Technical Welding on a rear end housing
Discussion in 'The Hokey Ass Message Board' started by nochop, Aug 26, 2023.
  1. nochop
    nochop
    from norcal
    Anybody have, or can you weld 1/4 20 weld studs on a fully ***embled rear end housing? Fully loaded and full of 90wt. I’d like to add 2 to attach brake line clamps. Welder is a 211 Miller mig. Thanks.
  2. Bandit Billy
    Bandit Billy
    If you know what you are doing and control the heat it is not a big deal. Emphasis on the former.
    lucky ink and LWEL9226 like this.
  3. lostone
    lostone
    from kansas
    A couple small tack welds like that wouldn't bother me.
    Although if it were me I'd just tack a couple small tabs on much like the factory did.
    Just Gary and caprockfabshop like this.
  4. caprockfabshop
    caprockfabshop
    ^Yep, as long as you're only doing spot welds, then there's nothing to worry about, the housing is so thick the temp of the liquid inside won't get too hot.
    nochop likes this.
  5. nochop
    nochop
    from norcal
    Just because I have a good welder, doesn’t make me a good welder…..so a few tacks should be ok. I’ve done quite a few sheet metal repairs with no problem. Thanks.
    Bandit Billy likes this.
  6. nochop
    nochop
    from norcal
    That’s what I’m thinking as well, but it never hurts to start a conversation, thanks.
  7. deathrowdave
    deathrowdave
    from NKy
    Maybe think about drill and tap the tube , they are plenty heavy enough to drill and tap . Lock Tight will seal up the threads and prevent leaks . A couple tacks will do the job also , only issue I can see is if it’s painted nicely , your going to loose some , from cleaning , preparing then tack welding .
  8. Happydaze
    Happydaze
    I'd be inclined to weld on a couple of small blocks which have been pre drilled and tapped for clamps. I don't see a couple of 1/2" welds on each tab causing any issues, except for paint damage.
    Chris
  9. Budget36
    Budget36
    Is the concern a fire inside?
    bobss396 likes this.
  10. James Sacred
    James Sacred
    Ain't no big thing. Just ground to the diff near where your welding. Try to avoid current going through a bearing.
    The heat is not enough to hurt anything by just welding a bolt or bracket to the diff. The oil won't even notice you did it.
    Absolutely nothing to be worried about.
    bchctybob, Paulz, Tman and 4 others like this.
  11. 73RR
    73RR
    ^^^what he said, ground very close to weld.
    bchctybob, Desoto291Hemi and nochop like this.
  12. DDDenny
    As was mentioned prior to drill/tap/loc***e, that will work fine, use heavy grease on tap to control shavings.
    By the way, if it was me, I'd weld a whole 1/4" bolt instead of just a stud.
  13. nochop
    nochop
    from norcal
    A lot of my concerns are current though the bearings. I’m in the process of stripping and painting now so paint damage isn’t a concern. All in the thread “Blowing this thing apart”.
    rattlecanrods likes this.
  14. nochop
    nochop
    from norcal
    I’ve have weld nuts just down really want to drill the housing, kind of a scaredy cat
  15. Rickybop
    Rickybop
    Shouldn't you bolt on your rear end housing rather than weld on your rear end housing?
    Ork Ork Ork Ork Ork Ork...
    Algoma56 and Tman like this.
  16. 2OLD2FAST
    2OLD2FAST
    from illinois
    Huh ?
  17. Rickybop
    Rickybop
    Hah?
  18. 05snopro440
    05snopro440
    No, don't drill and tap. If you do, the areas will be more susceptible to fatigue cracking than welding on a tab or stud.
    ekimneirbo, nochop and Fitty Toomuch like this.
  19. nochop
    nochop
    from norcal
    Proper commas? Or proper quotation, Help Uncle Jack off a horse…..or “ help” Uncle jack off a horse. Probably why I’m a “plumber “ and not a writer
  20. Marty Strode
    Marty Strode
    I would weld raw steel nuts, and use short stainless steel ****on head Allen bolts.
  21. Pete1
    Pete1
    from Wa.
    Any weld or heat applied to the housing will bend it some.
    What you want to do, you will probably get away with.
    Keep in mind that what you are doing is one method that is used to straighten bent housings.
    As noted before, observe carefully where you put the ground wire.
    nochop likes this.
  22. 2OLD2FAST
    2OLD2FAST
    from illinois
    Do you think manufacturers straighten each & every rear end housing during the production welding process ?
    427 sleeper and nochop like this.
  23. Pete1
    Pete1
    from Wa.
    Yes.
    nochop likes this.
  24. lostone
    lostone
    from kansas
    I don't agree, I've done suspension work for 40 yrs and seen factory new axles every where from -1/2 camber to +5/8 pos camber. Toe anywhere from a 1/4" in to a 1/4" out.
    I say it's done on a jig, pulled from jig and checked, if it falls into their loose oem specs out the door it goes....
    Tman and 2OLD2FAST like this.
  25. rattlecanrods
    rattlecanrods
    As stated above make sure there are no roller bearings between your welder ground and electrode (burny end). Failure to do so will create a whole bunch of tiny welds inside the bearing...
    Okie Pete and nochop like this.
  26. ekimneirbo
    ekimneirbo
    from Brooks Ky
    When you weld them, clamp them in place so they can't move away from the housing.
    Then weld one side of the block or bolt or clamp that you are attaching. Not one side of the housing, but one side of the block or bolt or clamp on each side of the rear end housing.
    Then let it cool for a few minutes and weld the other side of the bolt or block or clamp on each side of the housing.
    Probably overkill, but minimal heat buildup.
    05snopro440 and nochop like this.
  27. bobss396
    bobss396
    I have attached a brake hose bracket to a Ford housing, by brazing rather than welding.
  28. 2OLD2FAST
    2OLD2FAST
    from illinois
    That's funny.
  29. krylon32
    krylon32
    from Nebraska
    If your a good welder and have everything ready to go you'll need less than a minute of weld time for each stud. I've done this many times a never gave it a thought. I have tried to not overthink a simple operation.
  30. 05snopro440
    05snopro440
    People give a lot less thought to welding on suspension brackets to a rear end housing than has been given to this minor question.
