until you start counting your mistakes at 76! My philosophy is, that it isn't the mistake you make so much as the recovery.
    So you think you have a problem now at 50, wait until you are 76. My vision is still good enough that I don't require gl***es, but the big problem, is that my eyes are so much slower to adapt from dark to light and vice versa. To compensate for this problem, as one of the other posters mentioned above, I have been using the trick of welding outside with the sun behind me for years, but now even that is only adequate.
    I have been using one of those halogen shop lights to light up my projects whenever I can. That does help make a difference.
    I have been using an auto darkening helmet for around 15 years, and it was tremendously helpful, particularly when arc welding. I don't even have to lift the lid to see the seam before striking the arc. I keep the batteries fresh, and have never received a flash, nor have I suffered the symptoms of a flash. (I do know what it feels like, and there are few things more painful).
    I have some small LED flashlights, so I am going to mount one on my helmet to see if that improves things for me.
    When my garage is done, I hope to get a whole bunch of welding done this winter.
    Bob
  5. Joliet Jake
    Joliet Jake
    from Jax, FL
    Back in the 70's all we had were the large and small fixed shade lens hood. Decades later, I went through several full auto HF quality hoods (they all died) before I finally purchased the top of the line Speedglas 9100 hood 8 years ago, it was worth every penny! They have cheater lenses available that fit right in.
  6. Blue One
    Blue One
    from Alberta
    New from Miller.
    R A Wrench and Flathead Dave like this.
  7. Atwater Mike
    Atwater Mike
    Now, this is what I went to my welding shop and asked about. (6 years ago!)
    I ended up buying 2 of the advertised Bell & Howell brite flashlights, and bracketing them on the LOWER sides of my good helmet.
    The weight of these is 'notable'. Might be good exercise for my neck!
    Great posting, Blue One! Pretty sure I'm gonna get this kit, $40. Just right.
    Blue One likes this.
  8. aaggie
    aaggie
    I'm 75 and wear tri-focals. Even my high end helmet with large lens doesn't work well overhead or out of position so I took my gl***es prescription to the local Walmart and had a pair of gl***es made with the whole lens as the bi-focal. It works great and I can get up close for TIG welding.
    Dino 64 likes this.
  9. Dino 64
    Dino 64
    from Virginia
    I’ve been in the optical business for 40 years, this exactly the best option. If you measure the distance from the work piece to your helmet, you can have Rx made just for that distance. I made up this light from the top of a pen light, worked great till it melted ![​IMG]
    Just Gary likes this.
  10. 41rodderz
    41rodderz
    from Oregon
    What shade # are you guys using in a fixed lense helmet ?
  11. Blue One
    Blue One
    from Alberta
    I use # 9 for everything :D
  12. 41rodderz
    41rodderz
    from Oregon
    #9 here forever. #11 I might as well have sprayed the lense with black paint.
  13. flatford39
    flatford39
    Went out today and used it. It was like night and day. I didn't even wear my gl***es. I could see the puddle clearly and was able to drag it along easily.
    I did have some difficulty trying to push it and I think I suspect I need a different motion. When I drag it I just use a simple circular motion. What motion do you guys recommend to use when you push the puddle.
    Thanks for bearing with me here.
  14. warbird1
    warbird1
    Just wait until someone paints the lens in your welding helmet black...
    I've used a H/F auto darkening helmet for years on stick and MIG without a problem. Tried it on TIG and saw spots for hours. Buying a new Miller helmet with 2X cheater made all the difference...
  15. Flathead Dave
    Flathead Dave
    from So. Cal.
    "Hi...My name is Dave and I can't see when I weld...Hi, Dave! Take the film off of your lens"...
    Sent from my SM-G930T using The H.A.M.B. mobile app
    alanp561 and LOST ANGEL like this.
  16. TRENDZ
    TRENDZ
    Im trying to figure out how a flashlight helps.
  17. TRENDZ
    TRENDZ
    Not being snarky, just don’t get it.
  18. Dino 64
    Dino 64
    from Virginia
    Just for making sure the wire (mig) is exactly where I want it before I pull the trigger. Obviously useless once the arc is struck
  19. Budget36
    Budget36
    Clean cover and a magnifier behind it...seems like every few years I get a bigger magnifier. I'm up to 2.5 now.
  20. 56don
    56don
    If there is a thread on just the stupid stuff we have done over the years, it would be a million posts long!
    metlmunchr, Just Gary and BamaMav like this.
  21. Budget36
    Budget36
    Stick or wire?
  22. flatford39
    flatford39
    MIG wire
  23. deathrowdave
    deathrowdave
    from NKy
    This sounds like a prank that was done to me and then p***ed on for years pipelining . A piece of carbon paper between the filter and the cover plate will drive you completely nuts for a bit until you determine what has happened to your vision .
    warbird1 likes this.
  24. David Gersic
    David Gersic
    from DeKalb, IL
    I put one here.
    It helps some. I need a bigger window helmet, though. Can’t line up the progressive lens with the helmet view to be able to see what I’m doing.
  25. David Gersic
    David Gersic
    from DeKalb, IL
    It adds light from a different angle.
  26. Charlietruck62
    Charlietruck62
    x2
    dirty old man likes this.
  27. southcross2631
    southcross2631
    I wear bifocals and with my gl***es I can never get the right focal length. So when I weld I take my gl***es off. The light on the helmet trick works great.
  28. David Gersic
    David Gersic
    from DeKalb, IL
    I envy you. With my gl***es off, I can’t even see the inside of the helmet.
  29. mgtstumpy
    mgtstumpy
  30. jnaki
    jnaki
    Hello,
    It has been quite some time that I last welded anything. Our welding history goes back to the teenage days in the metal shop and auto shop. But, I always felt my vision was hindered by those pitch black drop down welding helmets in those high school cl***es and before that, the dark, space goggles that my brother gave me to use, when first starting the welding process in our backyard hot rod garage.
    I could lay down a good two inches of beads and join metal plates. But, after that time, the darkness got to me. I did not want to burn down the garage or get a nice hot bead on my arm. So, I let my brother do most of the welding in the last months of building and racing.
    My last welding project for our 1940 Willys Coupe was the m***ive amounts of steel plates, neatly cut and welded over the rear axle of the trunk. It was now part of the structural floor board for ch***is support and rigidity. (We needed some extra weight to compensate for the 292 SBC with the new 671) It was legal to use if they were welded and not bolted in, according to the tech inspectors. So, that allowed us to fit into the C/Gas Coupe cl***.
    Jnaki
    Jump up many years and with the advent of LED lights, that would have made the darkened gl***es or helmet wonderful. The whole welding projects would have been lit up and the dark lens still protecting my eyes. It was just a little bit too late for me. So, the new tech would have eliminated the problem way back then… But then, it would not have been the experimental 1950s-60s.
    https://www.jalopyjournal.com/forum/threads/shop-safety.1142140/page-2#post-12991153 WELDING DARK LENS
    https://www.jalopyjournal.com/forum/threads/protect-your-eyes.1043859/page-2#post-11824739 WELDING BEADS LENS
