Technical Welding
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Nov 5, 2015.
Tags:
  1. 33sporttruck
    33sporttruck
    2 Makita angle grinders, 1 Air powered grinder, 1 die grinder and 1 angle die grinder. At age 68 my welds still look like ****. Forgot to mention 13 various files for the tedious work........... Jeff
  2. scooterp0019
    scooterp0019
    from tennessee
    As a young man I wish I could weld, now I wish you could.
  3. mgtstumpy
    mgtstumpy
    Down here your welds get inspected during the build, no grinding until after inspection.
  4. I'm going to wager that the cars on the road are generally better because of that.
    volvobrynk likes this.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    Remember years ago when I was in my 20's. Was at Bab**** And Wilcox taking a pressure vessel certification. The old saying was. It's not how well you weld it's how well you grind.
    The instructor was an inspiration. 2000 people and as a new hire I didn't have a time card in the rack. I approached the time keeper and gave him my name. Immediately he wrote down my employee number. Just amazed that he knew it I exclaimed to the instructor how and the heck with that many employees he could remember my number.
    His answer. That's nothing.
    He can't weld.
  6. Gorilla welding..... one of my specialties.
  7. Binger
    Binger
    from wyoming
    Sometimes I ask myself if I am a grinder who welds or a welder who grinds. HAHA
    '51 Norm likes this.
  8. that's got to cut down on the "rodent" rod population!
  9. dreracecar
    dreracecar
    from so-cal
  10. BamaMav
    BamaMav
    from Berry, AL
    And here I thought dirt dauber welds were traditional. I guess the previous owners of my car didn't own a grinder!
  11. dirt t
    dirt t
    Funny stuff guys.
  12. 56don
    56don
    I have discovered that the welds I made when I was thirty seven are a hellava lot better than the ones I am making at sixty seven. I think I know why but don't want to admit it...
    33sporttruck likes this.
  13. treb11
    treb11
    If you cant weld good, weld a lot!
  14. '51 Norm
    '51 Norm
    from colorado
    Last year I had cataract surgery. I can weld again. I didn't realize how bad my eyes were; it explains the really nice welds that were 1/4" away from the joint!
    falcongeorge, 56don, MRTS33 and 2 others like this.
  15. Budget36
    Budget36
    I started wearing mag gl***es under my hood a few years back...was like night and day, then happened across a Mag gl*** for my helmet...that and the large auto darkening lens...mercy...I can see again!
    falcongeorge likes this.
  16. dirt t
    dirt t
    Where do I find such a lense? I bought my hood at Praxair and I have an added magnifier inside.
    Terry aka dirt t
  17. Budget36
    Budget36
    We might be talking the same thing?
    I have a 1.5 mag cover gl*** that goes in front of my lens (inside the helmet), it's not the lens that is magnified.
  18. chaos10meter
    chaos10meter
    from PA.
    My Dad was a boiler shop welder for almost 50 years,no positioners, weld it where it stands, vert.,horz,overhead.
    He could lay a weld that I still can,t match.
  19. "Now-Just because you can wash the sheets doesn't mean it's OK to **** the bed." That's what my welding instructor used to say about us using grinders.:D
    Some hamber here said this a few years back. "Chrome on B*** welds is like suntan lotion on ****s" now that's another great ****ogy there.
    falcongeorge and 117harv like this.
  20. ct1932ford
    ct1932ford
    I am a certified weldor and worked for near 40 years doing mostly s/s sanitary pipe.(TIG) The problem I have now is seeing where the hell I am going. It's a ***** getting old!:confused:
  21. leadfootloon
    leadfootloon
    I went to night school and became certifiable by the state if i wanted to pay. My teacher was a state certifier.
  22. leadfootloon
    leadfootloon
    :D:D
    ct1932ford likes this.
  23. Gene Boul
    Gene Boul
    Great welds are what friends are for! I'm way to particular to weld my own stuff!...unless it's an emergency.
  24. deathrowdave
    deathrowdave
    from NKy
    Many years in training as a welder . Stationary Engineer by trade . Just remember , structure and sheet metal different type of welding . OEM cars are just tacked ( spot ) welded together. Tack or spot your panels return hours later add a few more , repeat until fully welded . Tig is the answer for heat control but most don't have access , Mig works for all of us . Just be clean and slow go to stop warpage issues that are worse to repair than the rust started out to be
    gary jenkins likes this.
  25. stimpy
    stimpy
    just got back from repairing a tank ( r stamp ) we use a spool gun if its a easy spot , but if the metal is a problem we hand tig it , I was workign with my buddys mig welder and liked how smooth it was going , and checked all the settings and stuff , came home to play with my welder and I have noticed since I borrowed it out ( its a little 120 handimig ) several years ago its never been quiet the same , the guy who I borrowed it to said it kept bird nesting in the cabinet or hanging up at the tip , I kept on blaming it on the feed rollers and the wire, then the tension , well I wanted a new longer gun for it ( 8' is not enough ) so I got a 15' for $150 ( HTP) , and ran the wire thru it and it was smooth as my buds big one welded beautifully for a mini mig . so I got thinking and pulled the liner on the old one . MF'er the liner has 3 kinks in it and one you can see the plier marks in it where they tried to dekink it . called the guy who borrowed it and he said he never took it apart , but his kid used it earlier . he asked him . 4 years and I find Out the kid closed a car door on the hose and tried to fix it . but didn't say nothing ... well now to order a new liner for my tweco ain't gonna throw it out .. and the kid is paying for it he said ..
  26. The37Kid
    The37Kid
    Thanks, that was me, sure wish B*** was still posting stuff here on the HAMB, that guy sure could weld. Bob
    117harv likes this.
  27. Don's Hot Rods
    Don's Hot Rods
    from florida
    I've never been a good welder, but my welds at least held. It has gotten worse as my eyes age, so I now let my Son Dan do all my welding for me. I feel bad taking his time away from his projects, but he is good about doing it.
    I needed a motor mount for the engine in my rpu, and a few weeks ago he did this one for me.
    Don
  28. Donut Dave
    Donut Dave
    TIG WELDER:
    Just because you own one doesn't mean you are one....
  29. Petejoe
    Petejoe
    from Zoar, Ohio
    Just for fun. Not to be a ****.
    I am a weldor. The machine I use is a welder. My, what computers have done to the English language. :)
  30. The37Kid
    The37Kid
    Goal for 2016 is to have a TIG. Bob
