Projects Welding together 2 33 34 coupe bodies - Build Thread
Discussion in 'The Hokey Ass Message Board' started by Uptown83, Jul 5, 2014.
  1. Uptown83
    Uptown83
    I wanted to share my build pictures of me putting together my 1933 3w coupe and my mixed up 33/34 frankenstien 5w coupe body. This will be me just welding together the bodies. I Should finish this year.
    This is my first build thread so bear with me!
    The 3w was my first hotrod. Didnt know what the hell I was doing and it was out of whack to begin with. So long story short I am going to fix it correctly now. Plus it was a streetrod that will be turning into a "restorod"
    The 5w is just parts and pieces I picked up over the years and now its time to weld them together!
    First thing I started with was building a nice original frame. Having a square frame is #1 building block. I tried once lining a car up on a croocked frame and never really worked. I didnt know it was crooked for the longest time either. But anyhow I made this frame jig probably 11 years ago. Used it once and now I get to use it again briefly
    Putting my x member pieces in IMG_0111.JPG I had to use a floor to help make sure I was putting the x member in the right place. All of the frame diagrams only show measurement for the rails! IMG_0114.JPG
    X member tacked in.
    As I was waiting to sand blast I made new rear trunk braces. Here is what I had between both bodies
    Finally off to sand blast! The model A is my friends. My Frankenstein coupe though in the back of his truck. IMG_0147.jpg
    mauler rich likes this.
  2. The37Kid
    The37Kid
    Great start on your first build thread, great photos, look forward to following both builds. Bob
  3. ROADSTER1927
    ROADSTER1927
    Looks like a great start and workmanship! Gary
  4. Uptown83
    Uptown83
    Back from sandblasting. I sand blasted a bunch of things I guess I didnt take any pics though.
    Fixed the original back piece. Bought another one for the other coupe
    The front of the floor had been cut out. Since I am going for more original on the 3w I needed to buy this.
    Cutting it up to fit
    I wanted to add this because WTF!? I didnt notice the battery access hole hitting until after I tacked in the floor. Both sides have the same overlap. Oh well I will fix it later. IMG_0201.jpg
    First glimpse of a body! Just placed the body over the floor. I cut out the old floor. It was one I made a long time ago. It*****ed.
  5. rusty1
    rusty1
    nice work, this'll be cool.
  6. big duece
    big duece
    from kansas
    I'm digging the nice couch in the shop, wish I had that much room. Looking forward to the build.
  7. Hnstray
    Hnstray
    from Quincy, IL
    Looking forward to following this thread. Thanks for posting. Keep up the good work.
  8. Uptown83
    Uptown83
    The back is lining up pretty good.
    Welding in new nuts for the subrail. I did this in all the spots.
    Garbage that will be cut out and fixed the right way.
    The start of lining up the door. Beginning phase. I am using Don Smart door post
    Here is the door as of this morning. It open and closes. Lines up. Needs a little tweak but it is very close. Moving on to the other side today. Will take pics!
  9. Uptown83
    Uptown83
    Yeah I love having it in there. Was from the house when we got new couches.
  10. Uptown83
    Uptown83
    I would like to add. 10-12 years ago the body was out of whack and I used welding rod to fix the gaps on the doors. All that has been cut out and I am lining up the doors like it should of been done.
  11. 3wLarry
    3wLarry
    from Owasso, Ok
    patiently waiting
    kidcampbell71 likes this.
  12. ss34coupe
    ss34coupe
    You are doing some great work here, saving two coupe bodies in the process. Will be following your builds, you are doing it right!
  13. MAD 034
    MAD 034
    from Washington
    Will be watching along as you move forward. Very cool you are building it from pieces -- not a job for the faint of heart!
  14. brady1929
    brady1929
    Wow, great job!
  15. Great job keep the updates coming
  16. Dr Frankenstein would be jealous :)
  17. I love the model 40's..thanks for sharing, looking forward to updates.
  18. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Great work so far! I'll look forward to following your progress. I started with a really rough 34/5 window (no floor, firewall, etc.) It's a LOT of work building a floor, getting doors to fit well, etc.
    Ironically, I've also been collecting parts for years to build a puzzle 34 3/window...
  19. fab32
    fab32
  20. fab32
    fab32
    Excellent start correcting the first build. It's amazing how many of us will take short cuts when entering this hobby. Most of the time it is out of necessity for lack of experience, time, money, or all of the above. Rarely do we have the opportunity to go back and start over. Your project represents one of the Holy Grails of rodding (a 3w model 40) and any effort you put into it will well be worth the effort/$$$$'s.
    Keep us up to date as you make progress this is going to be a good one.
    Frank
  21. Uptown83
    Uptown83
    Well I was hoping I was going to get the passenger door on today. Nope. Spent most of the day messing with it and could never get anything to line up. I think I went backwards today.
    I started off by getting side tracked by taking off the inner door skin. I wasnt the guy that originally cut this out. It was tacked it place and bad at that. I went ahead and took it out and took out some of the dents and put it back in. I por15 the backside. I also will be doing a new door skin on both doors. Waiting on patch panels.
    There is a lot of work that is happening that pictures really cant show. I had the door hinges bent out from the first time. This time I have bent them all flat and starting with that. here is the door post on the door. Making sure it swings in and out correctly before I put it in.
    Got the inner door skin back on. Its still tacked but much better. I still have work to do on it. I need to cut out the mid door handle area. I need to put a flat piece back in so I can put in the 33 door pull.
    Here is me starting to try and line up the door. I tacked it in place but nothing was fitting right. I also and going to add back the original door lock. I welded it up the first time. But everything is still there for it inside the door.
    It looks decent but its way out. There is no room for the rocker if you notice!
    You can see why I cut the corner out. Garbage. Putting new patches in from Don Smart. Just gotta wait for them. What*****s about it is, I have no idea when I will get them.
    I stopped to put the rocker in since my door seemed way low. Its funny how you have to notch the notches for them to fit the step outs for the sill. You would think they would have got that right when they made the stamp. IMG_0221.jpg
    After messing with the doors for most of the afternoon I finally figure out what the hell is wrong. The passenger side is 1/2 inch lower then the driver side kicking the back of the door down. I even shimmed it first. Then finally I measured it and seen how out it really was. This is where I am leaving it tonight. I will continue tomorrow.
    Also I am putting a stock firewall in.
  22. Uptown83
    Uptown83
    You know I am a bit embarrassed to show my original work. It was my first project and I was learning. Learning on a crooked 3w is a bad idea to add. However I have gotten much better got 2 other cars behind me now, which came out great. I started when I was 17 or so. I am now 30 about to turn 31.
  23. timwhit
    timwhit
    There will be those days that make you wonder why your doing what your doing.... we have all been there. Keep after it, it is looking great!! I know what your goin through, as a lot of guys on here could say. Looking forward to updates. Hang in there....tim
  24. Nice job and cool projects!
  25. Uptown83
    Uptown83
    IMG_0245.JPG Still working on door gaps. Passenger side is good, but both sides sag a little when you open either door. Trying to get it out.
  26. HOTRODPRIMER
    HOTRODPRIMER
    Your attention to detail is evident.
    The fit and finish is very impressive,I'm subscribed. HRP
  27. Good stuff here!
  28. You're doing a great job of saving this car!
  29. Uptown83
    Uptown83
    Finally making some progress this afternoon.
    Got bored messing with doors so I stopped and tacked the rocker in. You have to like press fit these guys in.
    Went back to door. Got it! Lines up. No sag when you open the door. Feels good.
    Time to fix the gapping hole above door.
    Patched tacked in. I will gas weld it fully in on a different day.
    To explain the metal strip in the tack strip. Since the body was split at the roof and pushed out, I didnt know where or what the correct opening was anymore. So I measured the other side where the ribs bolt to and make a quick brace to hold it how the other side was. Not the most accurate place to measure but it worked out just fine.
  30. Uptown83
    Uptown83
    I will add some pics of the door post installed later. So incase anyone else installing don smart door post want any pics for reference.
