Technical welding pitman arms
Discussion in 'Traditional Hot Rods' started by ago, Dec 28, 2013.
  1. iadr
    iadr
    deleted
  2. ago
    ago
    from pgh. pa.
    What steel are they usually forged from? 4340 Does not like to be welded and not stress relieved after.
    Ago
  3. gimpyshotrods
    gimpyshotrods
    Unsure, but I have welded a ton of 4340 in my time. Pre heat, post heat, heat treat, no issues.
  4. GlenC
    GlenC
    Aussie road racers, 1950's. The one in front is Hudson-based, the one behind is a 120 series Jaguar based racer. I'll see if I can find another pic of Frank's, it was called the SO-CAL SPECIAL in its day.
    Cheers, Glen.
  5. GlenC
    GlenC
    Paul, here's another one, this one's based on a mid 30's Hudson also, but fully restored. I suspect this is what Aussie blokes who wanted to go fast did rather than hot rodding at this time.
    Cheers, Glen.
      234.2 KB
  6. GlenC
    GlenC
    And here's the full story on the So-Cal Special, including the correct engine that was swapped in place of the sidey, and the story of the broken pitman arm, all from Frank's daughter, and a number of era pictures of the special, and the sort of road racing done in Australia in the 50's and 60's.
    http://www.motormarques.com/community/drivers-and-cars/item/569-so-cal
    Cheers, Glen.
  7. Bert Kollar
    Bert Kollar
    Years ago I wanted to change the geometry of my pitman arm. A good friend worked in management at Lincoln Electric and he gave the project to the engineers at Lincoln. They cut, welded, heat treated and xrayed the arm and said it would be stronger than original. These were real pros. The first time I took the car out it broke and I ran into a telephone pole. Fortunately I was able to slow the car down and didn't kill myself. If this doesn't convince you then you must have a death wish.
  8. saltflats
    saltflats
    from Missouri
    Ok if you cant weld them how would you make the tapered internal splines if someone wanted to make one and what would you make one out of.
  9. gimpyshotrods
    gimpyshotrods
    My rock rig has an arm I welded. It has 199,000 miles on it. If that doesn't convince you, then you probably understand that the plural of anecdote is not data.
  10. roseville carl
    roseville carl
    Nice job Marty........
  11. The problem here is your good friend gave it to the engineers, not a welder.
    All the production pitman arms I've ever worked/welded on were forged low carbon steel, not at all difficult to weld.
  12. designs that work
    designs that work
    Question, if welded pitman arms are unsafe where do welded ujoints to shafts fall in the safety scope?
  13. gimpyshotrods
    gimpyshotrods
    How about my fabricated spindles? Or axle housings?
  14. gimpyshotrods
    gimpyshotrods
    Thumbs up, or thumbs down.
    I also would like to hear more about the one that failed the the Lincoln "experts" did. I have personally cut and welded, or otherwise modified more pitman arms that the number of failures indicated in this thread, with zero failures.
  15. designs that work
    designs that work
    I was referring to steering ujoints, not drive lines.
  16. badshifter
    badshifter
    So many "it broke and I almost died" stories, and yet not one picture of the failed weld.
  17. slinginrods
    slinginrods
    from florida
    This. There are probably thousands of welded parts on steering and suspension components in use on the street and in highly abusive off road race vehicles. Bottom line if you are a competent welder you will be fine. Bunch of panic merchants on here .
  18. 117harv
    117harv
    ^^^ This, well said.
  19. ago
    ago
    from pgh. pa.
    It is easy to type on the forum.
    Ago
  20. VoodooTwin
    VoodooTwin
    from Noo Yawk
    This convinced me....to stay away from Lincoln products. :p
    Atwater Mike likes this.
  21. ago
    ago
    from pgh. pa.
    Now come on Voodoo, my son is an engineer at Lincoln Welding. The first year he worked there out of college, he trained for a full year in every department to get experience. He had to go thru the complete welding school and p*** all the out of position manual welding, in all forms of welding. Then they put him him in his engineering job.
    Ago
  22. bobss396
    bobss396
    Bingo. I had a couple that were welded on stock cars which took quite a bit of abuse. I did all the cutting, fittting and mock up, but had a greatly experienced welder s***ch it up. Once it was completed, cleaned up and painted, it looked like new.
    Bob
  23. Gary Addcox
    Gary Addcox
    There are no "failures" in steering setups if DD rod is correctly utilized with Borgeson-type u-joints. There is no welding. The ONLY way to go.
  24. gimpyshotrods
    gimpyshotrods
    For you.
  25. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Whats that have to do with the question of welding a pitman arm :confused:
  26. Stretchmobile
    Stretchmobile
    from So Cal
    I've welded pitman arms, spindles and steering shafts. I made lengthened VW bug ball joint trailing arms out of two sets. Took it out and beat the hell out of it on and off road. Never failed. I am not a certified welder but did spend the night at a Holiday Inn Express last night.
  27. Olderchild
    Olderchild
    from Ohio
    I'm curious to how many were done in the past with stick or ox/ gas and still worked,i would guess that was old school though:rolleyes: . I watch my friend narrow a dodge axle and stick weld it back together when everyone said it would not hold up, i guess he proved them wrong, it's still under the car after almost 50 years
  28. Frankie47
    Frankie47
    from omaha ne.
    Another option I seem to read on here once in a while, is recruiting the services of an automotive blacksmith.......although this seems prevalent mostly in Europe and down under. andydodge has done this I believe.
  29. 38Chevy454
    38Chevy454
    As the old HAMB metallurgist, welded pitman arm can be fine. Key word "can" as in the welding technique and especially the pitman arm base material alloy. Most are low carbon steel and no problems welding by almost any technique. It is the higher alloy and specifically higher carbon that can mess you up. Proper weld prep and full penetration are required for any. Some of the harder to weld alloys need pre-heat and post-heat. Slow cooling is always good.
    The big problem is knowing what the base material is before you start. You can get it checked (money...), you can do a crude spark test to get an idea which is effective if you know how to do it.
    Would I do it on my own vehicles? Yes, I would but I also would be careful to figure out the material so I could be ***ured of the right welding process.
  30. Olderchild
    Olderchild
    from Ohio
    I retired from a steel mill and watched many a good spark testers save the comp. *** on mixed bundles of steel. Many people would be surprised by what a good spark tester can tell you about the type of steel and compounds that are in it just from the spark, the big thing is he cant be color blind:D
