welding question
Discussion in 'The Hokey Ass Message Board' started by ml68nova, Nov 10, 2009.
  1. ml68nova
    ml68nova
    On a 46 ford, the front sway bar link is attached to the perch bolt. I trashed those pins taking the front apart.
    I`m using new plain style perch bolts.
    My question is: I need to weld a lower sway bar bracket some where. Can I weld to the perch bolt? Or should I weld to the wish bone or axle.
    Thanks, Mark
  2. Paul2748
    Paul2748
    Get a new perch bolt. Try Job Lot for one - they might have a new one.
  3. ml68nova
    ml68nova
    Thanks but mine are new. They are the flat top or plain style. I couldn`t find any originals so I`m using swaybar links from a Nissan Altima. I just need to weld a flat piece of metal off of somthing that won`t compramise saftey.
  4. 37FABRICATION
    37FABRICATION
    Don't weld to a bolt... duh.
  5. ml68nova
    ml68nova
    I`m only considering the bolt because that where the factory put it.
    If not the bolt then what about the axle or wishbone?
    Mark
