Welding Pot Metal
Discussion in 'The Hokey Ass Message Board' started by I_be_moose, Dec 31, 2009.
  1. I_be_moose
    I_be_moose
    Has anyone here successfully welded pot metal? We are going to narrow a 52 Chevy dash and that will mean we will have to remove a few bars from the center. Looking for the best/correct way to put the grill piece back together and allow rechroming.
    Thanks
  2. Unkl Ian
    Unkl Ian
    IIRC, Polisher used to recommend Silver Solder for Die Cast repairs.
    Definitely practice on something else first,
    Zinc doesn't have much of a working window.
  3. 55bomba
    55bomba
  4. wbrw32
    wbrw32
    Take the pieces out that need it and line every thing back to where you want it welded...send it to Pauls Chrome in Pa.He can weld and chrome it....expensive,yes but he is the best.....
  5. hotrod40coupe
    hotrod40coupe
    It is very unforgiving. It has a very low melting point and even solder can be tricky, DON'T use a torch.
  6. duste01
    duste01
    If you have never done it, your best to practice on something you can throw away after you destroy it. I had to learn in college, its like working with ****er only you cant get the shape back after it melts away.
  7. Rickybop
    Rickybop
    Consider not cutting the insert? Cut the surrounding sheetmetal out, section the dash, recut the opening, and weld the surrounding metal back in? Or...section the dash on each side of the insert?
  8. shawnspeed
    shawnspeed
    from Attica Mi
    It can be done , it is best to use some of the s****s as filler, or there is rod for it but it is pricy...and as said above practice on something you don't care about first...I do my pot metal with a TIG , but I have seen an old timer do it with O/A torch....I wouldnt even attempt a torch...Shawn
  9. allstarderrick
    allstarderrick
    I've used the Eastwood welding rods for pot metal and it worked pretty well. Takes a little practice and patients. It's sort off like welding crayons together, goes from a solid to a liquid quickly.
  10. MERRELL
    MERRELL
    anyone have some input on welding or brazing pot metal to steel...[bezels to a fender]?
  11. Pot metal Bezel to steel fender - use body epoxy instead of welding. Strong stuff. Doing my 54 Ford next week.
